  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  MM 7496
0 Members Browsing (5 Guests)
  Author    MM 7496   (currently 1,823 views)
AK
Posted on: November 7th, 2012, 22:25:12 Quote Report to Moderator
hi, i'm Alexis an enthusiast about classic mini and also mini marcos , i recently bought this one
she has got the serial number :7496.
and a first registration date in 1984.
a complete restoration it's now engaged !
AK
Posted on: November 7th, 2012, 22:28:59 Quote Report to Moderator
she has got a new  garage
she is under cleaning
[/quote]
Private Message Reply: 1 - 21
AK
Posted on: November 7th, 2012, 22:32:35 Quote Report to Moderator
after use the hight pressure cleaner
i have a look about body working :
cut off the roof ( to make it plane)
fix a new dashboard
repaired the front noze
cut off a air box emplacement
[/quote]
Private Message Reply: 2 - 21
AK
Posted on: November 7th, 2012, 22:33:53 Quote Report to Moderator
fixing of the  roll cage
Private Message Reply: 3 - 21
AK
Posted on: November 7th, 2012, 22:36:12 Quote Report to Moderator
that progresses
roll cage it's machining
Private Message Reply: 4 - 21
AK
Posted on: November 7th, 2012, 22:37:29 Quote Report to Moderator
We look for the rust
Private Message Reply: 5 - 21
Damien Marais
Posted on: November 7th, 2012, 23:49:53 Quote Report to Moderator
Du boulot !!!
Ton garage me fait toujours rÍver ...
J'attends de voir la suite sur miniracing aussi !
Mini mayfair 1300
Marcos mk4
Private Message MSN Reply: 6 - 21
Denis
Posted on: November 8th, 2012, 09:45:16 Quote Report to Moderator
Vraiment du beau travail mais encore beaucoup travail pour venir belle.
Nice job.
Private Message Reply: 7 - 21
Nigel_Holmes
Posted on: November 8th, 2012, 18:58:59 Quote Report to Moderator
Alexis - that's the cleanest and tidiest garage I have seen for a long time!
Some interesting upgrades in the past, I don't think the panelling over the petrol tank is a factory item but it should stiffen up the rear window nicely.
For the roll cage are you planning to fit large load spreading plates at the end of the tubes, in particular the ones at the heelboard could be tricky as they are in an enclosed box section?
Best regards, Nigel
Private Message Reply: 8 - 21
Posted on: November 9th, 2012, 18:27:06 Quote Report to Moderator
You're right Nigel - definitely a case of garage envy!
Also at the pace you seem to be progressing at Alexis.
A bit OT but do you know the make of your engine stand?  I'm after one that will hold the A-Series.
Looking at your location I'm tempted to aim for the 2014 Le Mans Classic to get my car on the road by - it's always good to dream  .  Good luck with your build.
Private Message Reply: 9 - 21
Posted on: November 9th, 2012, 18:28:52 Quote Report to Moderator
Private Message Reply: 10 - 21
AK
Posted on: November 10th, 2012, 16:53:21 Quote Report to Moderator
Quoted from Nigel_Holmes, posted November 8th, 2012, 18:58:59 at here
as you can see it's not easy to keep the garage tidy.
For the roll cage it's planning to fit large spreading plates at the end of the tubes , may be like this for the hellboard
to Graham
this is an universal engine stand, like this :
for the moment, the gear box it's fixed on the stand by the final drive bolt †(4 bolts) , i have to create a specifique spacer to fix the engine block on it ( may be by the timing side)
Last modified November 10th, 2012, 18:56:24 by AK
Private Message Reply: 11 - 21
Allan Brown
Posted on: November 11th, 2012, 21:13:34 Quote Report to Moderator
Hi and welcome,
I thought my garage was big, but yours is massive.
Have you tried the seat in for position? Your rear roll hoop looks a long way forward. I hope you have short legs or your head will be hitting the roll hoop.
Good luck with the build
Allan
Private Message Reply: 12 - 21
AK
Posted on: November 19th, 2012, 15:38:03 Quote Report to Moderator
so , seats have just arrived it short but it's okay with the roll cage.
Private Message Reply: 13 - 21
Posted on: November 19th, 2012, 20:46:15 Quote Report to Moderator
Bloody Hell!  He's got the seats fitted already
(Nice seats by the way Alexis)
Private Message Reply: 14 - 21
Powered by e-blah Platinum 7 Final © 2001-2004   -   April 12th, 2021, 19:52:55
Files opened: 37 | Files closed: 37
