MM Rocker Cover Badges (currently 7,020 views) |
Posted on: January 9th, 2007, 20:37:40 Attachment: rockerbox2.gif - 3.82 KB (4372 views) |
I'm about to order some Mini Marcos rocker cover badges for the normal A-Series rocker cover. The proposed design is shown below but I would welcome any comments before I go ahead, such as:
Would you buy one? The price would probably be £2.50. Is the colour OK? It will be anodised aluminium so silvery letters on blue. Should the background be oval as on the MM logo? I don't think it's as good. Do you want rivet holes? The proposal is to use a self-adhesive, temperature resistant backing.
Doing two colours will be more expensive, as will a small quantity so Jem badges won't be feasible. The badges will have other applications, and can be stuck on the front of alloy rocker covers.
Richard |
Lee Matthews |
Posted on: January 9th, 2007, 20:51:04 |
Hi Richard the rocker cover is a good idea I would not change the design and would use self -adhesive so yes please . |
Reply: 1 - 36 |
Roger Garland |
Posted on: January 10th, 2007, 09:28:24 |
Hi Richard
I really like the idea, but I'm not sure about the blue
Roger |
Reply: 2 - 36 |
Joost van Dien |
Posted on: January 10th, 2007, 12:01:55 |
hello,
Good idea!! The disign is good i think, but is it posible to put the Mini Marcos badge logo on it?
Cheers, Joost |
Reply: 3 - 36 |
Posted on: January 10th, 2007, 12:52:08 |
I thought about that, and tried a number of designs before I settled on the above. The badges is 100mm x 25mm so the logo would have to be very small to fit on. Also the logo is red, white and blue so unless it was just printed in one colour it would be much more expensive. I wanted the lettering to be very visible when you look at the engine, so I decided to go for a simple design based on the inside bit of the logo. The blue rectangle looked better than an oval. Anyway we know what the 'blue oval' means (a four-letter word beginning with F). |
Reply: 4 - 36 |
Tertius van Zyl |
Posted on: January 10th, 2007, 18:34:50 |
Reputation: -1 (tot: -1) |
Like the idea Richard. Measured the space on my rocker cover and it would appear that you could go up to 30mm wide which will give you a bit more space. Cost aside, I would quite like the diagonal red flash if it could be incorporated. |
Reply: 5 - 36 |
Ron Boy |
Posted on: January 10th, 2007, 19:30:39 |
Hello richard, it's a good idea ....i suggest it will be better oval like the real logo |
Reply: 6 - 36 |
Joost van Dien |
Posted on: January 10th, 2007, 20:54:30 |
Hello,
An oval would be nice, more the looks of the MM badge it self.
Cheers,
Joost |
Reply: 7 - 36 |
Posted on: January 10th, 2007, 21:52:55 Attachment: mmoval.gif - 2.76 KB (4373 views) |
This is the oval version without the red flash. It's much harder to get the lettering looking good. |
Reply: 8 - 36 |
Ron Boy |
Posted on: January 11th, 2007, 10:34:29 Attachment: rocker_1.jpg - 25.82 KB (4363 views) |
Hi Richard, Here one whith a good lettering
I can send you better ones if you need but to see on the forum i can only put Jpeg ones, and it not looks very good in the blue.
But you can modify easily whith Paint |
| Last modified January 11th, 2007, 10:37:24 by Ron Boy |
Reply: 9 - 36 |
Posted on: January 11th, 2007, 11:37:35 |
How about as above with a pinstripe border ? |
Reply: 10 - 36 |
Ron Boy |
Posted on: January 11th, 2007, 16:44:29 Attachment: rocker_2.jpg - 31.67 KB (4367 views) |
something like that Neil ?
Maybe too hard to produce ?
Just tell me , i can draw what you want |
| Last modified January 11th, 2007, 16:45:33 by Ron Boy |
Reply: 11 - 36 |
Tertius van Zyl |
Posted on: January 11th, 2007, 17:45:34 |
Like it Robow! Still think the red flash would be nice - also would fill up some of the white space on the left and right. |
Reply: 12 - 36 |
Ron Boy |
Posted on: January 11th, 2007, 18:11:59 Attachment: rocker_3.jpg - 32.60 KB (4366 views) |
looks good too Tertius ! |
Reply: 13 - 36 |
Joost van Dien |
Posted on: January 11th, 2007, 18:42:36 |
hello,
Thats a very nice badge!!! But.. if u make ur own badge u can easly copy the orignal MM badge .
Cheers,
Joost |
Reply: 14 - 36 |
