  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  MK6 New shell build update
0 Members Browsing (37 Guests)
  Author    MK6 New shell build update  (currently 120 views)
stevecrook
Posted on: January 2nd, 2021, 15:22:25
Progress update on my MK6 build. Car inverted and supported on axle stands to fit fuel tank, rear subframe with running gear, brake / fuel lines and battery cables. Also fitted steering rack and test fit of front subframe. Headlining was easier to do while inverted as well. Wiring Loom labelled up.  Went through the IVA manual again. Most difficult job so far was rear subframe alignment and had to fit elbow grease nipples on the radius arms for access for future greasing. A third of the way through my task list so expect the build will be nearer 6 months rather than my predicted 4 months. Satisfying and enjoying doing the build again almost 40 years on from my MK4 build !
Powered by e-blah Platinum 7 Final © 2001-2004   -   January 16th, 2021, 09:24:21
Files opened: 84 | Files closed: 84
