  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  My Mini Marcos
0 Members Browsing (3 Guests)
  Author    My Mini Marcos  (currently 6,639 views)
Lee Matthews
Posted on: May 31st, 2009, 16:10:39
Hi some pictures for the forum of my work in progress mini marcos hope to get to the 50th party in cheltenham should have the motor running next week thanks for all the help from the club.
Last modified May 31st, 2009, 21:57:43 by admin
Lee Matthews
Posted on: May 31st, 2009, 16:21:39
no2
Private Message Reply: 1 - 23
Lee Matthews
Posted on: May 31st, 2009, 16:26:28
no3
Private Message Reply: 2 - 23
Lee Matthews
Posted on: May 31st, 2009, 16:27:53
no4
Private Message Reply: 3 - 23
Garry Scott
Posted on: May 31st, 2009, 20:33:38 Quote Report to Moderator
nice cosmics! i just swapped a set for a weber!
  Private Message Reply: 4 - 23
Syd Crawford
Posted on: May 31st, 2009, 22:48:01 Quote Report to Moderator
Good to see it that it will be on the road soon. Have you thought about touching up the paint a little?
Private Message Reply: 5 - 23
Guy Humphries
Posted on: June 1st, 2009, 22:09:19 Quote Report to Moderator
No, he doesn't want to do that - For once my my paintwork looks quite good in comparison...
Private Message Reply: 6 - 23
Tim Neal
Posted on: June 1st, 2009, 22:18:47 Quote Report to Moderator
Quoted from Syd Crawford, posted May 31st, 2009, 22:48:01 at here
Looks like someone has already touched it up a little...a little here and a  little there. Maybe what he needs to do is touch it up a lot LOL.
Just having a laugh, keep up the hard work, I know how much is involved working with old fibreglass! As do we all on here!
Private Message MSN Reply: 7 - 23
Lee Matthews
Posted on: June 2nd, 2009, 16:13:41 Quote Report to Moderator
Thanks for the all the good replys yes It will have a new paint job to replace the urban tiger look.Only posted so you could have a look the motor is austin 1300gt with lcb,rc40 exhaust and 40 webber.the brakes cooper s will keep you updated with work done  cheers Lee.
Private Message Reply: 8 - 23
Lee Matthews
Posted on: June 2nd, 2009, 16:15:54
Picture of dash.
Private Message Reply: 9 - 23
Joost van Dien
Posted on: June 7th, 2009, 13:44:42 Quote Report to Moderator
That dashboard is quite good! Take it appart, bit of sanding a layer of clear coat and put it back in! The paint of the car look worn how are the subframes and engine (if in)?
Private Message MSN Reply: 10 - 23
Lee Matthews
Posted on: June 7th, 2009, 20:29:22 Quote Report to Moderator
Hi just finished work on marcos today yes the motor ran today after 5 years just need a little work on set up with webber a bit flat 1 1/4 of throttle but idled ok.Yes the dash is ok will clean up  the clocks are smith's and switch panel from jaguar also subframe look ok no holes.cheers Lee.
Private Message Reply: 11 - 23
Lee Matthews
Posted on: October 22nd, 2012, 17:26:03
Hi update on condition of my marcos.
Private Message Reply: 12 - 23
Posted on: October 22nd, 2012, 17:45:48 Quote Report to Moderator
Top colour choice!  Well done
Private Message Reply: 13 - 23
Lee Matthews
Posted on: October 22nd, 2012, 17:50:00
2.
Private Message Reply: 14 - 23
Lee Matthews
Posted on: October 22nd, 2012, 17:53:20
Private Message Reply: 15 - 23
Lee Matthews
Posted on: October 22nd, 2012, 17:54:12
Respect for that power
Last modified October 22nd, 2012, 17:56:23 by Lee Matthews
Private Message Reply: 16 - 23
Lee Matthews
Posted on: October 22nd, 2012, 17:57:06
Q.Factory fitted sunroof ??.
Last modified October 22nd, 2012, 18:00:09 by Lee Matthews
Private Message Reply: 17 - 23
Lee Matthews
Posted on: October 22nd, 2012, 18:01:53
engine bay .
Private Message Reply: 18 - 23
Lee Matthews
Posted on: October 22nd, 2012, 18:05:22
Honda crx mk1 seat with 3 point belts look ok and fitted in one hour. .
Private Message Reply: 19 - 23
Lee Matthews
Posted on: October 22nd, 2012, 18:07:17
crx seat's from rear close to roof but no problems for short people.
Private Message Reply: 20 - 23
Lee Matthews
Posted on: October 22nd, 2012, 18:09:04
Cooper s discs with bfg brake lines.
Private Message Reply: 21 - 23
Lee Matthews
Posted on: October 22nd, 2012, 18:14:09
The bad part front and rear wheel arches need repair should have it done this week .
Private Message Reply: 22 - 23
Lee Matthews
Posted on: October 25th, 2012, 21:37:02 Quote Report to Moderator
Hi Good home needed the car is listed on ebay sad but lack of time for a project  ebay 221145325436
Private Message Reply: 23 - 23
Powered by e-blah Platinum 7 Final © 2001-2004   -   April 16th, 2024, 06:04:07
Files opened: 80 | Files closed: 80
