Piping routes (currently 803 views) |
Andy_Bullock |
Posted on: April 22nd, 2014, 09:56:59 |
Hi all, I have just about finished the bodywork repairs on my 1969 MM. Before spraying I am looking at drilling the holes for securing both the fuel line and brake lines. When I purchased the project there were none and there was also no exhaust, so I am in the blind somewhat as to the exact route they go and where the exhaust fixings will then have to go. Would anyone be kind enough to provide me with some 'underneath' pictures of cars / brake /fuel line placements please? Thanks again for all if your help, Andy |
Andy_Bullock |
Posted on: April 25th, 2014, 11:17:35 |
Any info gratefully received folks?! I can guess the brake and fuel lines to a certain extent (run down the passenger side of the central recess), but have no idea how / where the exhaust is to be fixed underneath.
Cheers Andy |
Reply: 1 - 4 |
Steve_Schmidt |
Posted on: April 25th, 2014, 12:37:11 |
Having just been through this myself Andy, I can tell what I have done - I'm not sure how Marcos envisaged it being done, I guess everybody had their own ideas. The previous owner of my car ran power and earth cables, brake line and fuel line in a pair of plastic conduits attached to the top of the central tunnel inside the car. They ran one either side of the handbrake lever. I felt that it was rather cumbersome and untidy, so I ran my power and earth cables through the drivers-side sill cavity with the brake and fuel lines through the passenger-side sill. It was very fiddly feeding them through, but it is a tidy way of dealing with the problem. As for the exhaust, I'm not up to that yet, but having thought about it a fair bit, I'm just going to fit some sort of strap or rubber mount to the front and back cross-members of the rear subframe to support an oval muffler with a single 2" inlet and twin pipe outlets running under the fuel tank in the centre of the car. Unfortunately I've found that the standard mini exhaust mount that bolts to the front cross-member of the rear subframe won't fit my Marcos because the spare wheel well is too close to it.
This picture shows where the brake and fuel lines enter the sill cavity-
This is where they come out and run up under the dash and through the firewall -
Here's where the Earth, Power and rear loom wires enter the drivers-side sill cavity -
They then run up the inside of the A-pillar and terminate at the dashboard where there is a battery isolation switch and an angle-iron dash support rail that makes a nice Earthing point.
.... and this is how they were located in the car originally -
Steve (MM 7056) Downunder http://www.mm7056.wordpress.com |
Logged |
Reply: 2 - 4 |
Andy_Bullock |
Posted on: April 25th, 2014, 13:25:02 |
Perfect, thanks very much for this Steve. Much neater method of running the lines, I am not too keen on the original central tunnel idea !
I am also a big fan of your choice of rear lights, you wouldn't happen to know anywhere I could get a similar pair do you? I think they fit the rear of your car perfectly.
Thanks again, Andy
Reply: 3 - 4 |
Steve_Schmidt |
Posted on: April 25th, 2014, 20:12:22 |
Logged |
Reply: 4 - 4 |
