Mini Marcos Forum > Mini Marcos > 7213 Topic Started by: Philip_Davenport |
Printable Version | |||||
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 18:51:53 | |||||
I'm pleased to be the new owner of 7213. The prior owner had the car from 1985 and it was registered in March 1969. |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:13:52 Reply: 1 |
Looks nice.. |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:15:07 Reply: 2 |
Interesting badge |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:16:46 Reply: 3 |
Nice face.. |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:18:14 Reply: 4 |
Inside.. after vacuuming |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:20:49 Reply: 5 |
Cool... |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:21:20 Reply: 6 |
Inside.. |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:22:59 Reply: 7 |
Special fuel tank float..it's a digital internet ready OLED capable external float..... |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:24:08 Reply: 8 |
Special twin pipe exhaust, shortened to lower weight for racing. |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:26:24 Reply: 9 |
Another cool badge... I keep these.. |
Posted by: Philip_Davenport | Posted on: March 17th, 2019, 19:33:28 Reply: 10 |
So what comes next.. i think the petrol tank will be first to get attention. |
Posted by: mike brown | Posted on: March 17th, 2019, 22:05:36 Reply: 11 |
Lotus colours not sure if it works or not but I've seen an awful lot worse. Couple of weekends and that'll be ready to go. |
Posted by: Philip_Davenport | Posted on: March 18th, 2019, 12:32:45 Reply: 12 |
Cheers Mike, Do you have any hints on exhaust? |
Posted by: Philip_Davenport | Posted on: March 18th, 2019, 14:09:09 Reply: 13 |
I think i found exhaust ... |
Posted by: Gary Marlow | Posted on: March 18th, 2019, 17:03:37 Reply: 14 |
Looks like you have a rear anti roll bar on the MM as well. |
Posted by: mike brown | Posted on: March 18th, 2019, 18:30:31 Reply: 15 |
My last Marcos had an extended mini van system but the Mk3 shouldn't need the extension. Single box will be loud without being illegal (regardless of no mot requirement). |
Posted by: Philip_Davenport | Posted on: March 18th, 2019, 19:37:02 Reply: 16 |
Gary, I thought you were pulling my leg...but there is one.. maybe the engine is a cooper?? 🤔 |
Posted by: Philip_Davenport | Posted on: March 18th, 2019, 19:39:04 Reply: 17 |
Other side.. |
Posted by: Philip_Davenport | Posted on: March 18th, 2019, 19:40:17 Reply: 18 |
Thanks Mike |
Posted by: Philip_Davenport | Posted on: March 19th, 2019, 19:31:01 Reply: 19 |
So the engine has five studs facing front, not seven. I can't see tappet covers on the back of the block. It has aluminium plate on the back saying 1275. It has long arm on clutch release lever... |
Posted by: Gary Marlow | Posted on: March 19th, 2019, 20:05:24 Reply: 20 |
Still might be something reasonable inside? |
Posted by: mike brown | Posted on: March 20th, 2019, 11:47:06 Reply: 21 |
A standard 1275cc is very spritely in a Marcos. Yes more is nice but I would build it with that then drive it and go from there assuming it's serviceable. |
Posted by: Philip_Davenport | Posted on: March 20th, 2019, 13:22:23 Reply: 22 |
The car hasn't moved for many years, hence the rusted out exhaust + fuel tank and the engine bay looks really rough. However the pistons are not seized. |
Posted by: Philip_Davenport | Posted on: March 23rd, 2019, 18:04:05 Reply: 23 |
Got some of these... need seat belts because the car goes so fast!!!.. we have three point harnesses, possibly fifty years old and very crusty and rusty. They were soaked in the bath for a day and the webbing is like new now but the metal fittings need attention. |
Posted by: Philip_Davenport | Posted on: March 23rd, 2019, 18:08:04 Reply: 24 |
And we have a fuel tank to go in. The perspex rear screen had to come out to get some access to the fixings. |
Posted by: mike brown | Posted on: March 23rd, 2019, 22:19:14 Reply: 25 |
At this rate you'll have it on the road in no time. |
Posted by: Philip_Davenport | Posted on: March 25th, 2019, 08:23:33 Reply: 26 |
Thanks Mike! |
Posted by: Craig Smith | Posted on: March 25th, 2019, 17:14:04 Reply: 27 |
Great to see another car with a keen owner and under restoration. Be prepared, you will spend a lot more than you bargained for! |
Posted by: Philip_Davenport | Posted on: March 26th, 2019, 11:27:50 Reply: 28 |
cheers Craig, |
Posted by: Colin Jenkins | Posted on: March 28th, 2019, 21:08:25 Reply: 29 |
Nice project, can I ask where you bought the petrol tank? Ill be looking for one myself soon. |
Posted by: Colin Jenkins | Posted on: March 28th, 2019, 21:16:08 Reply: 30 |
Posted by: Graham_Thurston | Posted on: March 29th, 2019, 10:06:28 Reply: 31 |
Van tank in stainless from Minispares about £160 |
Posted by: Philip_Davenport | Posted on: March 29th, 2019, 11:07:25 Reply: 32 |
Colin |
Posted by: mike brown | Posted on: March 29th, 2019, 11:35:13 Reply: 33 |
All tanks are bare on the inside the idea is the fuel stops it from rusting. |
Posted by: Neil KilBane | Posted on: March 29th, 2019, 16:25:50 Reply: 34 |
I was lucky enough to buy a pair of galvinised van tanks that were made in Canada back in 2004 at the IMM in Norfolk. Back then they were £95 each too. |
Posted by: Gary Marlow | Posted on: March 29th, 2019, 16:51:31 Reply: 35 |
My original tank rusted on the inside and through the tank, just above the line of the fuel that was left sitting in the tank, fortunately have another new one that I bought many years ago and is sealed so should be fine when I finally get onto it. |
Posted by: Philip_Davenport | Posted on: March 30th, 2019, 18:00:54 Reply: 36 |
I might regret it but i ordered a tin of Rustoleum paint and some rollers ...i reckon i can lay on some coats and cut it back... |
Posted by: mike brown | Posted on: March 30th, 2019, 19:04:48 Reply: 37 |
All cars were hand painted once. I've seen good results with a roller and cutting back it's edges and corners that will catch you out. A soft pad on a DA is great for flatting back the paint ready to polish up. |
Posted by: Philip_Davenport | Posted on: April 4th, 2019, 11:22:26 Reply: 38 |
The lenses on the rear lights are cracked so i thought replacing the lenses could be an easy job.. |
Posted by: admin | Posted on: April 4th, 2019, 20:53:51 Reply: 39 |
Those lights say "trailer"! Get some Mini Van rear lights and fit them upside down. Then a repro Lucas number plate lamp or a die-cast Mini one. |
Posted by: Philip_Davenport | Posted on: April 9th, 2019, 12:12:49 Reply: 40 |
Craig said earlier: Be prepared, you will spend a lot more than you bargained for! |
Posted by: mike brown | Posted on: April 9th, 2019, 18:37:13 Reply: 41 |
If it makes you feel better I finished building a long wheelbase foers ibex last year. That cost me £15k over 5 years when you consider that if I'd bought the kit new (mine was an un-started kit off ebay) it would of cost £12k for the kit alone. |
Posted by: Philip_Davenport | Posted on: April 10th, 2019, 10:56:03 Reply: 42 |
much respect ! |
Posted by: mike brown | Posted on: April 10th, 2019, 14:45:39 Reply: 43 |
I'm currently banned from starting my Jem until I've finished the house and another little project (building a caravan using a lorry fridge box). |
Posted by: Philip_Davenport | Posted on: April 10th, 2019, 17:32:39 Reply: 44 |
Hi Mike, |
Posted by: mike brown | Posted on: April 10th, 2019, 17:41:46 Reply: 45 |
Glad it arrived safely. To be fair she owns a Jem that needs restoring as well so I've actually got two to do. |
Posted by: Philip_Davenport | Posted on: April 29th, 2019, 18:11:27 Reply: 46 |
Had to grind a lot to get 30 year old nuts off... painted new one.. just need to get the rest of the bits together and screw it back on.. |
Posted by: Philip_Davenport | Posted on: April 29th, 2019, 18:12:38 Reply: 47 |
First coat of Rustoleum went on... now i see it needs some filler.. |
Posted by: Philip_Davenport | Posted on: April 29th, 2019, 18:13:03 Reply: 48 |
Not orange peel... |
Posted by: Philip_Davenport | Posted on: April 29th, 2019, 18:13:47 Reply: 49 |
Roll bar and front panel... |
Posted by: mike brown | Posted on: April 30th, 2019, 08:26:30 Reply: 50 |
If you want some inspiration YouTube channel soup classic motoring. https://youtu.be/h0LAPH4QHtw |
Posted by: Simon_Pike | Posted on: April 30th, 2019, 09:54:24 Reply: 51 |
fantastic project,keep up the good work |
Posted by: Philip_Davenport | Posted on: April 30th, 2019, 11:33:37 Reply: 52 |
Cheers Mike |
Posted by: Philip_Davenport | Posted on: April 30th, 2019, 11:45:44 Reply: 53 |
cheers Simon ... let's see who is on the road first :0) |
Posted by: Simon_Pike | Posted on: April 30th, 2019, 13:07:46 Reply: 54 |
hoping to get mine done for summer,got it running yesterday |
Posted by: Philip_Davenport | Posted on: May 3rd, 2019, 08:24:58 Reply: 55 |
Yippeee..... Looking forward to a trip to Stoneleigh at the weekend !!! |
Posted by: mike brown | Posted on: May 3rd, 2019, 08:42:25 Reply: 56 |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:10:12 Reply: 57 |
I like the stop motion as he takes himself out of the film and just shows his work. The problem with this though and with Wheeler Dealers etc is that it it makes things look easy. I bet he spends a couple of weeks behind his computer editting a 20 minute clip. |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:27:44 Reply: 58 |
I have a theory ... that the wondow rubbers from a Mini can be used on the Marcos... i hope so as i have a full set! Lets see.. |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:28:51 Reply: 59 |
And side window |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:43:15 Reply: 60 |
Got some dials for Mikes dash... |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:44:07 Reply: 61 |
A bit rough on the back ..but might polish up... |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:48:01 Reply: 62 |
So anyway, spent the day putting the rear subframe back together.. took ages!!! |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:49:45 Reply: 63 |
Hi tech.... |
Posted by: Philip_Davenport | Posted on: May 6th, 2019, 16:52:45 Reply: 64 |
Not sure if this is right...maybe too much rubber?? |
Posted by: Simon_Pike | Posted on: May 7th, 2019, 08:44:20 Reply: 65 |
lump hammer,love it phillip |
Posted by: Philip_Davenport | Posted on: May 7th, 2019, 15:17:50 Reply: 66 |
Hi Simon, it was good to meet you on Sunday. Lump hammer is a change from angle grinder ... none of the bolts/nuts come off... grr! |
Posted by: Philip_Davenport | Posted on: May 8th, 2019, 08:07:14 Reply: 67 |
Had to empty out the boxes in the attic, the boxes in the shed and ....lots of other boxes to find these.. (they were no good from the old sub-frame, and they were all the smaller dia ones anyway) |
Posted by: Philip_Davenport | Posted on: May 9th, 2019, 08:06:55 Reply: 68 |
Bought some 50mm snap hook clips for the seatbelts from ebay.. |
Posted by: Philip_Davenport | Posted on: May 9th, 2019, 08:09:42 Reply: 69 |
The old ones had been eaten by a mouse.. |
Posted by: Philip_Davenport | Posted on: May 9th, 2019, 08:10:50 Reply: 70 |
Look okay but need two more clips.. |
Posted by: Simon_Pike | Posted on: May 9th, 2019, 08:23:15 Reply: 71 |
Posted by: Philip_Davenport | Posted on: May 13th, 2019, 13:08:58 Reply: 72 |
No pictures .. but was working .. wanted to finish rear sub frame, petrol tank, rear windscreen and the stuff at the back... |
Posted by: Philip_Davenport | Posted on: June 5th, 2019, 14:06:34 Reply: 73 |
yippee.... The registration doc arrived today... No checks or hassle... just lots of waiting … I was worried .. |
Posted by: Neil KilBane | Posted on: June 5th, 2019, 17:02:08 Reply: 74 |
Congrats :) |
Posted by: Philip_Davenport | Posted on: June 6th, 2019, 10:34:24 Reply: 75 |
thanks Neil. Just saw that the car has not been taxed so used on the road since 1986 so 34 years .. and a lot of this was stood outside judging by the extent of rust.. |
Posted by: Simon_Pike | Posted on: June 6th, 2019, 10:53:59 Reply: 76 |
excellent now you can crack on. get it done for imm in august. |
Posted by: Philip_Davenport | Posted on: June 10th, 2019, 08:30:32 Reply: 77 |
Only managed to get an hour on the car.. started fitting front light covers and clearing space for the radiator... which was not easy as every bolt needs grinding off and i trashed the Dremel mandrel thing.. |
Posted by: Philip_Davenport | Posted on: June 10th, 2019, 08:31:31 Reply: 78 |
Glued the bracket first to get right position, then drilled through later.. |
Posted by: Philip_Davenport | Posted on: June 10th, 2019, 08:33:29 Reply: 79 |
Nuts on from top as access through headlamp bowl wasn't great. |
Posted by: Philip_Davenport | Posted on: June 21st, 2019, 12:38:09 Reply: 80 |
So the car is historic now |
Posted by: Philip_Davenport | Posted on: September 8th, 2021, 14:44:02 Reply: 81 |
After getting inspiration from |
Posted by: Philip_Davenport | Posted on: September 8th, 2021, 14:53:01 Reply: 82 |
--talking to lots of MM owners at "Marcos on the Moor" at the home of Ewen Sergison and Rachel |
Posted by: Philip_Davenport | Posted on: September 8th, 2021, 15:02:31 Reply: 83 |
-Goff taking me out for a ride and talking to me about his two Jems. This picture is from Goffs page as I took my photos on Sunday after Goff went back to Maltby. |
» Print page generated: August 10th, 2022, 18:13:38 « Powered by e-blah Platinum 7 Final © 2001-2004 |
