Cooling system (currently 598 views) |
Andy_Bullock |
Posted on: June 24th, 2017, 16:25:43 |
Hi all, literally have about 3 jobs left now and another MM will be on the roads! I have fitted the cinquecento radiator and cooling fan along with a mgb brass expansion tank. Anyone familiar with these expansion tanks will know they have a small capillary pipe inside that goes down into the water level within the tank....meaning you really can't use it to full the cooling system!! So I have sent a long time today with the small pipe off the thermostat housing and a funnel filling the system. I have ran the car for a while on the drive with the expansion cap off and it looked as though it has bled itself with a large number of bubbles coming through. Soon after turning off though the expansion tank was boiling! Will this be OK if I just put the cap on and try again. Engine temp was fine, not overheating or anything. How does everyone else fill their cooling systems when using the Cinq radiator?? Cheers guys. |
John_Campbell |
Posted on: June 24th, 2017, 16:35:55 |
Hi Andy, I've got a Cinque in my 1275 Jem. I used the heater pipe to fill it then the exp tank. If the expansion tank takes the expanded hot water surely it must return it when it cools, mine does. I had bubbling from the thermostat housing hose and assumed it was just air escaping rather than boiling. It may well settle down once run for a while, mine did. The Cinque rad works a treat and I can't even get my fan to come on as it never gets hot enough, even this week with record temps. Good luck. |
Reply: 1 - 4 |
Andy_Bullock |
Posted on: June 24th, 2017, 17:44:40 |
Can you roughly remember the capacity? I don't have a heater and think I am around 3.5 litres? I will keep an eye on it, just worrying on a freshly rebuilt engine when you see boiling in the header!!! |
Reply: 2 - 4 |
David_Farmer |
Posted on: June 24th, 2017, 18:21:19 |
If you had the cap off, then I would expect to see the water boil. Fitting the cap increases the pressure, which means more heat is required to boil the water. With the correct cap fitted, the engine should never produce enough heat to boil the water. |
Reply: 3 - 4 |
Andy_Bullock |
Posted on: June 24th, 2017, 19:27:43 |
Thanks David, only reason for running with the cap off was the uncertainty of how much fluid had actually gone in! Cheers, will drop the cap back on! |
Reply: 4 - 4 |
