0 Members Browsing (25 Guests)
Pages: 1, 2, 3, 4, 5, 6 » : All Reply Recommend Print
  Author    7213  (currently 11,614 views)
Philip_Davenport
Posted on: March 17th, 2019, 18:51:53 Quote Report to Moderator
It needs a full restoration, so I thought I'd post pictures as it goes..
Philip_Davenport
Posted on: March 17th, 2019, 19:13:52
Looks nice..
Private Message Reply: 1 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:15:07
Interesting badge
Private Message Reply: 2 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:16:46
Nice face..
Private Message Reply: 3 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:18:14
Inside.. after vacuuming
Private Message Reply: 4 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:20:49
Cool...
Private Message Reply: 5 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:21:20
Inside..
Private Message Reply: 6 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:22:59
Special fuel tank float..it's a digital internet ready OLED capable external float.....
Last modified March 17th, 2019, 20:43:51 by Philip_Davenport
Private Message Reply: 7 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:24:08
Special twin pipe exhaust, shortened to lower weight for racing.
Last modified March 17th, 2019, 20:42:31 by Philip_Davenport
Private Message Reply: 8 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:26:24
Another cool badge... I keep these..
Private Message Reply: 9 - 83
Philip_Davenport
Posted on: March 17th, 2019, 19:33:28 Quote Report to Moderator
I don't like the dash so hopefully Mike Brown helps me with a cool one.
Last modified March 17th, 2019, 19:37:16 by Philip_Davenport
Private Message Reply: 10 - 83
Posted on: March 17th, 2019, 22:05:36 Quote Report to Moderator
Lotus colours not sure if it works or not but I've seen an awful lot worse. Couple of weekends and that'll be ready to go.
Private Message Reply: 11 - 83
Philip_Davenport
Posted on: March 18th, 2019, 12:32:45 Quote Report to Moderator
Cheers Mike, Do you have any hints on exhaust?
As loud as possible as it doesn't need MOT and we want people to hear the car, as they wont see it..
Private Message Reply: 12 - 83
Philip_Davenport
Posted on: March 18th, 2019, 14:09:09 Quote Report to Moderator
I think i found exhaust ...
Richard Porter on FB said... "On foggy it's Maniflow throughout (came as seven bits in a sack) ... exits RHS... "
So from MiniSpares:
C-ARA339 - MANIFLOW VAN AND PICKUP T...                     117.00
C-AEG376 - MANIFOLD LCB EXHAUST STAG...                     92.80
        251.76
It looks like this 5 bits though.. & I need to look at what is on car now...
Private Message Reply: 13 - 83
Gary Marlow
Posted on: March 18th, 2019, 17:03:37 Quote Report to Moderator
Looks like you have a rear anti roll bar on the MM as well.
What sort of condition is it in and do you have any photos or close ups you could post.
From what can be seen of it looks like it could be one of the Speedwell anti-roll bars offered as an option on the MM.
Gary
Private Message Reply: 14 - 83
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 12th, 2022, 00:46:16
Files opened: 90 | Files closed: 90
