  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Mini marcos  8410 Spain (+++ PHOTOS)
0 Members Browsing (6 Guests)
Pages: « 1, 2, 3, 4, 5, 6, 7, 8 » : All Reply Recommend Print
  Author    Mini marcos  8410 Spain (+++ PHOTOS)  (currently 10,458 views)
Posted on: April 2nd, 2014, 09:41:31
Insides of doors, Jem left.
  Private Message Reply: 15 - 106
Posted on: April 2nd, 2014, 09:46:46
From above. Note the frame on the Jem goes into the slot; on the Marcos it just screws onto the face. The Jem has no external handles so it has a panel lock to secure the drop light from outside. The white door is off my TMJ. The spare ones are painted black and have hinges.
  Private Message Reply: 16 - 106
Cristian Sammartin Castro
Posted on: April 2nd, 2014, 14:20:59 Quote Report to Moderator
good afternoon, thank you very much for the info, I first want to disassemble and remove the doors you have now, and if you keep looking at the frames of the original door, and then with quiet time and try to get some original doors or a mold to manufacture,
Private Message Reply: 17 - 106
Posted on: April 2nd, 2014, 14:22:18 Quote Report to Moderator
can someone explain to me the difference between a mini frames mk1, 2 and 3 of a mini frames mk4?, external dimensions, inside dimensions? thanks
Private Message Reply: 18 - 106
Posted on: April 2nd, 2014, 14:42:05 Quote Report to Moderator
I think the window frames, where fitted, are the same dimensions for all marks of Mini Marcos. The main difference is that the Marcos ones were usually polished or chromed brass whereas the D&H ones were formed of aluminium channel painted black. I haven't got the dimensions to hand but I have obtained a new set of Lexan door windows for a Mk.IV from ACW Motorsport Plastics so they may have patterns. If not I can make some.
  Private Message Reply: 19 - 106
Posted on: April 2nd, 2014, 15:29:31 Quote Report to Moderator
thanks for your help, I've asked on this page (http://www.rory.uk.com/) and doors have a new mini mk5 frames? are the same of a MK4? , Have some up to internal and external dimensions of the body of the mini marcos mk4? thanks
Private Message Reply: 20 - 106
Posted on: April 2nd, 2014, 16:31:06 Quote Report to Moderator
Mk4 and mk5/6 doors are the same except for the catches mk4 uses mk1/2 mini catches mk5 on uses later mini catches. I'm fairly sure mk3 and 4 doors are the same aswell but that needs confirming. I have moulds for mk4 doors but I think I changed the catch set up as I made them for a mk5. I can make some for 250 a pair plus postage but I can't help with the metal frames.
Private Message Reply: 21 - 106
Grant Wilson
Posted on: April 2nd, 2014, 18:03:15 Quote Report to Moderator
LeMans -- 2016
Hi,
On the subject of door frames.....mine are goosed..can anyone help ???
Grant
Private Message Reply: 22 - 106
Posted on: April 2nd, 2014, 18:57:52 Quote Report to Moderator
Mike brown Are the doors that you can make the same to the doors mk4 original??, to put the windows of Plexiglas is it necessary to have the frame of the door? Thank you
Private Message Reply: 23 - 106
Posted on: April 2nd, 2014, 21:13:13 Quote Report to Moderator
Yes the moulds were take from mk4 doors though the catch area may require work as I can't remember what I did there as the doors I made were to take later mini catches.
It is possible to fit frameless perspex windows we have fitted them on my brothers (allan brown) mk3 race mini Marcos though possibly not the best thing for a road car.
Private Message Reply: 24 - 106
Posted on: April 3rd, 2014, 15:48:22 Quote Report to Moderator
ok thank you very much, within 15 days I will find the mini marcos to my house, I'll dismantle whole and looked at him and then the doors, thanks
Private Message Reply: 25 - 106
Posted on: April 3rd, 2014, 15:49:05 Quote Report to Moderator
fantastic race  mini marcos mike
Private Message Reply: 26 - 106
Martin_Loram
Posted on: April 4th, 2014, 06:37:11 Quote Report to Moderator
Hi mike as anyone got a mould to make a one piece re- moveable front end as per mk 6 or trans xl shape and what sort of money are we looking at many thanks Martin
Private Message Reply: 27 - 106
Posted on: April 4th, 2014, 09:18:53 Quote Report to Moderator
My brother has the mould for his race car above I has no headlight recess and the wheel arches are wrong but I do have some bits I can put in the mould that return it to standard ish. Pm me for price etc.
Private Message Reply: 28 - 106
Posted on: April 10th, 2014, 13:41:17 Quote Report to Moderator
Cristian,
Your car was converted to Gullwing by Mike Crawley, from Shavington in Crewe.. I've not seen him for a few years now, so not sure if he still lives there.
Last modified April 11th, 2014, 16:54:22 by Craig Smith
Private Message Reply: 29 - 106
Powered by e-blah Platinum 7 Final © 2001-2004   -   June 25th, 2022, 13:26:37
Files opened: 44 | Files closed: 44
