  Mini Marcos Forum  >  General Boards  >  Mini Jem  >  MK3 jem from Malcolm Fell
0 Members Browsing (7 Guests)
  Author    MK3 jem from Malcolm Fell  (currently 722 views)
maxos
Posted on: August 5th, 2021, 16:39:34 Quote Report to Moderator
hi all,
i bought a mk3 jem one month ago.
the car is from Malcolm Fell.
i have some questions about this shell product.
is there a plate? because on mine i can't find.
if yes someone know how many shell was produced by Malcolm fell. and the shell numbers list?
thanks in advance
Last modified August 5th, 2021, 16:40:35 by maxos
Posted on: August 5th, 2021, 17:33:04 Quote Report to Moderator
There aren't really any definitive records as to which company built which cars. If you have a chassis number that can help however a lot of car have lost their chassis numbers through the years. Some pictures may help identify the car through the club gallery but even then that may not help. I have Malcolm's ex rally car but even that doesn't have a chassis number other than its mini donor.
Private Message Reply: 1 - 8
maxos
Posted on: August 5th, 2021, 18:46:55 Quote Report to Moderator
hi Mike,
thank for answer.
the car is knowed on the forum
it's the OWY157K.
the plates actually are from clubman estate donor ... but i really preafer know the original shell number.
will see if somthing is possible with this to have the road clearance.
Private Message Reply: 2 - 8
Posted on: August 5th, 2021, 21:22:04 Quote Report to Moderator
I had that car for a while. It was part of a collection that needed re-homing about 5years ago. Unfortunately I know for a fact that the original chassis number was lost well over 30 years ago. The owner before I had it bought it as an incorrectly registered car to save it from the scrap man I believe.
Private Message Reply: 3 - 8
maxos
Posted on: August 6th, 2021, 13:07:13 Quote Report to Moderator
Ok so il know mk3 was made by malcolm and he produce aprox 10 cars.
I know the begining of number is mrmsf.
doesnt exist register of the serial number of the malcolm kit cars?
I already foud some jem virgin plate.
Private Message Reply: 4 - 8
Posted on: August 6th, 2021, 21:36:44 Quote Report to Moderator
Unfortunately any paperwork regarding build numbers and chassis numbers has been seperated from the moulds and is presumed lost I'm afraid.
Private Message Reply: 5 - 8
Allan_Scott
Posted on: August 20th, 2021, 20:05:04 Quote Report to Moderator
In regard to the Mk 3 jems i do know that Malcolm fell is a kart scrutineer, i was speaking to a scrutineer at harewood hill climb a while ago and he knew him, i think he has something to do with a kart track up Newcastle way, if you contact him he may be able to help
Private Message Reply: 6 - 8
maxos
Posted on: August 22nd, 2021, 08:46:08 Quote Report to Moderator
Ok thanks i found on LinkedIn and sent him message.
Lets pray 😀
Private Message Reply: 7 - 8
Allan_Scott
Posted on: November 14th, 2021, 19:10:25 Quote Report to Moderator
Any luck contacting malcolm Fell ? would be interested in knowing you have more info on your car.
Private Message Reply: 8 - 8
Powered by e-blah Platinum 7 Final © 2001-2004   -   November 27th, 2021, 10:53:56
Files opened: 104 | Files closed: 104
