  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  new to the forums
0 Members Browsing (43 Guests)
  Author    new to the forums  (currently 789 views)
Tony Shadforth
Posted on: February 2nd, 2007, 11:54:09 Quote Report to Moderator
hi peeps
as you can gess im new to the forums just need a little help with 1 of the mini marcos ive got
according to the log ive got for the car its a 1964 reg DBV272B
just need a little help in getting its true age will get the brass plate number and photos over the weeked and post them
all i can tell you at the mo is that its built out of alot of 60's componets
10 inch magnesium light weight wheels
7/half inch brakes plus calipers
copper brake servo
front mounted oil cooler in the lower front panel(factory cut hole not home made mod)
morris minor front side lamps+indercators
cortina mk1 rear lights
hydroelastic suspension(very odd that wont be staying)
lots of dust and cobwebs
quick shifts
vynal roof
ive owend the car for 3 years now it still does run this car is also never been painted still in original colors although the gel coat is full of cracks
any help would be helpfull
cheers tony
Last modified February 3rd, 2007, 02:37:17 by Tony Shadforth
Pete Crudgington
Posted on: February 2nd, 2007, 17:21:10 Quote Report to Moderator
Tony,
Brass plate indicates that is is made by marcos mut manufacture is likely to be 1966 or later (very few cars were made in 1965).  The number on the brass plate will confirm better the year of manufacture.  The morris minor round front indicators indicate that it is probably a Mk3 or possibly even a Mk4 and will date from 1967 or later but assembled from the engine etc from the 1964 car.
The fact that it is still get coat may indicate that it is a later car, send in the photos of let us have the number.  If it is 7XXX it is a mk 3 and 1968 on if it is 8*** it is a mk4 from 1974 on.  Vynal roof, don't see may of them except on mk4's
Pete
Private Message Reply: 1 - 10
Tony Shadforth
Posted on: February 2nd, 2007, 20:10:48 Quote Report to Moderator
helo just got the plate number it reads
m-a 2s4 s229 751
have some pics will post them tomorow
not very good ones its been lurking at the back of my work shop for 3 years now
Private Message Reply: 2 - 10
Allan Brown
Posted on: February 3rd, 2007, 20:43:09 Quote Report to Moderator
Your car is a mk4. It has a large B pillar behind the door. Not sure about the chassis plate.
Private Message Reply: 3 - 10
Posted on: February 4th, 2007, 12:19:39 Quote Report to Moderator
The chassis plate definitely isn't a Marcos one. The car looks like it's an early Mk.IV because of the polished window frames. D&H used cheap aluminium channel (back-to-back for the quarter lights) and painted it matt black. They also stuck bits of aluminium over the tops of the door mouldings on the outside.
  Private Message Reply: 4 - 10
Tony Shadforth
Posted on: February 6th, 2007, 23:10:43 Quote Report to Moderator
found abit more out about the chassis number
its from the original mini dates and numbers match up
http://joltfreak.tripod.com/id13.html
gonna have a good kuck at the car and see if i can find the marcos body number if it was put on the car
Last modified February 6th, 2007, 23:12:42 by Tony Shadforth
Private Message Reply: 5 - 10
Pete Crudgington
Posted on: February 7th, 2007, 13:21:48 Quote Report to Moderator
Tony,
It is certainly a Mk4 so the very earliest it can be in 1974.
The marcos chassis plate should be in the engine bay and should be a rectangular brass plate if it is made by Marcos or an Aluminium one if a later car made by D&H.
What does the log book say it is? is it still a mini or does it actually say marcos.
As Richard states above it is definatly a Mk 4 but more than likely one made by Marcos.  There are no other chassis numbers apart from this Marcos brass plate on the shells and as they are held on with rivits it may have been taken off.
The brass plate you have has been made up by someone so the chassis number matches the log book I suspect.  Not very legal.
Private Message Reply: 6 - 10
Tony Shadforth
Posted on: February 8th, 2007, 09:19:04 Quote Report to Moderator
the log says its a morris mini
dont know who did what to it and when thats why im hunting infomation on this vehical
as i have two of them it may help me with the other one
details
reg----- Q198RFM
VIN----- SABTVR03933062262
COLOUR ---BLACK{WAS ORIGINALY ORANGE)
THE LOG ON THIS ONE SAYS LEYLAND MINI MARCOS
Private Message Reply: 7 - 10
Nick Harland
Posted on: February 11th, 2007, 01:46:09 Quote Report to Moderator
i must say the vinyl roof looks bit different i like it though
if the car has been made from a mini does that depreciated it as a marcos??
does its value drop what impact does that have??
Private Message Reply: 8 - 10
Nick Evans
Posted on: February 11th, 2007, 11:04:28 Quote Report to Moderator
Quoted from Tony Shadforth, posted February 8th, 2007, 09:19:04 at here
details
reg----- Q198RFM
the one that says mini marcos on it is the correct one for the car, the other log book is just a mini log book, and if you use that numper plate /ID, then you could risk serious consequences if you are pulled by the police.
Private Message Reply: 9 - 10
Tony Shadforth
Posted on: February 11th, 2007, 12:17:30 Quote Report to Moderator
not that worried m8 about the police just yet till the car is restored
the police up here are not that bright
last year they tried to prosicute me for not wearing a seat belt while i was driving an 1958 land rover series 2!!!!(muppets)
gonna conact marcos to see if i can get any info of them(at a price)
Private Message Reply: 10 - 10
Powered by e-blah Platinum 7 Final © 2001-2004   -   February 25th, 2021, 14:27:58
Files opened: 92 | Files closed: 92
