  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Rebuilding engine
0 Members Browsing (40 Guests)
Pages: 1, 2, 3, 4 » : All Reply Recommend Print
  Author    Rebuilding engine  (currently 2,024 views)
Gert-Jan Westerveld
Posted on: October 5th, 2007, 20:59:33 Quote Report to Moderator
this is my spare engine
it is a inno engine
I found it in a scrap yard, end I started it on the floor
http://www.youtube.com/watch?v=fSb9pFDHAAw
Rebuild engine  1312CC  .
Last modified November 24th, 2007, 15:31:29 by Gert-Jan Westerveld
Gert-Jan Westerveld
Posted on: November 24th, 2007, 15:23:25 Quote Report to Moderator
Hello
I planed to fit a spare engine bud sadly it isn't possible to make it a quick fit, so I've  put the engine in a corner fore another project.
Now I am going to rebuild my engine, to day I took of the gear linkage and a lot of the other stuff that needs to come of before we take the engine out.
Private Message Reply: 1 - 46
Posted on: November 24th, 2007, 18:18:58 Quote Report to Moderator
Good luck with the build, I hope your garage has a good heater.
Private Message Reply: 2 - 46
Gert-Jan Westerveld
Posted on: December 24th, 2007, 20:21:57 Quote Report to Moderator
Hello, after a little time of work on another car. (bought myself a mini   for daily transport) end very busy with my new job. ( starting Feb 2008 )
I had to do some things on the Marcos, first is taking the engine out. We did some research of  this. We, is may dad and I.
The research said take the engine out trough the top, so we rented a hoist.
And started it, half way trough it be came clear it was a very tithe fit. We found it to tithe.
So the idea was, to put the engine back on its place, and take the sub frame and engine out from under the car. Because it is a holiday there was no time to get spec tools. So we did it with raw power. My brother and I , we picked the front of the car and lifted it over the engine and sub frame.
This went very well, although you need to coordinate the several steps.
As we are really good team players it worked really great.
[img][/img]
Last modified January 12th, 2008, 19:33:07 by Gert-Jan Westerveld
Private Message Reply: 3 - 46
Posted on: December 25th, 2007, 11:31:42 Quote Report to Moderator
The approved method is to lift the body off the subframe. I can take the engine out single-handed, using a couple of jacks to raise the body and axle stands to support it. It's easier if you take the head off first and remove the head studs, so you don't need to raise the front so high.
  Private Message Reply: 4 - 46
Gert-Jan Westerveld
Posted on: December 30th, 2007, 12:07:29 Quote Report to Moderator
With the engine is on a work-bench, it is time to strip it. First of will be the clutch and flywheel, with the wright tools and a good medium hammer it sprung loose. (watch your feet)
Last modified January 12th, 2008, 19:34:27 by Gert-Jan Westerveld
Private Message Reply: 5 - 46
Posted on: December 30th, 2007, 15:35:37 Quote Report to Moderator
Perhaps it's just me, but I can see the pics from your last 2 posts Gert-Jan
Private Message Reply: 6 - 46
Joost van Dien
Posted on: December 30th, 2007, 22:59:41 Quote Report to Moderator
I cant see them too!
Private Message MSN Reply: 7 - 46
Posted on: December 31st, 2007, 11:32:35 Quote Report to Moderator
There are seven broken URLs which just return an empty page. That site just returns nothing unless you give it a valid argument. Try an alternative site like photobucket, or just upload the pics one at a time.
Last modified December 31st, 2007, 11:40:06 by admin
  Private Message Reply: 8 - 46
Gert-Jan Westerveld
Posted on: January 1st, 2008, 11:22:49 Quote Report to Moderator
I don't get it.
I see them.
Private Message Reply: 9 - 46
Posted on: January 1st, 2008, 13:22:44 Quote Report to Moderator
The site you've chosen uses Windows Live ID which guarantees it won't be compatible with a lot of browsers and platforms. Also it's possible that the site limits hot-linking to five images. As you have an account  that probably won't apply to you so you can see all of your own photos.
Last modified January 1st, 2008, 13:45:12 by admin
  Private Message Reply: 10 - 46
Gert-Jan Westerveld
Posted on: January 2nd, 2008, 19:55:33 Quote Report to Moderator
I still don't get it I always did it like this.
Last modified January 2nd, 2008, 19:56:04 by Gert-Jan Westerveld
Private Message Reply: 11 - 46
Gert-Jan Westerveld
Posted on: January 12th, 2008, 19:55:41 Quote Report to Moderator
Today I removed the cylinder head, here I found an oil track.
I think de head gasket wasn't the right one. So now I am thinking of placing a copper gasket.
I also examined the studs and bolts, how often can we use these nuts and studs?
Some of these studs I measured and found out that the length has become longer then the spec's.
Private Message Reply: 12 - 46
Gert-Jan Westerveld
Posted on: January 12th, 2008, 19:57:56 Quote Report to Moderator
I hope that you can see the photos.
Private Message Reply: 13 - 46
Posted on: January 13th, 2008, 10:26:14 Quote Report to Moderator
Mini Spares in London do higher quality cylinder head studs and nuts. In fact they do 2 types, their own and some incredibly priced versions. If you do fit a copper head gasket make sure it's a genuine one as there are some poor quality replacements out there.
Last modified January 13th, 2008, 10:26:43 by John Dickens
Private Message Reply: 14 - 46
Powered by e-blah Platinum 7 Final © 2001-2004   -   April 11th, 2021, 21:24:13
Files opened: 97 | Files closed: 97
