Mini Marcos Forum  >  Mini Marcos  >  DH8302
Topic Started by:
Matt_Phillips
Printable Version
Posted by: Matt_Phillips Posted on: April 3rd, 2019, 07:39:22
Hi all,
Just to say hello and pass on that I now own DH8302
https://www.minimarcos.org.uk/minimarcos/8302/index.html
Matt
Posted by: mike brown Posted on: April 3rd, 2019, 08:49:05
Reply: 1
Little bit of work there.
Posted by: Gary Marlow Posted on: April 3rd, 2019, 13:43:17
Reply: 2
Will be good when done.
Funnily enough - well it is for me - the person who built my Mk 3, cut the front off the car with the plan to make the front look more like a Jem.
Gary
Posted by: Gary Marlow Posted on: April 3rd, 2019, 13:46:44
Reply: 3
Hopefully attached!
Posted by: Philip_Davenport Posted on: April 4th, 2019, 10:00:02
Reply: 4
Good luck with this Matt. The front wheel arches look very cool!
I think I can see a  classic Mini under the cover. Is this for parts or is it running?
And a white Mini Marcos in the foreground.. what is the story with this?
Or are these pictures from the prior owner?
cheers Philip
Posted by: admin Posted on: April 4th, 2019, 20:05:28
Reply: 5
Quoted from Matt_Phillips, posted April 3rd, 2019, 07:39:22 at here
Hi all,
Posted by: Matt_Phillips Posted on: April 5th, 2019, 11:14:54
Reply: 6
Quoted from Philip_Davenport, posted April 4th, 2019, 10:00:02 at here
cheers Philip
Posted by: Matt_Phillips Posted on: April 16th, 2019, 16:37:41
Reply: 7
Posted by: Matt_Phillips Posted on: June 12th, 2019, 08:00:13
Reply: 8
The eagle has landed
Posted by: Matt_Phillips Posted on: June 12th, 2019, 08:01:19
Reply: 9
Posted by: Matt_Phillips Posted on: June 12th, 2019, 08:02:09
Reply: 10
Posted by: Matt_Phillips Posted on: June 12th, 2019, 08:03:57
Reply: 11
First batch of powdercoating
Posted by: Graham Bichard Posted on: June 16th, 2019, 14:22:56
Reply: 12
Matt - after the powder coating do you have to re-tap any threaded holes?
If so, does this cause the powder coating to chip off?
Posted by: Matt_Phillips Posted on: February 14th, 2020, 13:51:49
Reply: 13
Posted by: Matt_Phillips Posted on: February 14th, 2020, 13:52:19
Reply: 14
Posted by: Neil KilBane Posted on: February 16th, 2020, 13:01:06
Reply: 15
Any reason you removed the lower lip on the rear panel ?
Posted by: admin Posted on: February 19th, 2020, 18:13:27
Reply: 16
It's coming along nicely. Is that a Speedex beam and trailing arms?
Posted by: Matt_Phillips Posted on: March 3rd, 2020, 17:13:42
Reply: 17
Quoted from admin, posted February 19th, 2020, 18:13:27 at here
i think the beam is a"huddersfield spares" style beam - nothing fancy. The radius arms came in a job lot of parts destined for a hillclimb mini. I've had them for about 13yrs, were off my last mini.
Posted by: Matt_Phillips Posted on: March 3rd, 2020, 17:19:15
Reply: 18
Quoted from Neil KilBane, posted February 16th, 2020, 13:01:06 at here
It ruined the nice lines of the rear end. In my eyes, it was a typical 1970's 'blocky' styling design/addition  done to curvy/ delicate vehicle shapes from the 1960's. Think rubber bumpers on mg midgets and MGB's etc etc.
Posted by: Matt_Phillips Posted on: March 18th, 2020, 13:26:30
Reply: 19
Chop! Unbelievable amount of filler in the nose/mouth. So heavy I believe it would effect handling
Posted by: Matt_Phillips Posted on: March 26th, 2020, 10:53:46
Reply: 20
Crappy bulkhead airbox be gone! Took the decision to get rid as it was just another bit of dodgy fibreglassing. Will replace with a smooth bulkhead.
Posted by: Matt_Phillips Posted on: March 26th, 2020, 10:54:44
Reply: 21
Random bit of flat-ish grp glued and screwed in. This will be glassed in from the back then given a couple of layers of tissue to smooth out the top layer. Then a skim/sand for blending in.
Posted by: Matt_Phillips Posted on: April 1st, 2020, 08:41:53
Reply: 22
Peekaboo!
» Print page generated: August 10th, 2022, 18:23:36 «
