  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Mk3 Mini Marcos - 075 battery option
0 Members Browsing (5 Guests)
  Author    Mk3 Mini Marcos - 075 battery option  (currently 454 views)
Nigel_Holmes
Posted on: January 8th, 2015, 19:31:21 Quote Report to Moderator
For info, anyone looking to replace their battery in Mk3 (or earlier?) Mini Marcos, the 075 size battery fits into the standard battery box, just.
The 075 is a good upgrade, gives a useful increase in Amp-hr capacity and also cranking current is higher which is useful on cold mornings.
Posted on: January 8th, 2015, 19:45:19 Quote Report to Moderator
I've been using a Bosch S5 Silver 075 in the MM for a couple of years now, after the last one gave out. No problems and as mentioned a lot more current - which is good when the winter chill is about...came with a 5 year guarantee as well.
Private Message Reply: 1 - 3
Posted on: January 8th, 2015, 19:52:48 Quote Report to Moderator
I have one of these tucked behind the dashboard :
http://www.ballisticparts.com/product_info.php?cPath=141&products_id=428
1.5kg, and it starts my high compression (with gear reduction starter) motor no problem.
For one of my road worthiness tests, I had to run the headlights (low beam) and running lights for 45 mins witness car running. Not part of the requirements, but we had to start the car 10+ times after that for other tests, and had no problems.
Private Message Reply: 2 - 3
Posted on: January 9th, 2015, 12:00:13 Quote Report to Moderator
I've found the Cooper S battery, 057, is fine, but I wouldn't use the standard Mini battrery on a 1275.
  Private Message Reply: 3 - 3
Powered by e-blah Platinum 7 Final © 2001-2004   -   April 12th, 2021, 19:53:37
Files opened: 34 | Files closed: 34
