  Mini Marcos Forum  >  General Boards  >  Mini Jem  >  Mini Jem door windows
Pages: « 1, 2, 3 : All Reply Recommend Print
  Author    Mini Jem door windows  (currently 1 views)
Piffer94
Posted on: June 5th, 2018, 10:02:10 Quote Report to Moderator
Quoted from mike brown, posted February 9th, 2017, 19:35:51 at here
This is the type I used on my last jem.
Panel Lock with Two Keys from Merlin Motorsport
https://www.merlinmotorsport.co.uk/p/panel-lock-complete-with-two-keys-pnl-lck
Mike didn't you have issue with the locks ? I've just receive it but there are not quarter-turn but half-turn.
I've fitted it on a door but when I spin the key, I can't release the key because the cam ends on the interior door.
Last modified June 5th, 2018, 10:03:47 by Piffer94
Private Message Reply: 30 - 33
Posted on: June 5th, 2018, 16:43:25 Quote Report to Moderator
I can't remember whether they were 1/4 or 1/2 turn. They were mounted close to the window which should give enough room but if not you maybe able to cut the latch part down to clear the door but still catch the window.
Private Message Reply: 31 - 33
Piffer94
Posted on: June 7th, 2018, 08:05:08 Quote Report to Moderator
Ok I'll try and let you know. But I'm not sure that will work.
Private Message Reply: 32 - 33
Posted on: June 11th, 2018, 10:50:26 Quote Report to Moderator
As far as I can remember there's a disc inside the lock with cut-outs that determine a) how far the barrel can turn and b) at which point(s) you can withdraw the key. You need a quarter turn.
You may need to twist or bend the cam (tongue) slightly to hold the window in the fully up position. Twisting it allows it to slide under the window more easily. Don't twist it near the square hole that locates the tongue onto the barrel as that part is very weak. I once had the bonnet blow off for that reason!
Last modified June 11th, 2018, 10:57:16 by admin
  Private Message Reply: 33 - 33
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 13th, 2026, 09:55:12
Files opened: 112 | Files closed: 112
