  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  glassfibre tissue
0 Members Browsing (41 Guests)
  Author    glassfibre tissue  (currently 309 views)
lester stenson
Posted on: December 25th, 2013, 22:40:16 Quote Report to Moderator
my marcos isa mark 3 with a clear gelcoat, this has cracks and crazing all over it and looks a bit sorry for itself. I propose to cover the whole outer bodyshell in resing and glassfibre tissue to insure the the cracks don;t reappear how have some of you guys tackled this problem, as you can see from my previous threads i have to graft a new front on it so it is having major work anyway. Any idea's where to get the tissue from by the way.
cheers people and merry xmas
Posted on: December 25th, 2013, 22:56:28 Quote Report to Moderator
You can get tissue from Halfords in smallish quantities, or from online fireglass suppliers, Scott-Bader (The Fibreglass Shop), some chandlers and boat yards.
If you're not going to remove all the gelcoat then I suggest that you at least grind out the cracks so that any dampness can evaporate and the resin can flow into them.
  Private Message Reply: 1 - 6
Posted on: December 26th, 2013, 09:53:26 Quote Report to Moderator
East Coast Fibreglass.
http://www.ecfibreglasssupplies.co.uk
I don't think a covering of tissue will stop the cracks reappearing in stress areas though.
These will need to be reinforced first.
Private Message Reply: 2 - 6
lester stenson
Posted on: December 28th, 2013, 00:56:00 Quote Report to Moderator
so what's the best way of doing this cause i only want to do it once.
cheers lester
Private Message Reply: 3 - 6
Posted on: December 28th, 2013, 08:52:54 Quote Report to Moderator
Tissue is fine over small and minor cracks but major and high stress areas I would put some additional mat on the inside then you need to grind the outside deeper some chopstrand or maybe some woven put in then tissue and filler.
Private Message Reply: 4 - 6
Posted on: December 28th, 2013, 09:46:00 Quote Report to Moderator
Stress cracks are caused by flexing so you need to reinforce the area to stop it flexing.
Abrade the GRP behind the crazing with something fairly aggressive. I use a twist knot wire brush in a angle grinder. Laminate on the csm until you are happy that it is rigid enough then repair the outer surface as described above. To be honest it's a total pain in the butt but unless you do it right then cracks will reappear very quickly once the car is in use again.
Private Message Reply: 5 - 6
Posted on: December 28th, 2013, 11:39:43 Quote Report to Moderator
I got a length of coarse sander belt about 10cm wide at one of the shows and that's good for abrading the fibreglass. I just cut off a short length at a time as required.
  Private Message Reply: 6 - 6
Powered by e-blah Platinum 7 Final © 2001-2004   -   February 25th, 2021, 13:23:26
Files opened: 85 | Files closed: 85
