  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Tank for Mini Marcos
Pages: « 1, 2, 3 » : All Reply Recommend Print
  Author    Tank for Mini Marcos  (currently 1 views)
Posted on: August 26th, 2011, 13:44:22
The new leg without the bend.... which required a new cross brace and new door bars... £'s.....
Private Message Reply: 15 - 35
Posted on: August 26th, 2011, 13:55:40
This is how it was mounted in the front. The foot loads both the floor and the sill. Even better would be to have an even bigger plate extending on t the top of the sill.
The bars that go to the top of the front subframe can just be seen. Also the door bars are tight on the sill. We always thought that this was a last resort, if the cage is moving in a roll relative to the body the door bars would spread some load across the sills from front to back. The cross beam is tight on the centre tunnel for the same reason, but no spreader plate is fitted.
Having the rear cross beam means that the rear hoop is about 100mm further forward than if mounted directly onto the body infront of the wheel arch. That gives a cage nearer the driver and about 10mm higher. Not a lot but with the tiny head clearance of the MM that might make all the differance between breaking my neck or not.
It was the Roll Centre's idea, but mainly because they thought it needed to pick up as much of the suspension points as possible. They considered that they were the only points they could rely on. Even so they told me I was completely mad to be in it !
Private Message Reply: 16 - 35
laurent laval
Posted on: August 26th, 2011, 14:52:47 Quote Report to Moderator
Thanks a lot for all this details!!!
Private Message Reply: 17 - 35
Peter Bremner
Posted on: August 26th, 2011, 20:19:21 Quote Report to Moderator
While your wallet is undergoing surgery, are you going to powder coat?
To put on multiple pictures, open an account with Photobucket (or similar), upload the pictures then copy and paste the IMG codes underneath each picture in the album. If you leave a line between each code, the photos will have a white line between them.
Private Message Reply: 18 - 35
Posted on: August 27th, 2011, 12:19:48 Quote Report to Moderator
Thanks Peter for the info on posting pictures.
As for powder coating although I'd like to, I can't justify the cost or prep time so I'll just spray it. That's the reason the Roll Centre didn't paint it, the new bits are easy but the old bits more difficult.
This series of posts has made me think and if I was having a brand new cage built I don't think I'd go for the rear spreader bar, but just land in front of the rear wheel arches. But I would try and spread the load using similar sized plates. i.e. into both the top and into the rear beam and subframe. The minimal gain in height and side to side protection gained by the bar is probably not really worth the complication or weight.
Private Message Reply: 19 - 35
Phil Smethurst
Posted on: August 28th, 2011, 00:00:22 Quote Report to Moderator
Sorry if this doesn't work - I'm just trying Peters advice and have opened a photobucket account to try and post a picture of my own rollcage. I would like to modify it as per Jims car to pick up the front subframe.
Private Message Reply: 20 - 35
Posted on: August 28th, 2011, 14:43:19 Quote Report to Moderator
There's no reason why you shouldn't do multiple posts with one photo per post. I've put a size limit on attachments to stop very large images being uploaded but 153.5kB should e adequate.
The interior looks nice!
  Private Message Reply: 21 - 35
Posted on: August 29th, 2011, 17:57:15 Quote Report to Moderator
Phil, far nicer interior than mine.
Safety devices do a set of bars to pick up the front cross beam on a standard mini see http://www.stableenergies.com/Multipoint-Bolt-In-Roll-Cage-Kit-Mini-Cooper/productinfo/SD-N46/
You may be able to use/adapt a set of these depending on the location of your front legs. But the diagram clearly shows the effect you are aiming for.
Private Message Reply: 22 - 35
dalla
Posted on: August 29th, 2011, 20:34:42 Quote Report to Moderator
This will also be one of my first things to do on 7012. I was wondering if would be a good idea to attach the drivers seat to a frame seperate from the body welded the rollcage? What happens if the roll cage bolting points break?
Mini Marcos Mk.II 7012
Dennis Overgaard Nielsen
Denmark
  Private Message Reply: 23 - 35
Posted on: August 29th, 2011, 20:49:38 Quote Report to Moderator
Attaching the seat to the roll cage is a very good idea and the roll centre were very keen that I did it. But to date I've never found a way to do it and still have any headroom! Suggestions welcome!
Private Message Reply: 24 - 35
dalla
Posted on: August 30th, 2011, 18:24:15 Quote Report to Moderator
Yeah i see the problem, i was thinking about a gurney bubble, but that might not be enough?
Do you know if a mod like this is accepted by FIA rules?
Denmark
Last modified August 30th, 2011, 18:25:02 by dalla
  Private Message Reply: 25 - 35
Posted on: August 30th, 2011, 18:48:49 Quote Report to Moderator
Strictly speaking you need 50mm above the drivers helmet to the top of the roll cage, but I've never known a scrutineer check that. I certainly haven't got it, I think I might have about 5mm! I've had to pad the roof to stop scratching my helmet, I also only do UK events. But a Gurney Bubble rather shouts at the scrutineer that you have no clearance. There is at least one MM I've seen photo's of with a Gurney Bubble but I don't know if it's caused problems. Malcolm Anderson used to compete in a Clan with a wedge shaped raised roof section but the roll bar went into the highest part of wedge.
When the requirement to fit FIA seats came in, that created problems for me, as the cushion of all FIA seats that I looked at were at least 30mm higher than the seat I had been using. I considered raising the roof but dropped the floor under the seat instead a bit like a mk1 (mine is MK3). I droped it about 25mm which still left the floor higher than the sump guard plus it made the floor more rigid..... I far prefered my old Cobra Clubman seats though.
Private Message Reply: 26 - 35
Allan Brown
Posted on: August 30th, 2011, 19:39:35 Quote Report to Moderator
I have got a gurney bubble in my roof. My head doesn't go up into it but it does make it easier getting my helmet off in the car. I lowered the floor originally but found the driving position to low, making it hard to see the apex of the corners. So I put the floor back to normal and put the bubble in the roof.
I have sprinted and hillclimbed the car across the south of England for 10 years and have never had a scrutineer complain about it.
Private Message Reply: 27 - 35
Posted on: August 31st, 2011, 09:27:52 Quote Report to Moderator
I hadn't come across the term Gurney Bubble before, but it seems it's yet another innovation of Dan Gurney to get his 6'3" frame into a GT40 which has a notoriously small cockpit. He also devised the Gurney Flap and (I didn't know this either) accidentally initiated the ritual spraying of Champagne around on the podium.
  Private Message Reply: 28 - 35
Glenn_Merrigan
Posted on: August 31st, 2011, 18:34:42 Quote Report to Moderator
is this the right tank?
http://secure.fueltanksdirect.co.uk/mini-vanclubman-est-19809008-01-381-166-p.asp
im hoping that is just a general picture as im pretty sure my mk1 tank looks different...
or does anyone have a better place to get one???
Private Message Reply: 29 - 35
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 12th, 2026, 18:18:35
Files opened: 121 | Files closed: 121
