Mini marcos 8410 Spain (+++ PHOTOS) (currently 10,457 views) |
Cristian Sammartin Castro |
Posted on: August 14th, 2015, 22:10:52 |
Reply: 90 - 106 |
Posted on: August 14th, 2015, 22:17:13 |
Reply: 91 - 106 |
Posted on: August 14th, 2015, 22:19:10 |
Reply: 92 - 106 |
Posted on: February 12th, 2016, 21:15:48 |
Reply: 93 - 106 |
Posted on: February 12th, 2016, 21:17:37 |
Reply: 94 - 106 |
Posted on: February 12th, 2016, 21:20:09 |
Reply: 95 - 106 |
Posted on: February 12th, 2016, 21:21:49 |
Reply: 96 - 106 |
Damien Marais |
Posted on: February 12th, 2016, 23:01:48 |
Reply: 97 - 106 |
Posted on: February 13th, 2016, 10:15:46 |
Because the fiber had cracks below gel coat
Reply: 98 - 106 |
Posted on: February 13th, 2016, 10:17:33 |
Reply: 99 - 106 |
Posted on: February 13th, 2016, 10:20:12 |
is necessary to give the gel coat when is finished fiber? Thanks |
Last modified February 13th, 2016, 10:20:28 by Cristian Sammartin Castro |
Reply: 100 - 106 |
Posted on: February 13th, 2016, 19:37:08 |
No gelcoat is mainly cosmetic and uv protection but high build primer and paint will do the same job. Looking good by the way but I don't envy the sanding job to get it looking smooth again. Mike |
Reply: 101 - 106 |
Posted on: February 14th, 2016, 11:59:39 |
I prefer sanding, priming and painting and not put gel coat , but there is still a lot of work on the body |
Reply: 102 - 106 |
Posted on: February 14th, 2016, 17:57:52 |
Believe me fairing in primer/filler is a lot easier than doing it with gelcoat. Gelcoat is harder wearing than paint but most cars end up filled and painted anyway so as long as you remove or glass over all the cracks you'll have no problems if you don't the cracks will show through the filler/paint quicker than they would gelcoat. Mike |
Reply: 103 - 106 |
Posted on: February 14th, 2016, 23:20:15 |
that primer for the body ? and model paint ? Thanks |
Reply: 104 - 106 |
