Mini Marcos Forum  >  Mini Jem  >  I have started to build the MK1 Jem
Topic Started by:
Printable Version
Posted by: Goff_Allen Posted on: October 26th, 2016, 20:08:56
I have started on the MK1 Jem that i purchased from Bob Stevens early this year , As Bob was moving and most of you know he could not take these cars with him, Advertised through the club and i was lucky enough to purchase the MK1 .
This will be my 3rd Jem build and second restoration/build , First was in 1968 having seen the Mini Jem in the Hot car magazine and placed a order with the late Robin Statham at Fellpoint , Penn , Bucks , Shell A , cost was £219.00 + i bought a set of headlamp cowls@ £6.66s ,, Photo attached of the original invoice courtesy of my late mam as she saved everything.
Photo of the latest project the day i bought and brought it home ,
To continue
Posted by: Goff_Allen Posted on: October 26th, 2016, 20:16:56
Reply: 1
Just arrived home
Posted by: Goff_Allen Posted on: October 26th, 2016, 20:18:05
Reply: 2
Home
Posted by: Gary Marlow Posted on: October 27th, 2016, 07:34:22
Reply: 3
Hello Goff,
Looks like an interesting one to do, a nice blank canvas to start with, hope that the shell is as good as it looks in the photo?
Bet it'll look good when done, like your other Jem.
Posted by: JERSEYMAN Posted on: October 27th, 2016, 17:14:55
Reply: 4
I hope you will post progress here, it is going to be an interesting project to watch.
Posted by: Goff_Allen Posted on: October 27th, 2016, 21:30:54
Reply: 5
I did a bit of exploration work around the front steel bulk head cross member as it was showing rust signs and the fibre glass was de-laminating , But good news Its rusty but not enough that it needs replacing , So removed most of the fibre glass , ground away the rust and gave it a coat of red oxide , The end fish plates are also OK , but just need to tap out the shock absorber mounting holes and fit in a pieces of threaded rod before it gets glassed over , Also noticed the the two drilled and tapped holes that hold the brake pedal assembly in the bulk head had been butchered , someone had drilled a hole straight through , So i fitted the brake assembly as a jig , then welded two nuts on the engine bay side again before it gets glassed over , Only part this shell has bolted on is the front shock mounting brackets and one was upside down , After removing them i have found lose fibre glass or should i say it looks like its been repaired or had a front end fitted !!!!!!!!! As whoever did the job bodged it ,Though it looks good but they never keyed the glass up and just glassed over the gell coat under the arch on the inner wing , so it was starting to de-laminate ,Resin tinted as original shell , Nearside is the same but that is the next job to tackle , Then ruff it key it up before i glass it over , A few photos added
Posted by: Goff_Allen Posted on: October 27th, 2016, 21:37:17
Reply: 6
Plenty of dust , Scratch and itch time again
Posted by: Goff_Allen Posted on: October 27th, 2016, 21:38:20
Reply: 7
painted , Just need to ruff up the fibre glass in the corners
Posted by: Goff_Allen Posted on: October 31st, 2016, 20:58:13
Reply: 8
More update , Though this was done a couple of months ago , I bought front and rear subframes secondhand , Both are Hydrolastic , Front one in nice condition ,Slight rust around the turrets , Rear one a bit more rust but salvageable , Both need converting to dry suspension , I had a rotten rear subframe that was laid in the scrap bin from my previous Jem build , I cut out the top hats and welded them in the hydro frame , Sure these act as bump stops , Heated up and knocked out the locking tabs that hold the Hyrdo bags in so the dry rubber cones will fit , same with the front subframe , Next after cleaning away all the grease , oil ect and pressure washing i made a tank to soak the rear subframe in, I don't bother with shot blasting anymore ,I use Molasses diluted 5 -1 works wonders and is a lot cheaper than blasting, Soaked the rear subframe for a week ,then washed and soaked again for another week ,Depending how rusty a component is , You may need to soak longer or shorter and wire brush in between !!!!!!!!!!!!! , Google it or watch on you tube , OK this way is slower than blasting but i only bought 10 liters and that is enough to do all the bits i have , including all the suspension parts, Once all cleaned i then sprayed and brushed painted the frames using paint that they use on off-shore rigs and electricity pylons , again i don't bother with powder coating as i like to do the components myself as i know they are painted properly !!! , A few photo's added ,
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:02:49
Reply: 9
cleaned up ready to fit
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:03:50
Reply: 10
Fitted just need to drill puddle holes and weld
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:10:22
Reply: 11
Molasses bath
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:20:52
Reply: 12
Just turned over as you can see the subframe is de-rusting nicely
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:24:34
Reply: 13
In the bath ready to cover over with molasses completely for another few days before its ready for paint
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:28:29
Reply: 14
Epoxy Blast primer as used on off-shore rigs
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:31:04
Reply: 15
first coat
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:36:08
Reply: 16
hand brushed wet top coat in all the seams before spraying.
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:38:19
Reply: 17
finished both subframes ready to build up
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:42:33
Reply: 18
Rear arms after a week soaking in molasses and just pressure washed ready to dry and paint
Posted by: Goff_Allen Posted on: October 31st, 2016, 21:44:29
Reply: 19
and painted
Posted by: Goff_Allen Posted on: November 1st, 2016, 11:56:19
Reply: 20
Heating up the Hydro tags on the rear subframe, Tap out flush then i can fit Dry rubber cones
Posted by: Goff_Allen Posted on: November 1st, 2016, 11:57:38
Reply: 21
again showing the tag heated up before knocking flush to form a ring so the rubber cone will fit
Posted by: Goff_Allen Posted on: January 10th, 2017, 20:57:15
Reply: 22
I got a bit more done today,  Modified a pair of front suspension bottom arms by adding 1/4 inch to make them negative camber , This is how i do mine , The photos should tell the story , Mark and square of with the back part of the arm , This will not change the geometry of the caster angle same as happens when lengthening the arm by cutting and welding in the middle,  OK ,Mark out , Cut with a hacksaw , Build up with weld aprox 1/8 inch in the middle , about 3 runs and one run each side , Grind a V prep , Do this to the other piece , Make sure you still have the original hacksaw cut at the edge , so you can measure , or you could just mark the arm either side of the cut and scribe a line to work from , OK so now you have the bottom arm with a V prep ready for welding , Line it all up square and tack weld each end make sure its 1/4 inch gap , If you cannot burn through the root don't worry as after the first run you can grind out from opposite side , Weld on opposite sides to stop it from pulling out of square , Grind and flap disc to finish ,any under cut just use a 1.5 mild steel welding rod to fill in , Stick weld , Use Low Hydrogen rods 7016 or 7018 , pre-heat rods also , I used a bit of scrap plate to start my runs so i don't end up with porosity at the start , About 1 1/2 hrs to do both arms , First time i did this was in 1968 ,Yes 49 years ago .
Posted by: Goff_Allen Posted on: January 10th, 2017, 20:57:57
Reply: 23
arm
Posted by: Goff_Allen Posted on: January 10th, 2017, 21:01:16
Reply: 24
run of plate for starting welding
Posted by: Goff_Allen Posted on: January 10th, 2017, 21:03:38
Reply: 25
V prep
Posted by: Goff_Allen Posted on: January 10th, 2017, 21:05:06
Reply: 26
!/4 inch gap
Posted by: Goff_Allen Posted on: January 10th, 2017, 21:10:05
Reply: 27
Tacked up one side
Posted by: Goff_Allen Posted on: January 10th, 2017, 21:13:18
Reply: 28
welded
Posted by: Goff_Allen Posted on: January 10th, 2017, 21:13:59
Reply: 29
finished
Posted by: Goff_Allen Posted on: January 10th, 2017, 21:15:49
Reply: 30
both finished ready to paint
Posted by: Goff_Allen Posted on: January 15th, 2017, 21:43:06
Reply: 31
This is the welder i used for welding the bottom arms and also the welding rods , Low hydrogen 7016 or you can used 7018 , painted a few more parts and had them in fron of the log burner to bake awhile , my wife looked but never commented !!!!!!
Posted by: Goff_Allen Posted on: January 15th, 2017, 21:44:07
Reply: 32
Cherry red
Posted by: Goff_Allen Posted on: January 15th, 2017, 21:45:02
Reply: 33
welding rods
Posted by: Goff_Allen Posted on: January 15th, 2017, 21:47:20
Reply: 34
painted parts
Posted by: Goff_Allen Posted on: February 13th, 2017, 20:39:12
Reply: 35
I got a bit more done , Fitted new roller bearings in the top arms using a long bolt and some wide wasers, Assembled and painted the Discs, Calipers warming up ready to paint and Shock absorber brackets de-rusted and painted.
Posted by: Goff_Allen Posted on: February 13th, 2017, 20:42:10
Reply: 36
top arm
Posted by: Goff_Allen Posted on: February 13th, 2017, 20:43:45
Reply: 37
top arm
Posted by: Goff_Allen Posted on: February 13th, 2017, 20:49:20
Reply: 38
new discs
Posted by: Goff_Allen Posted on: February 13th, 2017, 20:49:51
Reply: 39
warming up
Posted by: Goff_Allen Posted on: February 13th, 2017, 20:50:27
Reply: 40
undercoat
Posted by: Goff_Allen Posted on: February 15th, 2017, 20:36:10
Reply: 41
I got the calipers and Steering rack painted today , Sprayed them as the calipers are to fiddly to brush , You get more paint on your hands and know way of holding them really.
Posted by: Goff_Allen Posted on: February 15th, 2017, 20:37:48
Reply: 42
steering rack
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:38:58
Reply: 43
Weather was a bit warmer so i got to grinding out the Jelcoat cracks on the roof , Some are cracks , Some are the gelcoat lifting , Looks like someone as attacked the gelcoat with one of those Gouging chisels and it as just started to lift !!!!!!!!! Strange !!!! , I made a couple of inquires and was told to paint first coat with Mastic Polyester Spray Filler !!!!!!    I got the body outside today on its side to have a look underneath at the damage or repairs that it needs , Not to bad really , For some reason they have filled the front subframe floor mounts ???? ,I removed a couple of bits of wood that was poorly glassed over, Going to trial fit the front subframe to see if anything is wrong!!! ,Rear arches are a bit rusty but i reckon i can just repair them after removing some matting and grinding away the rusty part, A few photo's added  , My wife say's i am crackers , Ha Ha . Maybe she is right ????
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:41:39
Reply: 44
Roof , Look like it as got woodworm
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:43:18
Reply: 45
Polyester filler Spray filler for the first coat !!!
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:44:22
Reply: 46
on its side
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:46:19
Reply: 47
Subframe mounts
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:49:35
Reply: 48
mountings
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:51:08
Reply: 49
mountings
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:51:42
Reply: 50
mountings
Posted by: Goff_Allen Posted on: February 18th, 2017, 20:53:52
Reply: 51
inner wheel arch ready for glassing over as the fiber glass was not attached, just laid over gel coat and not ruffed up !!!!
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:23:53
Reply: 52
More work on the body , Ruffed up the surface for a couple of layers of matting in the floor pans , Removed two rusty bits of flat bar that had been poorly glassed over in the rear seat pan area , Removed the rusty front floor subframe mountings and replaced with stainless steel , Also removed fibreglass as the mounting were way out and repositioned them using the front subframe as a jig ,
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:24:59
Reply: 53
floor pans
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:27:48
Reply: 54
floor mountings
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:29:20
Reply: 55
rotten floor mounting
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:31:35
Reply: 56
two layers of fibre glass ,
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:33:07
Reply: 57
Fibre glass cut away for new mountings
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:34:15
Reply: 58
Subframe as a jig for the floor mountings
Posted by: Goff_Allen Posted on: February 26th, 2017, 21:35:22
Reply: 59
New Stainless steel mountings ready to glass over.
Posted by: mike brown Posted on: February 26th, 2017, 21:39:02
Reply: 60
Great progress keep it coming.
Posted by: Goff_Allen Posted on: February 27th, 2017, 08:50:54
Reply: 61
Quoted from mike brown, posted February 26th, 2017, 21:39:02 at here
Thanks Mike,
Question- This body as no wood running the length of the cills , Do i need to fit wood or will it be OK, , When i collected it from Richard he said it was very light so could have been a racing shell,
Thanks
Goff
Posted by: mike brown Posted on: February 27th, 2017, 09:16:46
Reply: 62
The cills are a fibreglass box section made up of the shells exterior and an internal section glassed into the shell. The wood (or sometimes cardboard  in mini marcos) is only there as a former for the fibreglass it has little structural property's. If you are concerned about stiffness in this area just add a couple of layers of glass along the internal section.
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:03:58
Reply: 63
Got a bit more finished , Glassed over the floor mountings , Made good outside also and a couple of polyester rods replacing the rotten tube in the foot wells, also fitted two stainless plates with nuts welded on for the subframe front mountings , removed the fibreglass from the rear of the car as it had been poorly glassed over , next job is to add another layer and fill in the rear light holes also the rear skirt needs some work , started painting underneath , Having a change from the grinding dust .
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:04:31
Reply: 64
floor
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:06:18
Reply: 65
front mounting plates
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:11:01
Reply: 66
glassed over front mounting
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:11:32
Reply: 67
front mounting
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:12:26
Reply: 68
a bit of paint
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:13:13
Reply: 69
i need to fill these holes in soon.
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:14:15
Reply: 70
Quoted from mike brown, posted February 27th, 2017, 09:16:46 at here
Mike i will leave them as they are , Thanks
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:20:32
Reply: 71
old mounting removed and a gap to fill in
Posted by: Goff_Allen Posted on: March 2nd, 2017, 21:20:59
Reply: 72
gap to fill in
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:33:54
Reply: 73
I am back after holiday and a bit of time off , first all i am undoing what i thought was right the first time round , Let me explain a bit and hopefully the photo's should tell the story , Right This shell came with  out a rear subrame fitted,Various hole cut out of the shell around the rear subframe !!!!!! Hah i thought i fill them with fibreglass ,MISTAKE , They were cut out to clear the subframe , What i ended up doing  was cutting the suframe and fibreglass and filling in again, its done now and all underneath painted, subfame fitted with the brake ,fuel and battery lines connected ,just got to fit shocks ,cables and rear pipes
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:36:42
Reply: 74
cut the battery box
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:41:51
Reply: 75
Cut the subframe
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:42:31
Reply: 76
and the inside
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:44:44
Reply: 77
and bent the other side
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:45:59
Reply: 78
no hole for the remote???
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:49:17
Reply: 79
Ready at last
Posted by: Goff_Allen Posted on: May 20th, 2017, 20:51:52
Reply: 80
Fitted subframe
Posted by: mike brown Posted on: May 21st, 2017, 07:34:34
Reply: 81
Look good geoff.
Posted by: Goff_Allen Posted on: January 17th, 2018, 20:39:32
Reply: 82
I am back again , After a short illness and taking it easy while i recovered, i did not do much all summer and most of the autumn , I discovered that this shell as a some major work done but not properly !!!! , Yes more set back , Walked round and round taking measurements come to the conclusion it as had top half on a bottom half , after i fitted the front subframe , the gap on wheel arch was about 11/2 more than the other , if i level them them up the car was leaning by same amount ,Come to the  conclusion that it was about 25 mm OUT , I fell out with the car !!! after a couple of months pondering what to do i decided to cut across the fire wall above the front cross member , along the inner wing , down the inner wheel arch and through the door frame just below the bottom hinge on the passenger side, Placed a strut in the door frame and jacked it up , moving it about 20mm , The photo's maybe tell it better , put the subframe back on and did a bit more jacking around the front , Finally got it near enough ,Then fibreglass and let it stand a couple of days before i removed the struts , Next still plenty of work to finish of in the engine bay , filling sanding ect , also start building the engine .
Posted by: Goff_Allen Posted on: January 17th, 2018, 20:41:55
Reply: 83
Cut firewall behind and down the inner wheel arch
Posted by: Goff_Allen Posted on: January 17th, 2018, 20:42:41
Reply: 84
door pillar
Posted by: Goff_Allen Posted on: January 17th, 2018, 20:53:19
Reply: 85
Looking in the engine bay why did i not notice this , look at the bulkhead firewall , off side is right , nearside is 20 mm smaller , measure from the scuttle to the cross member on both sides 20 mm difference and it had hole for the subframe bolt drilled through the gutter were the bonnet fits , Love is blind.
Posted by: Graham_Thurston Posted on: January 19th, 2018, 09:55:53
Reply: 86
Having gone through a similar stage to Goff, I reached the conclusion that there was not a lot of accuracy infitting the floor moulding into the top. The rear subframe could only be fitted by stressing the rubber mounts, so with poly bushes the whole lot had to be shoved over a bit. The front required similar treatment, but the important thing was to get both subframes level. The rear arches were also a pain.
Having replaced all the metal, I have tried to get metal to metal contact where the bolts go through, rather than bolting through a sandwich of GRP, by bonding in a stainless washer to the shell. But trying to establish a datum line on the shell is mysterious. Even the rear panel is asymmetric.
So you have my sympathy, and best wishes for the eventual solution
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:14:09
Reply: 87
Had a good week ,Been building the engine up , Its a bitsa engine & gearbox Rod change -1300 Pre +  k from a scrap yard in Doncaster  , The diff pin gear came loose and smashed the geabox casing + planet gears £120  , Block rebored +10 ,cam bearings fitted and decked about 6 mm , Crankshaft from South Africa £200 , regound 10 mains , 10 big ends , Its works out just under 1100 cc , Head from Manchester , 1300 GT off ebay for £40 ,listed as a bog standard 1300 though it needed a full recon including exhaust valves , Mini spares Evo 2 cam , Gearbox came from Nottingham  for £50 ,standard from a Mini 1000 last of the remotes , Stripped down all new bearings , Syncros, second gear and a minispares cross pin diff   Should make a nice fast road engine , Rest of the bits from a couple of engines.
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:23:10
Reply: 88
SA crankshaft
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:30:17
Reply: 89
Engine
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:31:10
Reply: 90
Engine
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:31:45
Reply: 91
Head
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:35:14
Reply: 92
Head , I had to fit the small bore push rods as they are shorter and head studs as they threaded longer , Also drilled and tapped the block for extra two studs.
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:44:24
Reply: 93
Nearly built up , Fitted later type out put shafts to the gearbox
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:45:25
Reply: 94
Lot of bits from other engines
Posted by: Goff_Allen Posted on: January 28th, 2018, 16:50:07
Reply: 95
Engine Block
Posted by: mike brown Posted on: January 28th, 2018, 17:20:39
Reply: 96
You may need to change the rocker box my mk2 was tight with a standard tin one.
Posted by: Goff_Allen Posted on: January 29th, 2018, 19:30:24
Reply: 97
Quoted from mike brown, posted January 28th, 2018, 17:20:39 at here
Yes mike , it does look to big ,When the engine is fitted i will see how it goes ,not going to alter the bonnet ,Maybe cut it down and re-weld it is an option.
Posted by: Goff_Allen Posted on: January 29th, 2018, 19:35:54
Reply: 98
Quoted from Goff_Allen, posted January 28th, 2018, 16:14:09 at here
Graham i am sure this shell has a had a repair done after it left the factory , I am going to remove the rear subframe and move it over , re-drill the holes.
Posted by: Goff_Allen Posted on: February 3rd, 2018, 20:38:47
Reply: 99
Here is the back view of the  engine showing pot drives i replaced the cross joints , Bought twin 11/4 SU from ebay £80 , came of a 998 cooper according to the number on the manifold ,good condition needing the rubber mounts between bowls and body , Spindles OK ,gave them a good clean and polished the dash pots and air filters , Started to make a dash board as this one was missing , photo's tell the story.
Posted by: Goff_Allen Posted on: February 3rd, 2018, 20:39:24
Reply: 100
carbs
Posted by: Goff_Allen Posted on: February 3rd, 2018, 20:39:52
Reply: 101
carbs
Posted by: Goff_Allen Posted on: February 3rd, 2018, 20:40:33
Reply: 102
dash missing
Posted by: Goff_Allen Posted on: February 3rd, 2018, 20:41:25
Reply: 103
made a dash but still needs finishing
Posted by: Neil KilBane Posted on: February 5th, 2018, 09:08:27
Reply: 104
Looking good Goff, not too bad a price for the carbs either.
Posted by: Goff_Allen Posted on: February 5th, 2018, 19:47:59
Reply: 105
Quoted from Neil KilBane, posted February 5th, 2018, 09:08:27 at here
Thanks Neil , Its giving me some heartache this body shell , Today taken the rear subframe off and re-drilled the mounting points as one wheel was sticking out around 12mm further than the other one Grrrrrrrr  and bloody cold working outside , Carbs good buy i have been watching ebay for about 4 months , Prices can vary considerable ,These were pretty local also and not worn on the spindles is a bonus.
Neil are you coming over to Blyton this year ?????
Posted by: Neil KilBane Posted on: February 6th, 2018, 09:37:47
Reply: 106
I won't make Blyton, the dates don't suit this year, I'm heading to Portugal for the IMM in May, can't afford to do both events unfortunately :(
Posted by: Goff_Allen Posted on: February 10th, 2018, 19:37:06
Reply: 107
Gearbox stripped down and washed ,On the wife's worktop for inspection , She wasn't to pleased about it , this was the end of November just found photo ,It needed new layshaft, 4 syncros, all the bearings and a second gear , Bloody expensive to recondition.
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:19:27
Reply: 108
OK ,A bit of a update .
Engine is in , What i did is cranked it over without plugs until i got oil pressure , 75 psi cranking " Great ", connected it all up ,fired up straight away ,Had to cut the front wheel arches as the tyres were catching both fronts on lock , fibre glassed and filled in , looks good now , still doing the body BUT getting close for first coat of polyester spray filler , photos attached , as you can see plenty of dust
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:22:02
Reply: 109
Fitting engine
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:30:51
Reply: 110
its in
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:32:06
Reply: 111
engine
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:38:05
Reply: 112
Plenty of dust
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:38:33
Reply: 113
More dust
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:39:14
Reply: 114
rear light filled in
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:39:56
Reply: 115
Fitted a heater
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:42:33
Reply: 116
Nice rad
Posted by: Goff_Allen Posted on: February 23rd, 2019, 18:44:34
Reply: 117
Heater. another update soon
Posted by: Goff_Allen Posted on: March 2nd, 2019, 16:10:31
Reply: 118
update - Body is just about ready for first coat , BUT i thought i would offer the windscreen up to see if it would fit , NOPE it needs either the glass grinding and/or the body modifying , I think ill alter the body , on the nearside bottom screen pillar it needs some taking off , same pillar at the top it needs biulding up , photo's will tell the story .
Posted by: Goff_Allen Posted on: March 2nd, 2019, 16:12:52
Reply: 119
nearside bottom pillar
Posted by: Goff_Allen Posted on: March 2nd, 2019, 16:16:43
Reply: 120
windscreen
Posted by: Goff_Allen Posted on: March 30th, 2019, 19:24:14
Reply: 121
Another update , got the windscreen opening sorting , got the sprayfiller on and the first undercoat , loads of pin holes filled in , It looks like a Cow instead of a pig at moment , got to sand it flat then a couple of more undercoats flat again and top coat . Got the seats , they are Cobra Cub with the Mini Jem logo stiched in the back , similar colour to the MK2 jem that i have .
Posted by: Goff_Allen Posted on: March 30th, 2019, 19:26:07
Reply: 122
first coat
Posted by: Goff_Allen Posted on: March 30th, 2019, 19:27:18
Reply: 123
under coat
Posted by: Goff_Allen Posted on: March 30th, 2019, 19:34:10
Reply: 124
The cow
Posted by: Goff_Allen Posted on: March 30th, 2019, 19:34:54
Reply: 125
and again
Posted by: Goff_Allen Posted on: March 30th, 2019, 19:47:00
Reply: 126
seat
Posted by: Goff_Allen Posted on: March 30th, 2019, 19:47:34
Reply: 127
seat
Posted by: Gary Marlow Posted on: March 31st, 2019, 19:14:23
Reply: 128
Looking good there Goff.
Was the undercoat home sprayed with a compressor?
Hopefully catch up at Blyton again this year, you bring the tea and I'll bring the biscuits!
Gary
Posted by: Goff_Allen Posted on: April 1st, 2019, 20:00:44
Reply: 129
Quoted from Gary Marlow, posted March 31st, 2019, 19:14:23 at here
Gary
Yes home compressor ,its as old as me 70 + , i have had since i was 19 , sprayed my first Jem with it in 1968.
Yes see you at Blyton Gary , Ill bring those 1275 side stripes that i promised you and the tea
Goff
Posted by: Neil KilBane Posted on: April 2nd, 2019, 07:42:20
Reply: 130
Great work as usual Goff, nice set of wheels too :)
Posted by: Goff_Allen Posted on: April 2nd, 2019, 16:04:05
Reply: 131
Quoted from Neil KilBane, posted April 2nd, 2019, 07:42:20 at here
JAPearce wheels , exspensive now Neil , Are you heading over to Blyton  ???
Posted by: Neil KilBane Posted on: April 3rd, 2019, 07:22:46
Reply: 132
Not this year Goff, the dates don't work out for me I'm afraid.
Posted by: Gary Marlow Posted on: April 3rd, 2019, 14:00:27
Reply: 133
Wish I knew that you had JA Pearce wheels on your car Goff, I only recently got rid of 3 centre caps  as in last week! - Had I known you had these on yours I'd have given them to you if you needed them.
Posted by: Simon_Pike Posted on: April 10th, 2019, 10:09:35
Reply: 134
hi goff,
       would you consider doing some bodywork on my jem
cheers simon
Posted by: Goff_Allen Posted on: April 24th, 2019, 20:03:26
Reply: 135
Quoted from Gary Marlow, posted April 3rd, 2019, 14:00:27 at here
Story of my life that Gary , See you at Blyton
Posted by: Goff_Allen Posted on: April 24th, 2019, 20:04:56
Reply: 136
Quoted from Simon_Pike, posted April 10th, 2019, 10:09:35 at here
hi goff,
cheers simon
I seen its for sale Simon , NO thanks , had enough with this one
Posted by: Goff_Allen Posted on: April 24th, 2019, 20:10:56
Reply: 137
Finally got the top coats on after a couple more under coats , filling pin holes ect , its not perfect BUT the conditions are not either !!! some photo's added
Posted by: Goff_Allen Posted on: April 24th, 2019, 20:12:55
Reply: 138
Roof painted
Posted by: Goff_Allen Posted on: April 24th, 2019, 20:13:31
Reply: 139
car painted
Posted by: Goff_Allen Posted on: April 24th, 2019, 20:14:43
Reply: 140
and again
Posted by: Goff_Allen Posted on: April 24th, 2019, 20:20:19
Reply: 141
this is the compressor Gary , I have had it since i was 19 , painted my first Jem in 1968, second hand when i bought it. god knows how old it is ???.
Posted by: Gary Marlow Posted on: April 24th, 2019, 21:11:49
Reply: 142
Looks super paint Goff and the compressor too!
Have one like that - got it off a neighbour who built it - seems to work ok but will be interesting to see how it really goes when I attempt to paint my Mk3 later in the year.
Catch up in a couple of weeks at Blyton.
Cheers Gary
Posted by: Goff_Allen Posted on: May 20th, 2019, 19:25:27
Reply: 143
Getting close now , Carpets ,headling , seats fitted , wiring up the dash back lights work , head side work , wipers work , just a bit more wiring to do this week then fit the windows , just got the two doors & bonnet to finish , check everything over , before i take it for a mot ,
Posted by: Goff_Allen Posted on: May 20th, 2019, 19:25:56
Reply: 144
headling
Posted by: Goff_Allen Posted on: May 20th, 2019, 19:26:23
Reply: 145
seats
Posted by: Goff_Allen Posted on: May 20th, 2019, 19:28:49
Reply: 146
dash wiring
Posted by: Goff_Allen Posted on: May 20th, 2019, 19:29:51
Reply: 147
back lights
Posted by: Goff_Allen Posted on: May 20th, 2019, 19:30:33
Reply: 148
front view
Posted by: Craig Smith Posted on: May 29th, 2019, 14:31:19
Reply: 149
Coming along very nicely Goff :-)
Posted by: Goff_Allen Posted on: May 31st, 2019, 19:57:25
Reply: 150
Just a couple more jobs done , cut from a sheet of 5mm perpsex rear screen and fitted , dash all fitted and working ok .
Posted by: Goff_Allen Posted on: May 31st, 2019, 19:58:23
Reply: 151
dash fitted
Posted by: Craig Smith Posted on: June 3rd, 2019, 06:21:41
Reply: 152
Very nice mate.  I've got the same Savage switches :-)
Posted by: Goff_Allen Posted on: June 29th, 2019, 20:01:31
Reply: 153
Had a good productive couple of weeks , doors and bonnet spray filled , undercoat and top coat finished , not perfect but i am happy with them , bonnet fitted today , drivers door also fitted and passenger very close , loads of snaging jobs also completed , i think just the side windows to fit , drivers/ passenger windows , passenger door , check everthing over then take it for its MOT next week
Posted by: Goff_Allen Posted on: June 29th, 2019, 20:03:30
Reply: 154
top coat baking in the sun on Wednesday afternoon , i new the dustbin would come in handy.
Posted by: Goff_Allen Posted on: June 29th, 2019, 20:04:51
Reply: 155
Aliminium wheel arches fitted made by Alloy Racing Fabrications , bonnet catches fitted.
Posted by: Goff_Allen Posted on: June 29th, 2019, 20:08:50
Reply: 156
another view
Posted by: Goff_Allen Posted on: June 29th, 2019, 20:09:34
Reply: 157
drivers door fitted
Posted by: Goff_Allen Posted on: June 29th, 2019, 20:10:38
Reply: 158
happy with todays work
Posted by: Allan_Scott Posted on: June 29th, 2019, 21:13:47
Reply: 159
Hi Goff Jem looking good hope to see it out soon , Maybe at harewood in August
Posted by: Craig Smith Posted on: July 1st, 2019, 22:24:31
Reply: 160
Great progress Goff.    You are putting me to shame!
Good luck with the MOT.
Posted by: Goff_Allen Posted on: July 20th, 2019, 17:16:43
Reply: 161
Well its just about finished , are they ever finished !!!! always something to do on these old cars , OK door perspex fitted , chrome catches also fitted , just had to machine down the the buttons and screws that hold them in because the perspex is 3mm , i made some stainless plates to fit opposite the window catches that cover the gasket up nicely , door mirrors fitted , just some interior to finish off , paint the wheels and centre caps , drove it for its MOT 10 miles and 10 miles back  , passed OK , just a weep on a union that needed nipping up , on the way back went on to 3 cylinders about 2 miles from home so i kept going , it turned to be a spark plug lead had come off from the distributer cap , easy fix , filled all the forms in and sent last Thursday to DVLA , now waiting for a age related plate then away we go , thanks to Roger Garland and Craig Smith for assisting with photo's , forms ect .
Posted by: Goff_Allen Posted on: July 20th, 2019, 17:17:55
Reply: 162
Headlamp covers fitted , these are from a VDP 1100
Posted by: Goff_Allen Posted on: July 20th, 2019, 17:18:44
Reply: 163
Persex and door catches fitted
Posted by: Goff_Allen Posted on: July 20th, 2019, 17:20:05
Reply: 164
stainless plates fitted to outside of window catches.
Posted by: Goff_Allen Posted on: July 20th, 2019, 17:23:26
Reply: 165
door mirrors
Posted by: Goff_Allen Posted on: July 20th, 2019, 17:27:53
Reply: 166
Quoted from Allan_Scott, posted June 29th, 2019, 21:13:47 at here
Don't know if i will be there Alan , if i am it wont be in this one .
Posted by: Goff_Allen Posted on: July 20th, 2019, 17:35:14
Reply: 167
Mike the Oselli rocker box is ok , i had around 6mm machined from the top of the block so i guess that's what gave the clearance .
» Print page generated: August 10th, 2022, 17:56:35 «
