  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  SPEEDO CABLE
0 Members Browsing (39 Guests)
  Author    SPEEDO CABLE  (currently 1,281 views)
Posted on: May 18th, 2009, 15:24:16 Quote Report to Moderator
The genuine Laminova oil/water intercooler is a great unit.
The smallest size, shown in the photo on my GTM Coupe, is equivalent to a 13 row oil cooler but needs no external airflow and no thermostat. It uses water in the engine cooling system to cool the oil but allows it to warm up quickly and never overcools it.
Private Message Reply: 15 - 18
Posted on: May 18th, 2009, 20:19:22 Quote Report to Moderator
Thats some maze of pipes John.
Private Message Reply: 16 - 18
Posted on: May 18th, 2009, 22:07:01 Quote Report to Moderator
Quoted from John Dickens, posted May 18th, 2009, 15:24:16 at here
It had better be at 150 plus VAT
  Private Message Reply: 17 - 18
Posted on: May 19th, 2009, 06:58:43 Quote Report to Moderator
By the time you've bought a standard cooler, thermostat, mountings and fittings they're not that cheap either. For me, with a Coupe, the price was a snip compared to the problems of either ducting air into the engine compartment for a conventional cooler or running oil pipes to the front of the car for a normal mounting. The laminova didn't even need a mount. The pipes held it in place.
Neil
The pipes sort of evolved. There's a Davies Craig electric water pump hiding in there too. I'm sure if they were'nt bright blue you wouldn't notice them too much.
Private Message Reply: 18 - 18
Powered by e-blah Platinum 7 Final © 2001-2004   -   February 28th, 2021, 18:08:53
Files opened: 78 | Files closed: 78
