  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Yippeeee I've got myself a MkIV
0 Members Browsing (41 Guests)
Pages: « 1, 2, 3, 4 » : All Reply Recommend Print
  Author    Yippeeee I've got myself a MkIV  (currently 3,087 views)
Posted on: January 9th, 2009, 19:10:35 Quote Report to Moderator
Yes mate I was very surprised just how different the MkIV is compared to the MkIII in many areas.
Still, if it's stiffer it should go around corners better
You have Yahoo email btw.
Private Message Reply: 15 - 50
Posted on: January 9th, 2009, 19:31:31 Quote Report to Moderator
I'm surprised at that. My Mk.IV is definitely more flexible than the Jem (which is more like the Mk.III). It tends to wind itself up first and then go round the corner whereas the Jem does what it's told straight away.
  Private Message Reply: 16 - 50
Joost van Dien
Posted on: January 9th, 2009, 19:35:15 Quote Report to Moderator
Congratz Craig!
cheers
Private Message MSN Reply: 17 - 50
Posted on: July 12th, 2009, 10:14:13 Quote Report to Moderator
The decideldly average British summer has meant that progress on the bodywork has been slower than I would have liked, so yesterday I moved the Marcos to a garage in Stoke.
I've only got the garage for 8 weeks or so, but it should enable me to make some headway, and not have to worry about the weather!
Private Message Reply: 18 - 50
Tim Frankland
Posted on: July 12th, 2009, 14:11:11 Quote Report to Moderator
That looks like a dream garage. Good to see pictures of the progress, good luck with the work!
Private Message Reply: 19 - 50
Joost van Dien
Posted on: July 13th, 2009, 17:08:31 Quote Report to Moderator
Craig,
I noticed that your old mk3 is for sale.
http://www.qmall.nl/brownslane/aangeboden/aangeboden.asp
http://www.minisevenclub.nl/forum/viewtopic.php?f=19&t=41390
Cheers,
Joost
Private Message MSN Reply: 20 - 50
Posted on: July 16th, 2009, 16:50:09 Quote Report to Moderator
Hmmm, no price.  I think I'll stick to the one I've started now
Private Message Reply: 21 - 50
Posted on: July 18th, 2009, 21:56:05 Quote Report to Moderator
Progress!!
Now all I have to do is train Jonathon to run at 70mph whilst holding the new front on!
Many thanks to Alan Brown for supplying me with the front end.
Private Message Reply: 22 - 50
Joost van Dien
Posted on: July 19th, 2009, 16:22:27 Quote Report to Moderator
Way have you grinded the front out? I had the same cracks on my yellow car and you can easily fiberglass it back in place from the inside. Then grind the cracks on the outside en fiberglass that as well. So you can save you frontend for later on!
Private Message MSN Reply: 23 - 50
Allan Brown
Posted on: July 19th, 2009, 19:28:13 Quote Report to Moderator
Glad I could help.
It's looking good.
So it will be ready for the Marcos 50th then
Private Message Reply: 24 - 50
Posted on: July 19th, 2009, 20:00:54 Quote Report to Moderator
Hi Joost,
Unfortunately there was very little fibre glass left, who ever had repaired it previously just used a bucket full of body filler to fill a big hole.  Here is a lump of it after removal..
Quoted Text
Unfortunately not
When's the next big occasion??
Private Message Reply: 25 - 50
Syd Crawford
Posted on: July 19th, 2009, 22:42:56 Quote Report to Moderator
Whoa! Never seen a lump of bog that thick before!
Good to see the progress
Having a nice garage to work in makes a big difference. Love my garage .
Private Message Reply: 26 - 50
Phil Lockett
Posted on: July 20th, 2009, 09:18:03 Quote Report to Moderator
Hey Craig,
Where you have rubbed it diwn on the roof and the rear end it seems to be standard D&H "Instant Fade" Orange gelcoat.
The front seems to be baby blue gelcoat - has it had another front end on it in the past do you think?
1983 GTM Coupe. Powered by Toyota 4A-GE.
Siva Moonbug
Private Message Reply: 27 - 50
Joost van Dien
Posted on: July 21st, 2009, 16:45:26 Quote Report to Moderator
I see why you grinded it out  . yeas that guy had some cash in an bodyfiller-factory xD. Keep up the good work!!
Private Message MSN Reply: 28 - 50
Posted on: July 21st, 2009, 20:43:23 Quote Report to Moderator
Quoted from Phil Lockett, posted July 20th, 2009, 09:18:03 at here
Hey Craig,
No mate, thats yet more filler that had been applied over the damage.
Here it is after sanding it off, and grinding out the cracks..
Last modified July 21st, 2009, 20:49:58 by Craig Smith
Private Message Reply: 29 - 50
Powered by e-blah Platinum 7 Final © 2001-2004   -   May 11th, 2021, 06:32:09
Files opened: 81 | Files closed: 81
