  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  NEW WHEELS AND TIRES MARCOS MK4
0 Members Browsing (34 Guests)
  Author    NEW WHEELS AND TIRES MARCOS MK4  (currently 342 views)
Kevtm49
Posted on: February 4th, 2016, 11:34:09 Quote Report to Moderator
Hello,
I want to change the wheels of my mini mk4 marcos who are currently 5x12 Minilight.
I want to pass on the 10 inch but I do not know what type of rim is most suitable especially in backwardation since I try ultralight 6x10 but the offset is really too important.
What you have wheels mounted 10 inches and would eventually you pictures?
I saw the following models:
Minilight 5x10
minator 5x10
minilite 5x10
gb 5x10
sorry for my English
Thank you for your feedback
Nigel_Holmes
Posted on: February 4th, 2016, 20:26:18 Quote Report to Moderator
Kevin,
If you're planning to use 145x10 tyres then I would recommend the 4.5 inch steel Cooper S rims (not reverse rim). These give very good handling, and are not prone to aquaplaning at speed in wet conditions.
If you're going to use 165x10 tyres then 5 inch rims should keep the tyres under the wheelarch. Wheels will need correct inset.
Are you running 7.5 inch discs?
Private Message Reply: 1 - 2
Kevtm49
Posted on: February 4th, 2016, 20:43:41 Quote Report to Moderator
I currently have brake in 8.4 "but I also changes to the 7.5" MINISPORT.
http://www.minisport.com/mslms03kit-7-5-brake-kit-with-4-pot-alloy-calipers.html
I wish for tires 165/70/10 Yokohama A032R mount for the circuit and road use.
So it takes me well rims 5x10 but not all the same offset values.
Last modified February 4th, 2016, 20:47:19 by Kevtm49
Private Message Reply: 2 - 2
Powered by e-blah Platinum 7 Final © 2001-2004   -   February 28th, 2021, 09:27:11
Files opened: 87 | Files closed: 87
