  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  370 JEA Rebuild
Pages: 1, 2, 3, 4 » : All Reply Recommend Print
  Author    370 JEA Rebuild  (currently 1 views)
David_Farmer
Posted on: April 6th, 2018, 09:16:30
There once was an ugly duckling...
David_Farmer
Posted on: April 6th, 2018, 09:17:56
Private Message Reply: 1 - 57
David_Farmer
Posted on: April 6th, 2018, 09:18:24
Private Message Reply: 2 - 57
David_Farmer
Posted on: April 6th, 2018, 09:18:58
Private Message Reply: 3 - 57
David_Farmer
Posted on: April 6th, 2018, 09:19:25
Private Message Reply: 4 - 57
David_Farmer
Posted on: April 6th, 2018, 09:19:49
Private Message Reply: 5 - 57
David_Farmer
Posted on: April 6th, 2018, 09:20:21
Private Message Reply: 6 - 57
David_Farmer
Posted on: April 6th, 2018, 09:22:16
I was going to get it roadworthy first before the restoration, but everything was junk, so I just stripped it back to a shell.
Private Message Reply: 7 - 57
David_Farmer
Posted on: April 6th, 2018, 09:22:47
Private Message Reply: 8 - 57
David_Farmer
Posted on: April 6th, 2018, 09:23:12
Private Message Reply: 9 - 57
David_Farmer
Posted on: April 6th, 2018, 09:23:33
Private Message Reply: 10 - 57
David_Farmer
Posted on: April 6th, 2018, 09:23:59
Private Message Reply: 11 - 57
David_Farmer
Posted on: April 6th, 2018, 09:24:27
Private Message Reply: 12 - 57
David_Farmer
Posted on: April 6th, 2018, 09:25:21
Private Message Reply: 13 - 57
David_Farmer
Posted on: April 6th, 2018, 09:26:46
Thanks to Mike Brown for completing the fibreglass work needed (including reinstating the bottom rear of every arch, which presumably had been cut away to make room for 12" wheels) and taking off the nasty white paint.
Last modified April 7th, 2018, 09:07:09 by David_Farmer
Private Message Reply: 14 - 57
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 10th, 2026, 17:23:59
Files opened: 140 | Files closed: 140
