  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  DH8302
0 Members Browsing (61 Guests)
  Author    DH8302  (currently 614 views)
Matt_Phillips
Posted on: April 3rd, 2019, 07:39:22 Quote Report to Moderator
Hi all,
Just to say hello and pass on that I now own DH8302
https://www.minimarcos.org.uk/minimarcos/8302/index.html
Matt
Last modified June 12th, 2019, 07:58:30 by Matt_Phillips
Posted on: April 3rd, 2019, 08:49:05 Quote Report to Moderator
Little bit of work there.
Private Message Reply: 1 - 15
Gary Marlow
Posted on: April 3rd, 2019, 13:43:17 Quote Report to Moderator
Will be good when done.
Funnily enough - well it is for me - the person who built my Mk 3, cut the front off the car with the plan to make the front look more like a Jem.
Gary
Private Message Reply: 2 - 15
Gary Marlow
Posted on: April 3rd, 2019, 13:46:44
Hopefully attached!
Private Message Reply: 3 - 15
Philip_Davenport
Posted on: April 4th, 2019, 10:00:02 Quote Report to Moderator
Good luck with this Matt. The front wheel arches look very cool!
I think I can see a  classic Mini under the cover. Is this for parts or is it running?
And a white Mini Marcos in the foreground.. what is the story with this?
Or are these pictures from the prior owner?
cheers Philip
Last modified April 4th, 2019, 10:01:39 by Philip_Davenport
Private Message Reply: 4 - 15
Posted on: April 4th, 2019, 20:05:28 Quote Report to Moderator
Quoted from Matt_Phillips, posted April 3rd, 2019, 07:39:22 at here
Hi all,
  Private Message Reply: 5 - 15
Matt_Phillips
Posted on: April 5th, 2019, 11:14:54 Quote Report to Moderator
Quoted from Philip_Davenport, posted April 4th, 2019, 10:00:02 at here
cheers Philip
Last modified April 5th, 2019, 11:17:22 by Matt_Phillips
Private Message Reply: 6 - 15
Matt_Phillips
Posted on: April 16th, 2019, 16:37:41 Quote Report to Moderator
Private Message Reply: 7 - 15
Matt_Phillips
Posted on: June 12th, 2019, 08:00:13 Quote Report to Moderator
The eagle has landed
Private Message Reply: 8 - 15
Matt_Phillips
Posted on: June 12th, 2019, 08:01:19 Quote Report to Moderator
Private Message Reply: 9 - 15
Matt_Phillips
Posted on: June 12th, 2019, 08:02:09 Quote Report to Moderator
Private Message Reply: 10 - 15
Matt_Phillips
Posted on: June 12th, 2019, 08:03:57 Quote Report to Moderator
First batch of powdercoating
Private Message Reply: 11 - 15
Posted on: June 16th, 2019, 14:22:56 Quote Report to Moderator
Matt - after the powder coating do you have to re-tap any threaded holes?
If so, does this cause the powder coating to chip off?
Private Message Reply: 12 - 15
Matt_Phillips
Posted on: February 14th, 2020, 13:51:49 Quote Report to Moderator
Last modified February 14th, 2020, 14:01:33 by Matt_Phillips
Private Message Reply: 13 - 15
Matt_Phillips
Posted on: February 14th, 2020, 13:52:19 Quote Report to Moderator
Private Message Reply: 14 - 15
Powered by e-blah Platinum 7 Final © 2001-2004   -   February 17th, 2020, 11:58:20
