the first (currently 1 views) |
| scrog |
Posted on: July 7th, 2004, 18:30:23
old enough to know better
well here's some pics of my kingfisher well strive to get on the road this month  |
| scrog |
Posted on: July 7th, 2004, 18:37:56
got some 8x13 for the rear almost fill out the arches can get another 1/8" wide with out risking damage (wheel nuts still have 6 turns they tell me thats safe) they have 195/45/13 tyre's so should stick well
and 6x13 for the front but not fitted yet got to split the disc to get the stud's in (80mm)
what do you all think |
Reply: 1 - 5 |
| scrog |
Posted on: July 7th, 2004, 18:41:37
| more pics |
Reply: 2 - 5 |
| Neil KilBane |
| Posted on: July 8th, 2004, 10:56:17 |
Just a quick question on the body work, I see that your car suffers from the pink haze, is there any way to get rid of this, my marcos is also a sufferer, I cut the haze back with T-cut but found it very hard to get an even finish/luster, there was alwas some area of each panel that looked "out" . Then the haze started to return within a couple of months.
Neil |
Reply: 3 - 5 |
| admin |
| Posted on: July 8th, 2004, 14:21:38 |
I think a respray is the only real answer. Some gelcoat colours and especially the 'red' used on Mk. IV Mini Marcoses tends to fade and go streaky after a few years in the sun. It's not just surface oxidisation. I've seen similar fading on a blue D&H Midas.
Richard |
Reply: 4 - 5 |
| scrog |
| Posted on: July 8th, 2004, 16:07:15 |
cant afored a respray at the mo so will try fine wet & dry first then cutting compound then t cut will let you know how it goes |
Reply: 5 - 5 |
