  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  TIME TO REBUILD
0 Members Browsing (37 Guests)
Pages: 1, 2, 3, 4 : All Reply Recommend Print
  Author    TIME TO REBUILD   (currently 2,818 views)
Simon_Pike
Posted on: April 25th, 2019, 14:38:57
MANAGED TO GET MY HANDS ON THIS,VERY VERY LUCKY
MKIV
Last modified May 20th, 2019, 11:45:13 by Simon_Pike
Simon_Pike
Posted on: April 25th, 2019, 14:39:48
EVERYTHING IS NEW ON IT,THE GUY HAD BEEN RSTORING IT FOR 35 YEARS
Private Message Reply: 1 - 51
Simon_Pike
Posted on: April 25th, 2019, 14:40:35
JUST NEEDS FINISHING
Private Message Reply: 2 - 51
Posted on: April 25th, 2019, 16:52:01 Quote Report to Moderator
Nice a quick tidy then on the road.
Private Message Reply: 3 - 51
Philip_Davenport
Posted on: April 26th, 2019, 10:40:03 Quote Report to Moderator
Looks great !
If V registration is 1979, then this car is now historic tax and needs no MOT... so you can drive it on the road as you like .. Happy Days!
Last modified April 26th, 2019, 10:48:31 by Philip_Davenport
Private Message Reply: 4 - 51
Simon_Pike
Posted on: April 26th, 2019, 17:20:10 Quote Report to Moderator
unfortunatly according to the gov website it does need mot and tax as it was built after jan 1979.
But that doesnt matter as it still has the v5 from 1979 and if you apply for a new one they will come and inspect the vechicle to see if its a ringer,but if you get it mot,d first they look at that as being inspected so will supply a new v5
https://www.gov.uk/historic-vehicles
Last modified April 26th, 2019, 17:20:56 by Simon_Pike
Private Message Reply: 5 - 51
Simon_Pike
Posted on: May 14th, 2019, 10:41:05
Picked up a brake conversion kit from himleyhall mini show.
No major problems fitting it,but i did have to grind a bit of the hub carrier to get the bolts to line up
Private Message Reply: 6 - 51
Simon_Pike
Posted on: May 15th, 2019, 13:41:38
Attachment: 60358746_910955849235925_2761451215828025344_n.jpg - 96.40 KB (1449 views)
back on 10,s how it should be
Private Message Reply: 7 - 51
Philip_Davenport
Posted on: May 16th, 2019, 10:03:08 Quote Report to Moderator
that looks the business ...nice !
tell the kids that they can't play basketball in the garden
Last modified May 16th, 2019, 10:04:08 by Philip_Davenport
Private Message Reply: 8 - 51
Posted on: May 17th, 2019, 19:11:19 Quote Report to Moderator
It looks very nice. Mine's a V-reg first registered in 1980 so I'll have to MoT and tax it.
What's that sticking out of the bonnet? It should only need a small bump for a single SU. The original bonnet was designed for twin carbs.
If you want to make a new front panel, the inside of a Mini windscreen makes a good mould.
Last modified May 17th, 2019, 19:17:54 by admin
  Private Message Reply: 9 - 51
Simon_Pike
Posted on: May 17th, 2019, 21:41:48 Quote Report to Moderator
Quoted from admin, posted May 17th, 2019, 19:11:19 at here
Thats the washer bottle it was just resting on the rocker cover,I dont know why the previous owner cut such a big hole in it.new bonnet required I think
Last modified May 18th, 2019, 07:29:20 by Simon_Pike
Private Message Reply: 10 - 51
Simon_Pike
Posted on: May 18th, 2019, 17:24:36
Attachment: 60246831_912524819079028_7192684239148548096_n.jpg - 50.92 KB (1454 views)
Sold those ridiculous 7x13" and at last got my wheels done,
10" mistrals
Last modified May 21st, 2019, 10:04:01 by Simon_Pike
Private Message Reply: 11 - 51
Simon_Pike
Posted on: May 18th, 2019, 17:26:33
Attachment: 60354284_912524839079026_2998861245420929024_n.jpg - 72.56 KB (1443 views)
just needs some arches now
Private Message Reply: 12 - 51
Simon_Pike
Posted on: May 20th, 2019, 09:52:52
Attachment: 60352952_913806158950894_8951041913100697600_n.jpg - 41.66 KB (1441 views)
next job,the saggy headliner.
there was two options on this
1 tear back the headliner from the windscreen,door,rear window pillars
2 cut the headliner straight down the middle
due to the fact it was fitted so well around the pillars and shaped and stuck down really well i didnt wont to do this as and taking the headliner totaly of ones side and getting it stuck back up on my own i would never have got it right.
so option two it was,this allowed me to get access to the rear hinge area aswell.
luckily the seam were i cut in the middle went back really well
Private Message Reply: 13 - 51
Simon_Pike
Posted on: May 20th, 2019, 09:54:26
Attachment: 60510951_913806195617557_6844960006077415424_n.jpg - 60.43 KB (1440 views)
was very worried at this point
Private Message Reply: 14 - 51
Simon_Pike
Posted on: May 20th, 2019, 09:54:56
Attachment: 59980306_913806285617548_25524191776210944_n.jpg - 46.45 KB (886 views)
very happy with the result
Private Message Reply: 15 - 51
Simon_Pike
Posted on: May 20th, 2019, 09:55:34
Attachment: 60453564_913806245617552_2840018485638070272_n.jpg - 50.70 KB (876 views)
and the pillars looked great
Private Message Reply: 16 - 51
Simon_Pike
Posted on: May 20th, 2019, 09:57:06
Attachment: 60508700_913788438952666_2694664620404113408_n.jpg - 75.93 KB (885 views)
was lucky enough to get a set of hinges from himleyhall mini day,but of course they had to be modified to stop them catching on the roof
Private Message Reply: 17 - 51
Simon_Pike
Posted on: May 20th, 2019, 09:58:03
Attachment: 60423525_913788462285997_4202759283072303104_n.jpg - 62.04 KB (875 views)
out with the dremmel
Private Message Reply: 18 - 51
Simon_Pike
Posted on: May 20th, 2019, 09:58:25
Attachment: 60785394_913788498952660_2206176171396169728_n.jpg - 66.24 KB (875 views)
another job completed
Private Message Reply: 19 - 51
Simon_Pike
Posted on: May 24th, 2019, 10:35:22
Attachment: 60744311_916615648669945_1727716415189811200_n.jpg - 55.04 KB (876 views)
its only taken about 16 hours to get the wiring for the rear lights sorted,loom was the wrong way round,numerous earths had to be added,relays,flasher units but they now all work
Private Message Reply: 20 - 51
Simon_Pike
Posted on: May 28th, 2019, 10:09:05
Attachment: 60920124_918401715158005_6211221428180615168_n.jpg - 74.10 KB (883 views)
thought i would have a go at puting the rear screen in today.
wasnt a tough job(once i got the right rubber)and everything went well
Private Message Reply: 21 - 51
Simon_Pike
Posted on: May 28th, 2019, 10:18:29
Attachment: 61193689_919340025064174_7387309367906795520_n.jpg - 65.02 KB (880 views)
well i was on a roll i thought i would tackle the dash wiring,
for some reason the previous owner had decided to refit all the standard mini switches into the original mini switch panel and stuff it up under the dash.
that explains why the lights came on when i connected the battery.
i fitted some nos triumph switches back into the dash(got rid of the mini switches/panel, refitted some gauges and wiring and repplaced all the bulbs(which to my suprise halfords still sell)
know have a fully functional dash
Private Message Reply: 22 - 51
Simon_Pike
Posted on: May 28th, 2019, 10:26:17
Attachment: 61406609_919356061729237_7488501125272829952_n.jpg - 57.63 KB (874 views)
I have a internal door handle missing(mk1/2 bent around the door cards)so was thinking maybe i could extend the square rod and use non bent handles,took the door card off to discover the window is smashed(i havnt rolled it up since i bought it)
so its a quick message to plastic4performance to get some lexan windows so not the end of the world,
it will make it faster anyway less weight
Private Message Reply: 23 - 51
Simon_Pike
Posted on: May 30th, 2019, 09:31:10
Attachment: 61686089_920012978330212_8709173956562649088_n.jpg - 44.31 KB (877 views)
At last the windscreen is in,ended up putting the original screen back in(rather than the new one i had) as it fitted better
this was the hardest job so far even had my daughter and the misses helping
Private Message Reply: 24 - 51
Simon_Pike
Posted on: June 3rd, 2019, 10:31:31
Attachment: 61631072_923188434679333_7799421848009048064_n.jpg - 93.42 KB (879 views)
a very handy trip to dunelm today to buy some chester leatherette fabric.
a couple of hours work with a staple gun and some wood.
really impressed with myself
Private Message Reply: 25 - 51
Simon_Pike
Posted on: June 3rd, 2019, 10:32:12
Attachment: 62045842_923188508012659_4803286180244226048_n.jpg - 60.71 KB (873 views)
ready to go back in the marcos
Last modified June 3rd, 2019, 10:32:24 by Simon_Pike
Private Message Reply: 26 - 51
Simon_Pike
Posted on: June 3rd, 2019, 10:32:58
Attachment: 62222021_923188578012652_7373298441557901312_n.jpg - 56.62 KB (879 views)
good result
Private Message Reply: 27 - 51
Philip_Davenport
Posted on: June 3rd, 2019, 19:47:01 Quote Report to Moderator
It's looking very sweet..
Private Message Reply: 28 - 51
Simon_Pike
Posted on: June 4th, 2019, 08:26:01 Quote Report to Moderator
thanks phil,hope you get your v5 sorted soon and you can crack on with yours,ive just sent mine off
Last modified June 4th, 2019, 10:00:14 by Simon_Pike
Private Message Reply: 29 - 51
Posted on: June 4th, 2019, 18:49:29 Quote Report to Moderator
Some really good progress there Simon!
(Must pull my finger out on mine - ho hum).
Liking the centre console.
Private Message Reply: 30 - 51
Philip_Davenport
Posted on: June 6th, 2019, 13:59:06 Quote Report to Moderator
Simon -- did you get the Lexan windows? Can you share pics? Im thinking of fixed front windows with slider kits in. Ive got two soft top cars (MR2 & Spitfire) for summer, will so use the Marcos more in cooler months - especially in the snow -wicked ..
IMM is mid-August, so maybe 9 weeks of DVLA sh1te if you are taking the Marcos.. Id have no chance. Engine has not run in 30+ years ..
Last modified June 6th, 2019, 14:00:14 by Philip_Davenport
Private Message Reply: 31 - 51
Simon_Pike
Posted on: June 6th, 2019, 21:44:28 Quote Report to Moderator
Yes I did get them,but unfortunately they dont fit as the templates used were for a marcos cars mk4 which have smaller windows. Mines a dh fibreglass mk4
Last modified June 6th, 2019, 22:03:14 by Simon_Pike
Private Message Reply: 32 - 51
Philip_Davenport
Posted on: June 7th, 2019, 07:51:33 Quote Report to Moderator
Sorry to hear that. A pain in butt ! So what do you do next about them?
Private Message Reply: 33 - 51
Simon_Pike
Posted on: June 7th, 2019, 08:41:03 Quote Report to Moderator
Quoted from Philip_Davenport, posted June 7th, 2019, 07:51:33 at here
make a template from my remaining original window and get them remade,hopefully sell the other ones
Private Message Reply: 34 - 51
Simon_Pike
Posted on: June 11th, 2019, 09:18:51
Attachment: 62138644_928463114151865_211200060388540416_n.jpg - 47.64 KB (1047 views)
thanks to craig smith for making the harness brace bar
harness fitted another job done
Private Message Reply: 35 - 51
Simon_Pike
Posted on: June 11th, 2019, 09:19:57
Attachment: 62256110_929189187412591_9089858065016029184_n.jpg - 51.62 KB (1048 views)
had a little play around fitting arches need to cover those wide wheels,not the best arches but they are the perfect width
Private Message Reply: 36 - 51
Simon_Pike
Posted on: June 11th, 2019, 09:20:21
Attachment: 62247507_929189220745921_6944217941533523968_n.jpg - 45.58 KB (1046 views)
rear looks ok
Private Message Reply: 37 - 51
Simon_Pike
Posted on: June 14th, 2019, 09:29:00
Attachment: 62307166_929795420685301_4209288496650649600_n.jpg - 68.93 KB (1049 views)
had to take the wiper motor apart and turn the cog 180 degrees,
now the wiper blades stop on the passenger side not the drivers side
Private Message Reply: 38 - 51
Simon_Pike
Posted on: June 14th, 2019, 09:30:45
Attachment: 64784066_931729640491879_8389548404564295680_n.jpg - 44.02 KB (1043 views)
managed to get the bonnet secured down,unfortunatly the previous owner had cut the lip off at the front.
just need to sort the big hole out or stick a v8 in it with a holley carb out the bonnet
Private Message Reply: 39 - 51
Simon_Pike
Posted on: July 12th, 2019, 14:14:30
Attachment: 64267861_932102247121285_7676914803608125440_n.jpg - 78.64 KB (1046 views)
been having a look around trying to find something to cover the massive bonnet hole.
found a bonnet vent for a mitsubishi l200,i dont think it looks to bad,its only until i get a new bonnet
Private Message Reply: 40 - 51
Simon_Pike
Posted on: July 12th, 2019, 14:15:31
Attachment: 64576388_932102270454616_6439623519784402944_n.jpg - 68.41 KB (1043 views)
pretty good
Private Message Reply: 41 - 51
Simon_Pike
Posted on: July 12th, 2019, 14:20:44 Quote Report to Moderator
thinks havnt been going to good lately,
I re-ordered a new drivers window in the new dimensions as the previous ones i ordered were the wrong size.
Waited 5 weeks and they had sent me the same old dimension windows,so thats another long wait for replacements
and now i found out the dvla never received my v5 after 6 weeks of waiting(yeh of course it was lost in the post)
So now there will be no imm in the marcos for me
Private Message Reply: 42 - 51
Simon_Pike
Posted on: July 19th, 2019, 09:54:31
Ive been staying out of the garage for the last 3 weeks due to the problems with the dvla and a certain plastics company,just totaly took the wind out of my sails and put me right off the marcos.
But i did venture into the garage last night and though i would have another go at making a door handle as i had one left after the last one melted.
over the moon i actually managed it
Private Message Reply: 43 - 51
Simon_Pike
Posted on: July 19th, 2019, 09:55:10
top job
Private Message Reply: 44 - 51
Simon_Pike
Posted on: July 19th, 2019, 09:56:08
Ive got a pair now
Private Message Reply: 45 - 51
Simon_Pike
Posted on: August 22nd, 2019, 09:54:34 Quote Report to Moderator
just an update on the marcos
sent v5 off on the 4th june and iam still waiting
Private Message Reply: 46 - 51
Posted on: August 26th, 2019, 19:58:44 Quote Report to Moderator
Well worth chasing DVLA if you've not done so already. Had to do this when I bought my Marcos some years ago, the previous V5 was from the late 1980s so had probably been lost in their system somewhere!
Last modified August 26th, 2019, 19:58:56 by Simon Robinson
Private Message Reply: 47 - 51
Simon_Pike
Posted on: October 26th, 2019, 12:34:23 Quote Report to Moderator
At last after 16 weeks i have the new v5
and only one owner
the only thing is i have to send it back in november for the historic class
dont think i will bother
Private Message Reply: 48 - 51
Simon_Pike
Posted on: December 11th, 2019, 17:16:34
last piece of the puzzle granada mk1 window winders
Private Message Reply: 49 - 51
Simon_Pike
Posted on: January 13th, 2020, 12:31:31
Attachment: 82348711_1102737196724455_752030253630619648_n.jpg - 96.11 KB (951 views)
first proper outing 100 mile round trip to llandudno
wipers were hardly touching the window and couldnt see much as it was raining very hard,then drivers wiper fell off just manage to catch it before it dissapered down the dual carrage way,then when it stopped raining the wipers wouldnt turn off,indicators stopped working and at one point carb stuck open at full revs.
so all in all a normal drive out in a kit car LOVED IT
Private Message Reply: 50 - 51
Simon_Pike
Posted on: January 13th, 2020, 12:32:30
Attachment: 81833384_1102737186724456_7193747106115354624_n.jpg - 83.18 KB (951 views)
the worsley just happens to be one of my old cars aswell
Private Message Reply: 51 - 51
Powered by e-blah Platinum 7 Final © 2001-2004   -   January 19th, 2021, 02:55:05
Files opened: 168 | Files closed: 168
