  Mini Marcos Forum  >  General Boards  >  Mini Jem  >  Race car ride heights
  Author    Race car ride heights   (currently 1 views)
Ian_Davies
Posted on: February 23rd, 2021, 21:52:27 Quote Report to Moderator
Hello All.
Having fitted a full cage to my Jem , I have a headroom issue.
Has anyone got a race Jem or lowered road car. What I need to know is how low can I put the floorpan. I have cut it out with a view to making up a frame work to support the seat.
Thanks
Ian
Ian_Davies
Posted on: February 24th, 2021, 20:27:49 Quote Report to Moderator
If my previous post was not that clear, perhaps another option is for an owner of a lowered Jem or Marcos could measure from the lower subframe  bolt hole on the rear heel board to the tarmac. This would give me a fair chance . Same on the front, perhaps the rear mount. This is needed fairly quickly as I want to make a proper start this weekend now that the weather is a bit better.
Thanks again.
Ian
Private Message Reply: 1 - 5
Allan_Scott
Posted on: February 27th, 2021, 20:02:43 Quote Report to Moderator
Ian i will measure up my Jem i use for hill climbs tomorrow and let you know, did your jem have the recess in the floor for seats or just flat?
Private Message Reply: 2 - 5
Allan_Scott
Posted on: February 27th, 2021, 20:46:34 Quote Report to Moderator
Ian thought i would go do the  measuring for you now so you can get on with it !! to the floor from the centre of the lower mounting bolt on the front mount on the rear subframe it is 8.75"the front i have measured from the centre of the lower arm suspension pin and it is 5.25"Hope this is of help
Private Message Reply: 3 - 5
Ian_Davies
Posted on: February 27th, 2021, 22:03:03 Quote Report to Moderator
Sorry for late reply..... watching a rugby match on tv😂
Thanks for the info . Hope to see you at harewood sometime.
Private Message Reply: 4 - 5
Allan_Scott
Posted on: February 28th, 2021, 18:53:18 Quote Report to Moderator
It would be good to catch up at harewood Ian. Look forward to that.
Private Message Reply: 5 - 5
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 12th, 2026, 18:07:08
Files opened: 111 | Files closed: 111
