Mini marcos 8410 Spain (+++ PHOTOS) (currently 3,629 views) |
Cristian Sammartin Castro |
Posted on: November 23rd, 2014, 11:51:56 |
Reply: 60 - 106 |
Posted on: November 23rd, 2014, 11:57:37 |
Reply: 61 - 106 |
Posted on: November 23rd, 2014, 12:09:50 |
Reply: 62 - 106 |
Posted on: November 23rd, 2014, 17:53:53 |
looking really good your making great progress. By the looks of your photos it's the front panel you need not the bonnet. Mike |
Last modified November 23rd, 2014, 17:55:20 by mike brown |
Reply: 63 - 106 |
Heinrich_Lux |
Posted on: November 23rd, 2014, 23:10:39 |
What about that massive gap between the front panel and the subframe? On mine (MK3) its not existent and even that tight that the subframe wont drop out without any bolts. That is engine still in place... |
Reply: 64 - 106 |
Posted on: November 24th, 2014, 17:08:25 |
I don't think it's as bad as it looks. The upright look to of been cut out along with part of the valence probably to allow it to be flip fronted in the past I suspect once this is reinstated the gap will be minimal. Mike |
Reply: 65 - 106 |
Posted on: November 24th, 2014, 20:09:40 |
In the past it was front flip , the next step is to put that part number and serial car front , where air enters to cool the engine
Last modified November 24th, 2014, 20:11:54 by Cristian Sammartin Castro |
Reply: 66 - 106 |
Posted on: November 24th, 2014, 20:12:03 |
Someone has measures to make that piece ?? Length and height of this piece engine cover thanks |
Reply: 67 - 106 |
Joost van Dien |
Posted on: November 25th, 2014, 11:04:30 |
The gap is I think as Mike says, for the flip front brace. As I understand it Cristian wants to have the front end as original as possible. It looks like the fiberglass from the subframe up the connecting points is cut away. Normally there is a thinker lip were the subframes rest against the fiberglass. A quick fix would be to have a spacer in the gap, otherwise you have to reconstruct the fiberglass.
Regards, Joost
Reply: 68 - 106 |
Posted on: November 27th, 2014, 20:38:31 |
Hello, we will rebuild fiberglass , can you say me far to the front entrance of the car? Thank you |
Reply: 69 - 106 |
Posted on: March 22nd, 2015, 11:17:01 |
Reply: 70 - 106 |
Posted on: March 22nd, 2015, 11:19:35 |
Reply: 71 - 106 |
Posted on: March 22nd, 2015, 11:19:48 |
Reply: 72 - 106 |
Posted on: March 22nd, 2015, 11:21:58 |
Reply: 73 - 106 |
Posted on: March 22nd, 2015, 11:24:03 |
Reply: 74 - 106 |
