  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  GEAR 2ND
0 Members Browsing (40 Guests)
  Author    GEAR 2ND   (currently 325 views)
margaret
Posted on: July 24th, 2014, 07:18:29 Quote Report to Moderator
where we can buy GEAR 2ND A Series engine 26 teeth ?
http://www.miniclassic.pl
http://www.clubmanestate.pl
http://www.minimarcos.pl
Posted on: July 24th, 2014, 08:20:50 Quote Report to Moderator
Minispares.
http://www.minispares.com/prod.....x/Helical~gears.aspx|Back%20to%20shop
Private Message Reply: 1 - 4
margaret
Posted on: July 24th, 2014, 08:51:13 Quote Report to Moderator
this is for A+
maybe it will fit to A, but I don't want to try.
I have found it on another site http://www.guess-works.com/Shop/Parts/display.htm?id=203
  Private Message Reply: 2 - 4
Posted on: July 24th, 2014, 10:13:03 Quote Report to Moderator
If you contact Minispares directly they will tell whether it is the correct part and if not they will be able to tell you which one you do require.
Private Message Reply: 3 - 4
Steve_Schmidt
Posted on: July 24th, 2014, 23:09:39 Quote Report to Moderator
G'day Margaret,
If it's the pre-A+,  4-syncro gearbox as fitted to to the Cooper S  then the part number is 22G1094. I also had trouble finding a new one of these for my gearbox. After a world-wide search I found a few new, old stock items in the Netherlands.
Contact Karel at info@damenenkroes.nl
Steve (MM 7056) Downunder
Last modified July 25th, 2014, 07:04:51 by Steve_Schmidt
Logged
Private Message Reply: 4 - 4
Powered by e-blah Platinum 7 Final © 2001-2004   -   February 28th, 2021, 09:35:28
Files opened: 81 | Files closed: 81
