  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  feul tank
0 Members Browsing (5 Guests)
  Author    feul tank  (currently 675 views)
koen
Posted on: April 22nd, 2008, 17:28:49 Quote Report to Moderator
hello im from belguim and my english is very bad.
i hope somewhone can help me
can somewhone help me with the feul tank my filling nek is to short how dos it fit?can it with some photos?how the filling nek must be instald.
greats
Gert-Jan Westerveld
Posted on: April 22nd, 2008, 19:41:55 Quote Report to Moderator
Hello Koen welcome.
wich type of marcos do you owne ??
I have a MK4, I can send you some photo's
(je mag mij ook in het Nederlands Mailen)
greats GJ
Rebuild engine  1312CC  .
Last modified April 22nd, 2008, 19:42:46 by Gert-Jan Westerveld
Private Message Reply: 1 - 5
Tertius van Zyl
Posted on: April 23rd, 2008, 07:39:10
Reputation: -1 (tot: -1)
Hi Koen
The following is taken from the original Mk3 "Build sheet".
"FUEL TANK
A Mini van fuel tank must be fitted in the Mini Marcos; before installing the tank cut off the filler pipe 2" from the base. Apply a sealing compound around the tank aperture and place the tank into position from inside the car. Drill ¼" holes in the floor to line up with the holes in the flange and secure the tank. Place the original grommet into the filler pipe hole in the body and insert the top half of the filler pipe. Connect this to the tank with 2" internal diameter hose and hose clips (Assembly Kit). A Mini van fuel gauge sender unit must then also be fitted."
I was told, when doing mine, that you have to have a "fuel resistant" hose otherewise the hose could be affected by the fuel and could fail.
Attached is a pic (not too good) of my set-up. You can see the hose and hose clamps.
Hoop dit sal goed gaan met jou bou van die Marcos.
Private Message Reply: 2 - 5
Posted on: April 23rd, 2008, 09:54:35 Quote Report to Moderator
Despite the build sheet, I think you need 2?" ID (63.5mm) rubber pipe to connect.
R
  Private Message Reply: 3 - 5
koen
Posted on: May 15th, 2008, 19:50:09 Quote Report to Moderator
where can i buy a rubber pipe on the internet for the marcos?
Private Message Reply: 4 - 5
Garry Scott
Posted on: May 15th, 2008, 20:53:03 Quote Report to Moderator
try demon tweeks or merlin motorsport they should do it!
  Private Message Reply: 5 - 5
Powered by e-blah Platinum 7 Final © 2001-2004   -   July 4th, 2025, 02:39:03
Files opened: 41 | Files closed: 41
