  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Build of Chassis # 8074
  Author    Build of Chassis # 8074  (currently 1 views)
Mike_Todd
Posted on: August 23rd, 2024, 17:03:28 Quote Report to Moderator
I am building up MM Mk4 chassis 8074 and I have refurbished all the suspension and subframes and they are assembled ready to fit to the car. The engine and gearbox have been stripped ready for machining/ rebuild but this may take some time as the company who are doing the machining are quoting a few months lead time. This has prompted a couple of questions:
1) I could fit the subframes to the body now and fit the engine later. Is there any advantage doing this versus installing the engine in the subframe first and then putting the complete unit into the car?
2) I don't yet have an exhaust manifold. I know that the manifold can end up very tight to the body so are there any manifolds that I should avoid or ones that fit better than others. I am looking to fit a slightly upgraded manifold over standard
I am also looking to source a rear roll bar to fit into the body. Does any company offer these for the Mk4 or is it a case of getting them custom made to fit an individual car?
Thanks for any guidance
Posted on: August 23rd, 2024, 17:13:02 Quote Report to Moderator
Yes you can fit the engine throught he top but it is tight and you'll need to remove the clutch cover.
The last Marcos I had I used a maniflow lcb and I don't recall any problems.
Rollcentre used to do a kit for the MK4  but that was a long time ago. Owens fabrication have done a couple of cages now for mini Marcos, so give them a try.
Private Message Reply: 1 - 4
Posted on: August 23rd, 2024, 19:57:27 Quote Report to Moderator
Yes, it's easier to mount the engine on the subframe then drop the body on to it. You need to put packing pieces between the tails of the subframes and the floor pan. I've put a piece of galvanised wirebetween the back subframe bolts to catch the down pipe when it comes off (as it does).
I have a Maniflow big bore exhaust system on my Mk.IV. I've used various manifolds in the past, with RC40 2-can silencers.
I recall thst Caged made roll cages for the Marcos Heritage Mk. VI which has basically the same internal dimensions.
Richard
  Private Message Reply: 2 - 4
Mike_Todd
Posted on: March 5th, 2025, 21:03:45 Quote Report to Moderator
The build continues and I am now looking at how to fit out the interior. Do people generally fit sun visors or not bother (I have been looking a simple mini ones). If so are there any recommendations on how to fix them to the roof. There are no obvious signs of visors being fitted in the past.
Also a question with respect to the fuel tank sender. I have installed a new mini van tank and the sender which came with the car, the ohms range on this sender is something like 0-80 ohms. No gauges came with the car so I'm looking to source a fuel gauge to match to this sender - any recommendations?
Many thanks
Private Message Reply: 3 - 4
Posted on: March 9th, 2025, 21:05:09 Quote Report to Moderator
Standard Smiths Fuel gauge is what I used, with the Mini Van fuel tank you arent going to get a gauge thats spot on anyway. As long as you know where empty is you'll be fine.
Private Message Reply: 4 - 4
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 10th, 2026, 17:04:59
Files opened: 113 | Files closed: 113
