  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  370 JEA Rebuild
0 Members Browsing (61 Guests)
Pages: 1, 2, 3, 4 : All Reply Recommend Print
  Author    370 JEA Rebuild  (currently 5,013 views)
David_Farmer
Posted on: April 6th, 2018, 09:16:30
There once was an ugly duckling...
David_Farmer
Posted on: April 6th, 2018, 09:17:56
Private Message Reply: 1 - 57
David_Farmer
Posted on: April 6th, 2018, 09:18:24
Private Message Reply: 2 - 57
David_Farmer
Posted on: April 6th, 2018, 09:18:58
Private Message Reply: 3 - 57
David_Farmer
Posted on: April 6th, 2018, 09:19:25
Private Message Reply: 4 - 57
David_Farmer
Posted on: April 6th, 2018, 09:19:49
Private Message Reply: 5 - 57
David_Farmer
Posted on: April 6th, 2018, 09:20:21
Private Message Reply: 6 - 57
David_Farmer
Posted on: April 6th, 2018, 09:22:16
I was going to get it roadworthy first before the restoration, but everything was junk, so I just stripped it back to a shell.
Private Message Reply: 7 - 57
David_Farmer
Posted on: April 6th, 2018, 09:22:47
Private Message Reply: 8 - 57
David_Farmer
Posted on: April 6th, 2018, 09:23:12
Private Message Reply: 9 - 57
David_Farmer
Posted on: April 6th, 2018, 09:23:33
Private Message Reply: 10 - 57
David_Farmer
Posted on: April 6th, 2018, 09:23:59
Private Message Reply: 11 - 57
David_Farmer
Posted on: April 6th, 2018, 09:24:27
Private Message Reply: 12 - 57
David_Farmer
Posted on: April 6th, 2018, 09:25:21
Private Message Reply: 13 - 57
David_Farmer
Posted on: April 6th, 2018, 09:26:46
Thanks to Mike Brown for completing the fibreglass work needed (including reinstating the bottom rear of every arch, which presumably had been cut away to make room for 12" wheels) and taking off the nasty white paint.
Last modified April 7th, 2018, 09:07:09 by David_Farmer
Private Message Reply: 14 - 57
David_Farmer
Posted on: April 6th, 2018, 09:27:16
Private Message Reply: 15 - 57
David_Farmer
Posted on: April 6th, 2018, 09:27:38
Private Message Reply: 16 - 57
David_Farmer
Posted on: April 6th, 2018, 09:28:01
Private Message Reply: 17 - 57
David_Farmer
Posted on: April 6th, 2018, 09:28:47
Back from the sprayer
Private Message Reply: 18 - 57
David_Farmer
Posted on: April 6th, 2018, 09:29:29
Private Message Reply: 19 - 57
David_Farmer
Posted on: April 6th, 2018, 09:29:58
Private Message Reply: 20 - 57
David_Farmer
Posted on: April 6th, 2018, 09:30:21
Private Message Reply: 21 - 57
David_Farmer
Posted on: April 6th, 2018, 09:30:49
Private Message Reply: 22 - 57
David_Farmer
Posted on: April 6th, 2018, 09:31:13
Private Message Reply: 23 - 57
David_Farmer
Posted on: April 6th, 2018, 09:32:43
Subframes were zinc'd & plastic coated. Amazing what colours are available now
Private Message Reply: 24 - 57
David_Farmer
Posted on: April 6th, 2018, 09:34:22
Then I moved house to one where there was no garage    So I had to turn this...
Private Message Reply: 25 - 57
David_Farmer
Posted on: April 6th, 2018, 09:55:56
And after 2 years, into this...
Last modified April 7th, 2018, 09:08:45 by David_Farmer
Private Message Reply: 26 - 57
David_Farmer
Posted on: April 6th, 2018, 09:57:00
Nice & cosy
Private Message Reply: 27 - 57
Posted on: April 6th, 2018, 16:35:20 Quote Report to Moderator
Looks outstanding with paint on. I'm looking forward to seeing it progress.
Private Message Reply: 28 - 57
Colin Jenkins
Posted on: July 6th, 2018, 17:53:07 Quote Report to Moderator
Looking good, what did you do with the sunroof? I could be interested if you wanted to sell it.
Colin
Private Message Reply: 29 - 57
David_Farmer
Posted on: July 8th, 2018, 08:46:28 Quote Report to Moderator
Unfortunately it had rotted out. I spent a long time searching for another but all the ones I found were much longer, so I filled the hole back in. In the early marketing brochures the car did not have a sunroof, so I assumed it was added by a new owner at a later date. Then I saw a photo of the Mini Marcos stand at the 1968 Earls Court motor show which clearly showed the car with the sunroof, so it it must have been a later factory addition. If I ever find another, I may return it.
Last modified July 8th, 2018, 08:47:23 by David_Farmer
Private Message Reply: 30 - 57
Colin Jenkins
Posted on: July 9th, 2018, 21:59:05 Quote Report to Moderator
By 'rotted out' did you mean the fabric or the metal work? The width is the important thing, a long sun roof can be shortened but not if too wide I don't think.
Private Message Reply: 31 - 57
David_Farmer
Posted on: July 9th, 2018, 22:13:15 Quote Report to Moderator
I mean the metal work
Private Message Reply: 32 - 57
David_Farmer
Posted on: August 5th, 2018, 14:41:19
Great news, both the Le Mans & the Factory Demo cars are now finished!
Private Message Reply: 33 - 57
Phil Smethurst
Posted on: January 7th, 2019, 22:39:55
David farmer - these shots may be of interest to you.
Private Message Reply: 34 - 57
Phil Smethurst
Posted on: January 7th, 2019, 22:44:21
Listed as John Frost's and appeared in the MOC magazine in Spring 1988.
interstingly enough when I had just bought my car and was dropping my mum at Manchester airport in it around 1994 or 1995 a guy came up to me in the car park - dressed in business suit - and said "I like your Marcos, I had one a few years ago" and I'm sure he said the plate was 370 JEA and it was or had been white. I can't recall if he said he was the one who built it or if he'd rebuilt it.
Private Message Reply: 35 - 57
David_Farmer
Posted on: January 8th, 2019, 20:40:35 Quote Report to Moderator
Yes these pictures are of interest as I had not seen him in green, just red or white. Many thanks for sharing. Do you have the photos in a jpeg? I like to collect all the history I can get hold of.
So I have the old style log book which only dates back to 1978, but from then until 1990 it was owned by John and then afterwards Paul Frieda until 1996 when I took charge (it was white). So if the car was green in 1988, then anyone approaching you 94/95 saying they used to own it when it was white, must have been John and he must have painted it that colour.
Last modified January 8th, 2019, 20:41:33 by David_Farmer
Private Message Reply: 36 - 57
Phil Smethurst
Posted on: January 9th, 2019, 10:46:06 Quote Report to Moderator
Hi David,
            Glad they are unseen by you and can add to the cars history. The pics are in an old Marcos Owners Club magazine. I’ve been flicking through my old collection and noted 370 JEA and knew something had been on the forum about the car and of course the reg stuck in my head from years ago.
I can scan the magazine and send to you but that would be a PDF. Drop me an address to send them to and I’ll fix it up at weekend.
Phil
Private Message Reply: 37 - 57
Gary Marlow
Posted on: January 13th, 2019, 08:39:00 Quote Report to Moderator
Have been following the rebuild of JEA and it looks great so far - colour looks good too!
Who did the paint work as it looks a tidy job, did you do all the prep for this or was this done by the painters?
The 'old photos' when it was green are a nice addition to the history of the car as well.
What did the car originally run with? I am guessing a 1275 engine and box?
Keep posting!
Gary
Private Message Reply: 38 - 57
Phil Smethurst
Posted on: February 6th, 2019, 21:14:45
I keep stumbling acrosss 370 JEA!!!.......There might be another owner of the car? as around end of Nov 94 or early 95 it is advertised in the club mag for sale.....
Somebody had been taking care of it back then.
Private Message Reply: 39 - 57
Phil Smethurst
Posted on: February 9th, 2019, 22:33:35
370 JEA appears for sale again end of 1996 - presumably when you bought it David.
Private Message Reply: 40 - 57
David_Farmer
Posted on: February 18th, 2019, 22:28:53 Quote Report to Moderator
Yes it was 96 when I first got hold of the car, though I think it was yet another ad that I replied to. I'll have to dig out my old mags to see if I still have it.
I've sent you an email for the photos
Private Message Reply: 41 - 57
David_Farmer
Posted on: February 18th, 2019, 22:51:35 Quote Report to Moderator
Mike Brown did a lot of the prep while he was repairing the fibreglass. The paint was done by a local semi-retired chap who was recommended to me.
The car came to me with a 1300GT engine, but there's also evidence of another hole for the gearshift closer to the bulkhead which would suggest a magic wand set up. So chances are it was originally built with a smaller engine.
Private Message Reply: 42 - 57
Posted on: November 9th, 2020, 00:07:11 Quote Report to Moderator
Came across this while searching for something else.....
Private Message Reply: 43 - 57
David_Farmer
Posted on: November 9th, 2020, 17:19:47 Quote Report to Moderator
Wow that's an amazing picture! To have the FLIRT girls pictured with the car is a great find. The website its on seems to want 159 for it and I'm guessing the original photographer isn't around anymore with a negative to develop an image from. Well Christmas is coming...
Private Message Reply: 44 - 57
Posted on: November 9th, 2020, 17:49:54 Quote Report to Moderator
Some video including 370 JEA with the FLIRT girls on British Pathe:
https://www.britishpathe.com/video/girls-from-f-l-i-r-t
Private Message Reply: 45 - 57
David_Farmer
Posted on: March 24th, 2022, 06:50:12
I found another one
Private Message Reply: 46 - 57
David_Farmer
Posted on: October 8th, 2023, 10:32:37 Quote Report to Moderator
Does anyone have a rusted out van tank that is ready for the scrap yard but could still be used as a template?
Last modified October 8th, 2023, 10:33:49 by David_Farmer
Private Message Reply: 47 - 57
Posted on: November 2nd, 2023, 13:58:51 Quote Report to Moderator
Another one of the FLIRT ladies and 370 JEA.
Private Message Reply: 48 - 57
David_Farmer
Posted on: November 5th, 2023, 13:37:15
And another:
Private Message Reply: 49 - 57
David_Farmer
Posted on: November 5th, 2023, 13:46:53
Here is another with the car on the Mini Marcos stand at the Sports Car Show, Olympia January 1967
Last modified November 5th, 2023, 14:30:45 by David_Farmer
Private Message Reply: 50 - 57
David_Farmer
Posted on: November 5th, 2023, 13:54:18 Quote Report to Moderator
I was just looking at some materials I have gathered over time and I remembered once hearing that when Marcos Cars were carrying out their production run of 50 Mini Marcos for homologation purposes, that some may have worn more than one chassis number so as to make up the numbers. I may have found evidence of this with my car. The 1967 Sports Car Show ran from 4th-14th January and the RAC certificate (for homologation) shows the manufacturing start date of cars serial numbers 7006-7057 beginning on 1st February 1967. Thanks to photos being taken at the time, we know 370JEA was at the car show, which would imply that its chassis number should have been in the range of 7000-7005. But its actual number is 7039. Something not quite right there!
I have always thought that a run of 39 cars was a lot to do, then to eventually decide that maybe a factory demo car would be a good idea
Last modified November 5th, 2023, 13:56:22 by David_Farmer
Private Message Reply: 51 - 57
David_Farmer
Posted on: November 5th, 2023, 14:14:42
Well I have finally had time to bolt some parts back onto the car
Private Message Reply: 52 - 57
David_Farmer
Posted on: November 5th, 2023, 14:15:45
And some more
Private Message Reply: 53 - 57
David_Farmer
Posted on: November 5th, 2023, 14:16:43
And the other side
Private Message Reply: 54 - 57
David_Farmer
Posted on: April 8th, 2024, 19:47:27
The 7.9" vented discs were a little too wide to keep the new wheels under the arches, so had to revert to 7.5"
Private Message Reply: 55 - 57
David_Farmer
Posted on: April 8th, 2024, 19:48:29
Rear corners now completed as well
Private Message Reply: 56 - 57
David_Farmer
Posted on: April 8th, 2024, 19:55:39
Braking system nearly all fitted, unfortunately the man from Mini Sport didn't sell me everything I needed, so the area around where there should be a banjo connector is a little spartan
Last modified April 8th, 2024, 19:56:41 by David_Farmer
Private Message Reply: 57 - 57
Powered by e-blah Platinum 7 Final © 2001-2004   -   July 21st, 2024, 06:31:48
Files opened: 225 | Files closed: 225
