  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Yippeeee I've got myself a MkIV
0 Members Browsing (43 Guests)
Pages: « 1, 2, 3, 4 : All Reply Recommend Print
  Author    Yippeeee I've got myself a MkIV  (currently 2,797 views)
Posted on: May 23rd, 2013, 21:07:25 Quote Report to Moderator
I spent ages modifying the clutch pedal to take the cable, I wanted it to go straight out through the bulkhead rather than down. Then after all the work I decided that I'll probably go with a slave cylinder and hydraulic system.
Private Message Reply: 45 - 50
Posted on: May 23rd, 2013, 21:45:39 Quote Report to Moderator
Neil, got to say that the pedal was by far the easiest part of the conversion yet.  I simply cut off the lug that ordinarily pushes, and turned it upside down and welded it onto the other side of the pedal arm (so that it pulls rather than pushes), with a notch cut out to take the cable (where the clevis pin normally goes).  Other than that it was just a case of adding an adjustable 'stop' so that the pedal didn't float and had a firm positon to return to against the spring and sits at the correct height
I did for a moment consider hydraulic, but it seemed far more work, and I can say that the clutch feels really light which is an added bonus
Private Message Reply: 46 - 50
Allan Brown
Posted on: May 25th, 2013, 20:59:39 Quote Report to Moderator
What are you doing with the driveshafts?
Do the Micra shafts fit?
That is one reason why my Suzuki Swift conversion stopped due to having to get custom shafts made.
Private Message Reply: 47 - 50
Posted on: May 26th, 2013, 10:22:35 Quote Report to Moderator
The Micra splines are identical to the Mini's so it's just a matter of getting them shortened, I got mine cut and sleeved for 100.
One of the guys in the I.M.O.C. has a Swift conversion, he got his drive shafts shortened and tig welded at a local engineering place for 150
Private Message Reply: 48 - 50
Posted on: May 29th, 2013, 04:26:01 Quote Report to Moderator
I have heard that Neil, but I have never offered them up, and I always intended to go with  a "spliced" approach using Nissan inner and standard Mini outer CV's - just because - errm well I didn't think they would fit / work.
The Nissan outers look huge compared to the Mini, can I really just shorten the drive shafts and thats it??
< Ramble>  Currently working in Dallas, so have absolutely no way of checking for myself for at least two weeks - Now if you want a 5.x v8 - this is the place to be..  In Tx bigger IS better, and my 'Compact' just doesn't cut it
Private Message Reply: 49 - 50
Posted on: May 29th, 2013, 12:16:21 Quote Report to Moderator
Here are the shafts that I had done.
The hole in the sleeve was slightly undersized and then the sleeve was heated and the two shafts were fitted to give the desired length before being welded. Welds were then cleaned up on a lathe and then the shafts were spun between centres to check for trueness and any imbalance.
Private Message Reply: 50 - 50
Powered by e-blah Platinum 7 Final © 2001-2004   -   April 11th, 2021, 01:38:17
Files opened: 86 | Files closed: 86
