  Mini Marcos Forum  >  General Boards  >  Mini Jem  >  Mini Jem door windows
0 Members Browsing (2 Guests)
Pages: « 1, 2, 3 » : All Reply Recommend Print
  Author    Mini Jem door windows  (currently 784 views)
Tim Neal
Posted on: May 2nd, 2010, 20:46:15 Quote Report to Moderator
Quoted from admin, posted April 25th, 2010, 21:00:36 at here
You are aware that some rocker covers have taller filler necks than others?
yes.....but the height of the rocker cover it self was even to high!
Private Message MSN Reply: 15 - 33
Nick Evans
Posted on: May 9th, 2010, 21:48:28 Quote Report to Moderator
On my Jem I had similar clearance issues with the oil filler neck when I fitted the 1275 engine, so I fitted a standard steel 60's rocker cover and gently smacked the front of the neck with a large hammer. This depressed the filler cap just enough to miss the bonnet.
I had similar clearance issues with the thermostat housing and heater tap. So used a thermostat housing off an MG Midget. It's the same stud spacing but a lot flatter. The Heater tap was cut off, and I had intended using an inline heater tap off a later mini, but sold the car before sorting it.
In this pic you can see the Midget thermostat housing, and you can just make out the kink in the rocker cover at the front of the oil filler neck.
Private Message Reply: 16 - 33
Posted on: May 10th, 2010, 18:31:54 Quote Report to Moderator
I think you can use a Metro type alloy rocker cover because the filler is in the middle where there's a bit more space.
  Private Message Reply: 17 - 33
Posted on: June 13th, 2010, 22:12:00
Posted on behalf of Jeremy:
The Mini Jem bonnet is finally finished. It now has a double,
forward-facing scoop, which clears both the rocker cover and the 45 DCOE
carb. It is painted in  BMC Iris Blue and fits correctly in position.
  Private Message Reply: 18 - 33
Posted on: June 13th, 2010, 22:13:41
  Private Message Reply: 19 - 33
Posted on: June 13th, 2010, 22:14:18
  Private Message Reply: 20 - 33
Posted on: June 13th, 2010, 22:15:06
  Private Message Reply: 21 - 33
Nick Harland
Posted on: April 5th, 2012, 21:59:38 Quote Report to Moderator
i like this! Very classy.
Private Message Reply: 22 - 33
Piffer94
Posted on: February 8th, 2017, 15:14:33 Quote Report to Moderator
I have read posts but I didn't see a reference for the lock door for the windows ? Which one did you use guys ? It is the same for the bonnet ones ?
Last modified February 8th, 2017, 15:15:51 by Piffer94
Private Message Reply: 23 - 33
Posted on: February 8th, 2017, 17:57:36 Quote Report to Moderator
The window lock is normally a panel lock (as a lot of people use for the bonnet). The idea is the lever part of the lock swings under the lifted window stopping it from being dropped.
Private Message Reply: 24 - 33
Allan_Scott
Posted on: February 8th, 2017, 22:04:08 Quote Report to Moderator
Quoted from Jeremy Harrison, posted April 6th, 2010, 06:42:03 at here
As you can see, there was severe damage to the car in 1973. The Estimate for repairs from Malcolm Fell was:
Mouldings:
Nose section & underskirt & driver's side wing £20
Rear moulding £35
Rear screen & fitting £17
Rear floor section £6
Materials:
Windscreen £22
Radiator 19.50
Perspex rear screen £6.50
Rubber and chrome strip for windscreen and rear screen £3
Carpeting £7
Petrol tank and locking cap £14
Head lining £17
Number plates £3
Labour charges:
Fibreglass £60
Mechanics £50
Transport to factory £20
Complete rub down and re-spray of whole car £60
Total £361+ £26.14 VAT
Total estimate for repair £387.54, which seems very reasonable now, but which was quite a lot in those days.
In the last photo, one of the new rear wing extensions can be seen which were fitted at the factory. I do not want them and I have carefully removed them. If anyone would like these genuine parts for your Jem, you can have them free of charge, but you'd need to pick them up from my home.
The car was repaired very well by the factory and it is only with stripping it to the bare shell that those repairs become aparent. I am having the whole shell restored and strengthened where necessary, so it should be as good as new very soon.
Wow i got my shell off Malcolm in 1975 for £432 +8% vat so it was an expensive repair you should have got a new shell!
Private Message Reply: 25 - 33
Piffer94
Posted on: February 9th, 2017, 19:30:39 Quote Report to Moderator
Quoted from mike brown, posted February 8th, 2017, 17:57:36 at here
I understand but do you have a reference for it ? for example from an another car or whatever ?
Private Message Reply: 26 - 33
Posted on: February 9th, 2017, 19:35:51 Quote Report to Moderator
This is the type I used on my last jem.
Panel Lock with Two Keys from Merlin Motorsport
https://www.merlinmotorsport.co.uk/p/panel-lock-complete-with-two-keys-pnl-lck
Private Message Reply: 27 - 33
John_Campbell
Posted on: February 25th, 2017, 11:05:23 Quote Report to Moderator
Hi Jeremy, I used the same locks as Mike and if you're careful you can disassemble the mechanism insert a key and file off the excess retaining metal, which allows you to use the door keys or have both bonnet locks on one key. Saves having four different keys.
Private Message Reply: 28 - 33
Posted on: February 25th, 2017, 11:23:30 Quote Report to Moderator
The keys have a code on them which allows you to match the locks up to the same key. You should be able to buy them keyed alike from places like RS etc.
Private Message Reply: 29 - 33
Powered by e-blah Platinum 7 Final © 2001-2004   -   January 18th, 2025, 06:27:22
Files opened: 48 | Files closed: 48
