  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  seatbelt points.....?
0 Members Browsing (45 Guests)
  Author    seatbelt points.....?  (currently 596 views)
Glenn_Merrigan
Posted on: July 31st, 2011, 15:35:11 Quote Report to Moderator
Ok ive noticed i have no where to mount any seatbelts.... im guesing my mkq didnt require them, but i would like to fit some, and am thinking about harnesses, where are the later models belts atached??
Chris_Shackleton
Posted on: August 1st, 2011, 10:50:12 Quote Report to Moderator
Hi Glenn,
Will have a look at my MK4 tonight, I think it has mountings built in.
Depends if you want to fit 3 point seatbelts or harnesses.
If its 3 point inertia reel seatbelts then I would make strengthened points on the B pillar at shoulder height (if there is enough 'meat' there), at the base and opposite on the raised transmission tunnel. I would do this with steel plates bonded in and then use harness mounting plates (you can get from Demon Tweeks) that you bolt onto.
A 4 (or 6) point herness is probably a better coice on an early car as the B pillar isnt that wide (someone will correct me if I am wrong - not recently familiar with the earlier cars). Make the lower mountings at B pillar base & in middle, then put spreader plates in the back, not too close to the seat - the belt should be closer to horizontal than vertical. Use the harness mounting plates and an eye bolt to clip the harness to it.
Hope this helps
Chris
8158 (MK4) to restore
Caterham 7 to repair
I've broken my toys!
Private Message Reply: 1 - 8
Posted on: August 1st, 2011, 10:53:04 Quote Report to Moderator
Glenn - my D&H Mk4 has the reel mounted on the wheel arches, and the "tail end" on a steel plate bolted through the floor next to the seat runners. As Chris said, it all depends on what you plan to fit, and that depends on what you're planning to do with it?
Private Message Reply: 2 - 8
Posted on: August 1st, 2011, 13:23:21 Quote Report to Moderator
You choose your own attachment points - they were never predrilled or reinforced. It depends on what type of belt or harness you are fitting, on whether you have a roll cage and on where you are placing the seats.
If you are fitting a roll cage then the rear harness mounts are usually provided on a horizontal bar at the back. For three point belts the rear fixing should be on top of the wheel arch with a steel plate underneath. The lower mountings can go on the sills below the box section and on the inside of the tunnel, also with steel plates behind to spread the load.
  Private Message Reply: 3 - 8
Glenn_Merrigan
Posted on: August 1st, 2011, 19:20:06 Quote Report to Moderator
ok thanks guys for the replies, i was looking at roll cages last night but didnt come up with much.... where can you get them or is it goingto be a custom jobby??
Private Message Reply: 4 - 8
Posted on: August 1st, 2011, 21:14:45 Quote Report to Moderator
You can't buy them off the shelf but at least three companies can make roll cages. Marcos Heritage Spares will refer you to a company called Caged, or you can go to Safety Devices or Rollcentre.
  Private Message Reply: 5 - 8
Glenn_Merrigan
Posted on: August 2nd, 2011, 10:31:05 Quote Report to Moderator
Ok, has anyone on here got one fitted? Would love to see how they look?
And while im asking about interior pics, is there any floating about of the standard mk1 interior? Or even the le mans ones insides??? Mine is pretty bare as the carpets have gone mouldy!
Private Message Reply: 6 - 8
Allan Brown
Posted on: August 2nd, 2011, 12:42:33 Quote Report to Moderator
Peter Bremner has a caged (Marcos Heritage) cage fitted to his car.
See here: http://minimarcos.org.uk/cgi-bin/forum/Blah.pl?b=MM,m=1300734715
I fitted a rollcentre cage in mine.
Where do you live? Peter is in Essex and I am in West Sussex.
Private Message Reply: 7 - 8
Posted on: August 2nd, 2011, 16:29:44 Quote Report to Moderator
I've a rollcentre full cage in mine, but it was custom made and fitted rather than the diy kit that they sell off the shelf. There's a lot of work fitting the kit, according to the people that have done it but the alternative is a lot of £'s in having one custom made and fitted. I didn't have a choice when I did mine back in '92 as no one did one off the shelf then, and mine was the 1st mini marcos that the roll centre had ever made a cage for. It's actually about to go back to the roll centre in a couple of weeks for some of modifications that I want. Even after 19 years they remember it well as it's the smallest car they have ever fitted a full cage to.
Private Message Reply: 8 - 8
Powered by e-blah Platinum 7 Final © 2001-2004   -   February 26th, 2021, 06:18:07
Files opened: 93 | Files closed: 93
