Jem rubber summary (currently 1,532 views) |
Piffer94 |
Posted on: December 12th, 2017, 17:18:14 |
Hi everyone,
I'll place an order about rubber for my jem mk2 and I would like to sum up informations that I found from archives. But for some references, I'm not sure so if you can reply to this message with your set up.
So there is the different references and lengths for rubbers:
Name Supplier Model/ Ref Lenght Number per car Windows channel ; Phoenix Trim ; VCR 4.75 ; 3.1 meters ; 1
Draught strip ; Phoenix Trim ; DS 6 ; 2 meters ; 1 Door seals ; Phoenix Trim ; DX10 ; ??? ; XX
Quarter rear windows seals ; ??? ; ??? ; ??? ; ???
Windscreen Rubbers ; MMOC ; MMOC ; ??? ; 2 (front & rear)
John_Campbell |
Posted on: December 14th, 2017, 01:17:00 |
I used MMOC rubbers for front and back windows. For the door seals I needed two different sizes as the top where the window narrows needed bigger seals. I joined the seals with Sikaflex to get a good seal. I measured the gap between the door and the body and bought accordingly. |
Reply: 1 - 1 |
