Front tower subframe studs (currently 1,421 views) |
Piffer94 |
Posted on: December 4th, 2017, 21:32:11 |
From the records last week when I bolt the front subframe to the car, I need to use studs for the tower. Has you know, there only on innocenti models that studs were used (hydrolastics are not the right size), but there are not reproduction. Only KAD and Swift made repro at very high prices. So I used a special head stud that fit perfectly : TAM1617 http://www.minispares.com/product/Classic/Engine/Cylinder_heads/Studs_bolts_nuts/TAM1617.aspx Originaly used if you fix the coil on the cylinder head
Hope this helps ! |
Posted on: December 5th, 2017, 07:04:17 |
Thank you that's worth knowing as I have a frame with no bolts mind I'm not likely to fit it any time soon. Mke |
Reply: 1 - 1 |
