Yippeeee I've got myself a MkIV (currently 6,608 views) |
Posted on: January 9th, 2009, 19:10:35 |
Yes mate I was very surprised just how different the MkIV is compared to the MkIII in many areas.
Still, if it's stiffer it should go around corners better
You have Yahoo email btw. |
Reply: 15 - 50 |
Posted on: January 9th, 2009, 19:31:31 |
I'm surprised at that. My Mk.IV is definitely more flexible than the Jem (which is more like the Mk.III). It tends to wind itself up first and then go round the corner whereas the Jem does what it's told straight away. |
Reply: 16 - 50 |
Joost van Dien |
Posted on: January 9th, 2009, 19:35:15 |
Reply: 17 - 50 |
Posted on: July 12th, 2009, 10:14:13 |
The decideldly average British summer has meant that progress on the bodywork has been slower than I would have liked, so yesterday I moved the Marcos to a garage in Stoke.
I've only got the garage for 8 weeks or so, but it should enable me to make some headway, and not have to worry about the weather!
Reply: 18 - 50 |
Tim Frankland |
Posted on: July 12th, 2009, 14:11:11 |
That looks like a dream garage. Good to see pictures of the progress, good luck with the work! |
Reply: 19 - 50 |
Joost van Dien |
Posted on: July 13th, 2009, 17:08:31 |
Reply: 20 - 50 |
Posted on: July 16th, 2009, 16:50:09 |
Hmmm, no price. I think I'll stick to the one I've started now  |
Reply: 21 - 50 |
Posted on: July 18th, 2009, 21:56:05 |
Progress!!
Now all I have to do is train Jonathon to run at 70mph whilst holding the new front on!
Many thanks to Alan Brown for supplying me with the front end. |
Reply: 22 - 50 |
Joost van Dien |
Posted on: July 19th, 2009, 16:22:27 |
Way have you grinded the front out? I had the same cracks on my yellow car and you can easily fiberglass it back in place from the inside. Then grind the cracks on the outside en fiberglass that as well. So you can save you frontend for later on! |
Reply: 23 - 50 |
Allan Brown |
Posted on: July 19th, 2009, 19:28:13 |
Glad I could help. It's looking good. So it will be ready for the Marcos 50th then  |
Reply: 24 - 50 |
Posted on: July 19th, 2009, 20:00:54 |
Hi Joost,
Unfortunately there was very little fibre glass left, who ever had repaired it previously just used a bucket full of body filler to fill a big hole. Here is a lump of it after removal..
Quoted Text |
Unfortunately not
When's the next big occasion??
Reply: 25 - 50 |
Syd Crawford |
Posted on: July 19th, 2009, 22:42:56 |
Whoa! Never seen a lump of bog that thick before!  Good to see the progress  Having a nice garage to work in makes a big difference. Love my garage . |
Reply: 26 - 50 |
Phil Lockett |
Posted on: July 20th, 2009, 09:18:03 |
Hey Craig,
Where you have rubbed it diwn on the roof and the rear end it seems to be standard D&H "Instant Fade" Orange gelcoat.
The front seems to be baby blue gelcoat - has it had another front end on it in the past do you think? |
1983 GTM Coupe. Powered by Toyota 4A-GE. Siva Moonbug |
Reply: 27 - 50 |
Joost van Dien |
Posted on: July 21st, 2009, 16:45:26 |
I see why you grinded it out . yeas that guy had some cash in an bodyfiller-factory xD. Keep up the good work!!
Cheers |
Reply: 28 - 50 |
Posted on: July 21st, 2009, 20:43:23 |
Quoted from Phil Lockett, posted July 20th, 2009, 09:18:03 at here |
Hey Craig,
No mate, thats yet more filler that had been applied over the damage.
Here it is after sanding it off, and grinding out the cracks..
Last modified July 21st, 2009, 20:49:58 by Craig Smith |
Reply: 29 - 50 |
