  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  TIME TO REBUILD
0 Members Browsing (35 Guests)
Pages: « 1, 2, 3, 4 » : All Reply Recommend Print
  Author    TIME TO REBUILD   (currently 3,203 views)
Posted on: June 4th, 2019, 18:49:29 Quote Report to Moderator
Some really good progress there Simon!
(Must pull my finger out on mine - ho hum).
Liking the centre console.
Private Message Reply: 30 - 51
Philip_Davenport
Posted on: June 6th, 2019, 13:59:06 Quote Report to Moderator
Simon -- did you get the Lexan windows? Can you share pics? Im thinking of fixed front windows with slider kits in. Ive got two soft top cars (MR2 & Spitfire) for summer, will so use the Marcos more in cooler months - especially in the snow -wicked ..
IMM is mid-August, so maybe 9 weeks of DVLA sh1te if you are taking the Marcos.. Id have no chance. Engine has not run in 30+ years ..
Last modified June 6th, 2019, 14:00:14 by Philip_Davenport
Private Message Reply: 31 - 51
Simon_Pike
Posted on: June 6th, 2019, 21:44:28 Quote Report to Moderator
Yes I did get them,but unfortunately they dont fit as the templates used were for a marcos cars mk4 which have smaller windows. Mines a dh fibreglass mk4
Last modified June 6th, 2019, 22:03:14 by Simon_Pike
Private Message Reply: 32 - 51
Philip_Davenport
Posted on: June 7th, 2019, 07:51:33 Quote Report to Moderator
Sorry to hear that. A pain in butt ! So what do you do next about them?
Private Message Reply: 33 - 51
Simon_Pike
Posted on: June 7th, 2019, 08:41:03 Quote Report to Moderator
Quoted from Philip_Davenport, posted June 7th, 2019, 07:51:33 at here
make a template from my remaining original window and get them remade,hopefully sell the other ones
Private Message Reply: 34 - 51
Simon_Pike
Posted on: June 11th, 2019, 09:18:51
Attachment: 62138644_928463114151865_211200060388540416_n.jpg - 47.64 KB (1175 views)
thanks to craig smith for making the harness brace bar
harness fitted another job done
Private Message Reply: 35 - 51
Simon_Pike
Posted on: June 11th, 2019, 09:19:57
Attachment: 62256110_929189187412591_9089858065016029184_n.jpg - 51.62 KB (1177 views)
had a little play around fitting arches need to cover those wide wheels,not the best arches but they are the perfect width
Private Message Reply: 36 - 51
Simon_Pike
Posted on: June 11th, 2019, 09:20:21
Attachment: 62247507_929189220745921_6944217941533523968_n.jpg - 45.58 KB (1177 views)
rear looks ok
Private Message Reply: 37 - 51
Simon_Pike
Posted on: June 14th, 2019, 09:29:00
Attachment: 62307166_929795420685301_4209288496650649600_n.jpg - 68.93 KB (1177 views)
had to take the wiper motor apart and turn the cog 180 degrees,
now the wiper blades stop on the passenger side not the drivers side
Private Message Reply: 38 - 51
Simon_Pike
Posted on: June 14th, 2019, 09:30:45
Attachment: 64784066_931729640491879_8389548404564295680_n.jpg - 44.02 KB (1172 views)
managed to get the bonnet secured down,unfortunatly the previous owner had cut the lip off at the front.
just need to sort the big hole out or stick a v8 in it with a holley carb out the bonnet
Private Message Reply: 39 - 51
Simon_Pike
Posted on: July 12th, 2019, 14:14:30
Attachment: 64267861_932102247121285_7676914803608125440_n.jpg - 78.64 KB (1173 views)
been having a look around trying to find something to cover the massive bonnet hole.
found a bonnet vent for a mitsubishi l200,i dont think it looks to bad,its only until i get a new bonnet
Private Message Reply: 40 - 51
Simon_Pike
Posted on: July 12th, 2019, 14:15:31
Attachment: 64576388_932102270454616_6439623519784402944_n.jpg - 68.41 KB (1171 views)
pretty good
Private Message Reply: 41 - 51
Simon_Pike
Posted on: July 12th, 2019, 14:20:44 Quote Report to Moderator
thinks havnt been going to good lately,
I re-ordered a new drivers window in the new dimensions as the previous ones i ordered were the wrong size.
Waited 5 weeks and they had sent me the same old dimension windows,so thats another long wait for replacements
and now i found out the dvla never received my v5 after 6 weeks of waiting(yeh of course it was lost in the post)
So now there will be no imm in the marcos for me
Private Message Reply: 42 - 51
Simon_Pike
Posted on: July 19th, 2019, 09:54:31
Ive been staying out of the garage for the last 3 weeks due to the problems with the dvla and a certain plastics company,just totaly took the wind out of my sails and put me right off the marcos.
But i did venture into the garage last night and though i would have another go at making a door handle as i had one left after the last one melted.
over the moon i actually managed it
Private Message Reply: 43 - 51
Simon_Pike
Posted on: July 19th, 2019, 09:55:10
top job
Private Message Reply: 44 - 51
Powered by e-blah Platinum 7 Final © 2001-2004   -   March 2nd, 2021, 00:45:07
Files opened: 87 | Files closed: 87
