gear linkage issue (currently 1,609 views) |
Piffer94 |
Posted on: December 18th, 2017, 08:36:05 |
Hi guys,
I need your help. This weekend I was working on the jem tring to fit in the gear linkage (rog change). There is a plate with 2 holes backside of the linkage that is bolted on the car, as you can see on the picture. But the plate is too large to fit in the tunnel.
How did you manage to fix in the rod change gear linkage on the car ? Did you make a bespoke plate ?
Posted on: December 18th, 2017, 17:42:07 |
I can't see the picture, and I'm not sure what you mean by the plate. There should be a bracket with two metallastic bushes on it. You will have to modify it or make up an alternative bracket to fit the tunnel.
I mounted the remote unit higher up than normal so it sits above the exhaust pipe, and cut 10cm out of the gear lever. |
Reply: 1 - 1 |
