Very busy wit maintenance (currently 3,113 views) |
Gert-Jan Westerveld |
Posted on: January 9th, 2007, 21:12:44 |
As the title says very busy wit maintenance of the Mini Marcos.
First of is the heather it was leaking. I let it repair, and the radiator was not ad his best. So I let it also repair.
I also want to replace the water hoses with samco sport hoses.
Next up is the cylinder head, the valve seals are gone so I have to put in new one's. The exhaust, will be replaced. I am going fore a full system maniflow . It will cost something, but I recon you'll get something.
Rebuild engine 1312CC .  | Last modified February 24th, 2007, 16:25:06 by Gert-Jan Westerveld |
Posted on: January 27th, 2007, 19:24:10 |
To day start it with the cylinder head, I did not get very far > . I need to remove the exhaust first. For this I need to build a ramp or something.
Reply: 1 - 34 |
Posted on: January 28th, 2007, 20:00:11 |
What sort of manifold has it got? If it's a cast iron one you should be able to remove the clamp, disconnect the pipe from the transmission so that it drops down a bit and remove the manifold. If it's an lcb exhaust it should come out through the top but you'll need to take the exhaust system off first, including the Y-piece. So you'll need a jack and axle stands at least. It is easier to remove the exhaust system before you undo the manifold studs! |
Reply: 2 - 34 |
Posted on: February 24th, 2007, 16:21:32 |
For this I use a little ramp.
So that the exhaust can be removed.
Den there was enough clearance to remove the cylinder head.
A little jiggling
And there is the whole exhaust.
There is the trouble oil traces, on the inlet valves. So we need to chance the valve stem seals
Rebuild engine 1312CC .  | Last modified February 24th, 2007, 16:52:09 by Gert-Jan Westerveld |
Reply: 3 - 34 |
Posted on: February 28th, 2007, 20:26:17 |
Hello very busy; little problem wit valve seals, the old one are of nylon and the new are of rubber but thy won't stay on.
I haven't seen these types before.
Any one!!! Help! ! !
Rebuild engine 1312CC .  | Last modified February 28th, 2007, 20:27:45 by Gert-Jan Westerveld |
Reply: 4 - 34 |
Posted on: March 4th, 2007, 14:55:18 |
Reply: 5 - 34 |
Posted on: March 17th, 2007, 17:04:36 |
Today was time fore grinding the valves.
A fresh coat of paint make's a difference. |
Rebuild engine 1312CC .  | Last modified March 17th, 2007, 19:03:14 by Gert-Jan Westerveld |
Reply: 6 - 34 |
Alex Gibson |
Posted on: March 17th, 2007, 20:58:16 |
That radiator looks very small! Whats it from? |
Inside every older person is a younger person wondering what the hell happened!!!! |
Reply: 7 - 34 |
Posted on: March 18th, 2007, 19:49:04 |
I am told, that it was from the italian mini innocenti. I fits very snug, in the front. |
Reply: 8 - 34 |
Posted on: March 25th, 2007, 16:53:40 |
Little big problem, whit the new valve seals. When I wanted to put them on, they tore up. Something went terribly wrong.
this is how it shut be.
Reply: 9 - 34 |
Bent Larsen |
Posted on: March 26th, 2007, 06:52:56 |
Hi There are normally a grove in the valve guides for the rubber type.
Bent |
Reply: 10 - 34 |
Posted on: March 26th, 2007, 09:40:11 |
Yes I was thinking that. They're not the valve guides I'm familiar with, or the seals for that matter. I haven't seen valve seals with metal collars before. They're usually black rubber with a spring round the neck for the inlet valves or small O-rings for the exhausts. You really only need to control the oil going down the inlet valve stems, and limit the amount of exhaust blowing out through the exhausts. |
Last modified March 26th, 2007, 09:40:52 by admin |
Reply: 11 - 34 |
Bent Larsen |
Posted on: March 26th, 2007, 13:37:13 |
Mercedes use that kind, but the are hard on the valves |
Reply: 12 - 34 |
Posted on: April 28th, 2007, 20:17:11 |
Sorry fore de late reaction, the reason is I was on a holiday . So the latest update is as follows: My cylinder head is ready to be fitted / mounted . I do not now which is the correct word.
Reply: 13 - 34 |
Posted on: May 5th, 2007, 18:34:57 |
This weekend I am again working on my Marcos, I came across the problem of a sticky clutch. Also the hose from the slave to the pipeline was broken, this I knew. I have replaced this with a metal wired one.
While dismantling the clutch hose I had to remove the top engine stabilizer, here I noticed the rubber bushes where in bad shape. These are going to be replaced with polystyrene bushes.
Reply: 14 - 34 |
