MM Rocker Cover Badges (currently 8,671 views) |
Posted on: January 11th, 2007, 19:29:43 |
Me likey.  |
Reply: 15 - 36 |
Tom Springer |
Posted on: January 11th, 2007, 20:22:27 |
Me likey,too... I love it when a plan comes together. One of those would look great on my newly polished rocker cover. Tom |
Reply: 16 - 36 |
Tertius van Zyl |
Posted on: January 12th, 2007, 18:24:26 |
Reputation: -1 (tot: -1) |
Robow the red flash addition looks perfect. What would that cost Richard?? |
Reply: 17 - 36 |
Posted on: January 12th, 2007, 19:46:19
I think the red flash makes it. I'll get a price for two colours. However I would like to keep the lettering more like the official badge, which is more square and the top of the MINI is flat. Btw, you can post GIF files as well as JPEGs. |
Reply: 18 - 36 |
Ron Boy |
Posted on: January 12th, 2007, 20:35:45
The real marcoslettering do not exist, i can't change it if i don't know exactlywhat it is, this one is the one whitch look nearest |
Reply: 19 - 36 |
Chris Pearson |
Posted on: January 12th, 2007, 23:49:40 |
What are you using to do these logos in if you don't mind me asking? |
Reply: 20 - 36 |
Ron Boy |
Posted on: January 13th, 2007, 09:49:26 |
I'm sorry i don't really understand your question Chris ... or it's just a lak in your sentence punctuation ? If this is the software i use that you want to know, it's simply PowerPoint by Micro. Office but many others could make it too ! |
Reply: 21 - 36 |
Chris Pearson |
Posted on: January 13th, 2007, 10:32:40 |
Yes it was the software. Sorry it was a bit odd grammar, I come from geek land where the software bit is implied! |
Reply: 22 - 36 |
Ron Boy |
Posted on: January 13th, 2007, 12:19:00
other suggestion Richard ?
don't worry, we go to find one good |
Reply: 23 - 36 |
Posted on: January 13th, 2007, 12:44:53 |
Add a thin black line to the straight edges of the red stripe. Gives it more definition. |
Reply: 24 - 36 |
Posted on: January 13th, 2007, 16:19:08 |
Thanks Robow - that's excellent! A black line isn't on because each additional colour increases the price which means more outlay and fewer sold. |
Reply: 25 - 36 |
Posted on: January 13th, 2007, 16:35:28 |
Quoted from Ron Boy, posted January 13th, 2007, 09:49:26 at here |
My originals are in Draw which is easily scaleable and smooth. The problem was with converting them to bitmaps using a screenshot, and then to 8bpp GIFs which looked a bit rough. I can convert them to JPEGs with antialiased lines which makes the end result much smoother. |
Reply: 26 - 36 |
Graham Cricket |
Posted on: January 14th, 2007, 09:45:00 |
Badge looks good, I will have one if it helps the cause.
Without opening another can of worms I was thinking of having the new design front number plate incorporating a MM badge in the Blue/Flag area, where the GB is normally seen, as I presume the normal number plate manufacturers at the shows do not have MM as an option when making the plates
Any experience or ideas on this subject
Graham |
Last modified January 14th, 2007, 09:47:03 by Graham Cricket |
Reply: 27 - 36 |
Posted on: January 14th, 2007, 16:01:08 |
I think you'd have to get them to do a special. I haven't tried it - but one thing at a time!
Richard |
Reply: 28 - 36 |
Grant Wilson |
Posted on: January 17th, 2007, 22:52:28 |
LeMans -- 2016
looks great in oval with the red stripe, count me in whatever you decide.grant |
Reply: 29 - 36 |
