TIME TO REBUILD (currently 8,252 views) |
Simon_Pike |
very happy with the result |
Reply: 15 - 51 |
Simon_Pike |
and the pillars looked great |
Reply: 16 - 51 |
Simon_Pike |
was lucky enough to get a set of hinges from himleyhall mini day,but of course they had to be modified to stop them catching on the roof |
Reply: 17 - 51 |
Simon_Pike |
out with the dremmel |
Reply: 18 - 51 |
Simon_Pike |
another job completed |
Reply: 19 - 51 |
Simon_Pike |
its only taken about 16 hours to get the wiring for the rear lights sorted,loom was the wrong way round,numerous earths had to be added,relays,flasher units but they now all work |
Reply: 20 - 51 |
Simon_Pike |
thought i would have a go at puting the rear screen in today. wasnt a tough job(once i got the right rubber)and everything went well |
Reply: 21 - 51 |
Simon_Pike |
well i was on a roll i thought i would tackle the dash wiring, for some reason the previous owner had decided to refit all the standard mini switches into the original mini switch panel and stuff it up under the dash. that explains why the lights came on when i connected the battery. i fitted some nos triumph switches back into the dash(got rid of the mini switches/panel, refitted some gauges and wiring and repplaced all the bulbs(which to my suprise halfords still sell) know have a fully functional dash |
Reply: 22 - 51 |
Simon_Pike |
I have a internal door handle missing(mk1/2 bent around the door cards)so was thinking maybe i could extend the square rod and use non bent handles,took the door card off to discover the window is smashed(i havnt rolled it up since i bought it) so its a quick message to plastic4performance to get some lexan windows so not the end of the world, it will make it faster anyway less weight |
Reply: 23 - 51 |
Simon_Pike |
At last the windscreen is in,ended up putting the original screen back in(rather than the new one i had) as it fitted better this was the hardest job so far even had my daughter and the misses helping
Reply: 24 - 51 |
Simon_Pike |
a very handy trip to dunelm today to buy some chester leatherette fabric. a couple of hours work with a staple gun and some wood. really impressed with myself |
Reply: 25 - 51 |
Simon_Pike |
ready to go back in the marcos |
 | Last modified June 3rd, 2019, 10:32:24 by Simon_Pike |
Reply: 26 - 51 |
Simon_Pike |
good result |
Reply: 27 - 51 |
Philip_Davenport |
Posted on: June 3rd, 2019, 19:47:01 |
It's looking very sweet.. |
Owner since March 2019 of SWD 588G Chassis: 7213 |
Reply: 28 - 51 |
Simon_Pike |
Posted on: June 4th, 2019, 08:26:01 |
thanks phil,hope you get your v5 sorted soon and you can crack on with yours,ive just sent mine off |
Last modified June 4th, 2019, 10:00:14 by Simon_Pike |
Reply: 29 - 51 |
