DH8302 (currently 2,307 views) |
Matt_Phillips |
Posted on: April 3rd, 2019, 07:39:22 |
Posted on: April 3rd, 2019, 08:49:05 |
Little bit of work there. Mike |
Reply: 1 - 22 |
Gary Marlow |
Posted on: April 3rd, 2019, 13:43:17 |
Will be good when done. Funnily enough - well it is for me - the person who built my Mk 3, cut the front off the car with the plan to make the front look more like a Jem.
Regards Gary |
Reply: 2 - 22 |
Gary Marlow |
Hopefully attached! |
Reply: 3 - 22 |
Philip_Davenport |
Posted on: April 4th, 2019, 10:00:02 |
Good luck with this Matt. The front wheel arches look very cool! I think I can see a classic Mini under the cover. Is this for parts or is it running? And a white Mini Marcos in the foreground.. what is the story with this? Or are these pictures from the prior owner?
cheers Philip |
Owner since March 2019 of SWD 588G Chassis: 7213 | Last modified April 4th, 2019, 10:01:39 by Philip_Davenport |
Reply: 4 - 22 |
Posted on: April 4th, 2019, 20:05:28 |
Reply: 5 - 22 |
Matt_Phillips |
Posted on: April 5th, 2019, 11:14:54 |
Quoted from Philip_Davenport, posted April 4th, 2019, 10:00:02 at here |
cheers Philip
Last modified April 5th, 2019, 11:17:22 by Matt_Phillips |
Reply: 6 - 22 |
Matt_Phillips |
Posted on: April 16th, 2019, 16:37:41 |
Reply: 7 - 22 |
Matt_Phillips |
Posted on: June 12th, 2019, 08:00:13 |
Reply: 8 - 22 |
Matt_Phillips |
Posted on: June 12th, 2019, 08:01:19 |
Reply: 9 - 22 |
Matt_Phillips |
Posted on: June 12th, 2019, 08:02:09 |
Reply: 10 - 22 |
Matt_Phillips |
Posted on: June 12th, 2019, 08:03:57 |
First batch of powdercoating
Reply: 11 - 22 |
Posted on: June 16th, 2019, 14:22:56 |
Matt - after the powder coating do you have to re-tap any threaded holes? If so, does this cause the powder coating to chip off? |
Reply: 12 - 22 |
Matt_Phillips |
Posted on: February 14th, 2020, 13:51:49 |
Last modified February 14th, 2020, 14:01:33 by Matt_Phillips |
Reply: 13 - 22 |
Matt_Phillips |
Posted on: February 14th, 2020, 13:52:19 |
Reply: 14 - 22 |
Posted on: February 16th, 2020, 13:01:06 |
Any reason you removed the lower lip on the rear panel ? |
Reply: 15 - 22 |
Posted on: February 19th, 2020, 18:13:27 |
It's coming along nicely. Is that a Speedex beam and trailing arms? |
Reply: 16 - 22 |
Matt_Phillips |
Posted on: March 3rd, 2020, 17:13:42 |
Quoted from admin, posted February 19th, 2020, 18:13:27 at here |
i think the beam is a"huddersfield spares" style beam - nothing fancy. The radius arms came in a job lot of parts destined for a hillclimb mini. I've had them for about 13yrs, were off my last mini.
Reply: 17 - 22 |
Matt_Phillips |
Posted on: March 3rd, 2020, 17:19:15 |
Quoted from Neil KilBane, posted February 16th, 2020, 13:01:06 at here |
It ruined the nice lines of the rear end. In my eyes, it was a typical 1970's 'blocky' styling design/addition done to curvy/ delicate vehicle shapes from the 1960's. Think rubber bumpers on mg midgets and MGB's etc etc.
Reply: 18 - 22 |
Matt_Phillips |
Posted on: March 18th, 2020, 13:26:30 |
Chop! Unbelievable amount of filler in the nose/mouth. So heavy I believe it would effect handling
Reply: 19 - 22 |
Matt_Phillips |
Posted on: March 26th, 2020, 10:53:46 |
Crappy bulkhead airbox be gone! Took the decision to get rid as it was just another bit of dodgy fibreglassing. Will replace with a smooth bulkhead.
Reply: 20 - 22 |
Matt_Phillips |
Posted on: March 26th, 2020, 10:54:44 |
Random bit of flat-ish grp glued and screwed in. This will be glassed in from the back then given a couple of layers of tissue to smooth out the top layer. Then a skim/sand for blending in.
Reply: 21 - 22 |
Matt_Phillips |
Posted on: April 1st, 2020, 08:41:53 |
Reply: 22 - 22 |
