  Mini Marcos Forum  >  General Boards  >  Mini Jem  >  Grannies Great Aunt!
  Author    Grannies Great Aunt!  (currently 1 views)
Pete Crudgington
Posted on: May 29th, 2017, 10:57:23
sorry problems with phots!
Private Message Reply: 30 - 74
Pete Crudgington
Posted on: May 29th, 2017, 10:57:50
more
Private Message Reply: 31 - 74
Pete Crudgington
Posted on: May 29th, 2017, 10:58:16
underside
Private Message Reply: 32 - 74
Pete Crudgington
Posted on: May 29th, 2017, 10:58:48
rear arches
Private Message Reply: 33 - 74
Pete Crudgington
Posted on: May 29th, 2017, 10:59:16
floor plate
Private Message Reply: 34 - 74
Pete Crudgington
Posted on: May 29th, 2017, 11:00:07
all glassed in
Private Message Reply: 35 - 74
Pete Crudgington
Posted on: May 29th, 2017, 11:00:46
floor front drivers side
Private Message Reply: 36 - 74
Chris_Pilling
Posted on: June 7th, 2017, 20:32:12 Quote Report to Moderator
Where are you getting your roll cage from??
Private Message Reply: 37 - 74
Pete Crudgington
Posted on: June 9th, 2017, 20:12:44
Chris, will let you know about roll cage, have a couple of options.
Done a bit more in past week or so.
New end plates on cross member and then reglassed it all back in.
Standard photo of a jem on its side in a garage!
Private Message Reply: 38 - 74
Chris_Pilling
Posted on: June 10th, 2017, 20:25:48 Quote Report to Moderator
Yes, please do Pete! Top job by the way!
Private Message Reply: 39 - 74
Graham_Thurston
Posted on: June 12th, 2017, 09:24:52 Quote Report to Moderator
Thought I'd get involved here!
I'm at a similar stage with mine. I got a drawing of a roll cage from Allan Scott, and will be looking at commissioning one soon. There is a guy in Norwich, quite near to me, who makes them for short track racers, and assuming he can use the CDS tube and work to MSA guidelines, should offer a solution. I'm not ready for the cage yet so will keep you posted. The big boys of this particular industry are expensive, and seem to want to weld it in.
Private Message Reply: 40 - 74
Pete Crudgington
Posted on: June 12th, 2017, 18:44:29
Bit more done, air box now complete as well.
With regards roll cages, back in 94 when I built Granny Smith (DH8351) I got the tubes from the rollcentre and fitted it all my self.  Seen a few bad crashes in the passing years so the roll cage will not be cheap, after all it may save my life one day.
Private Message Reply: 41 - 74
Chris_Pilling
Posted on: June 12th, 2017, 19:11:33 Quote Report to Moderator
Hello,
Graham just a thought.. so you may smell burning! just wondering if your man in Norwich would possibly do a small run of them? (Bolt type) as I'd certainly be interested in one and it may reduce the over all cost with a few of them. What sort of spec is your cage? Full multi point?
Or if you would be willing to copy your designs (at a price if it's cost you of course )I'd also be interested it that.
Private Message Reply: 42 - 74
Chris_Pilling
Posted on: June 12th, 2017, 19:13:56 Quote Report to Moderator
Looking spot on Pete!
Private Message Reply: 43 - 74
Posted on: June 13th, 2017, 09:45:42 Quote Report to Moderator
Don't know if you can view this, it's a build by Nicolas Pinon in France, cage was made by Endaf Owens.
https://www.facebook.com/ateli.....sw_fnr_id=2640461497
Private Message Reply: 44 - 74
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 10th, 2026, 16:28:58
Files opened: 131 | Files closed: 131
