Wasp Mini-Cobra (currently 1,189 views) |
Posted on: April 14th, 2006, 09:46:44 |
Just had a request from Australia - does anyone know what happened to the Wasp Mini Cobra? This was a scaled-down AC Cobra using a Mini power unit that was made in New Zealand. |
scrog |
Posted on: May 18th, 2007, 13:26:38 |
old enough to know better
Reply: 1 - 4 |
Posted on: May 18th, 2007, 16:14:57 |
It's a Berkeley Bandini or Bandera (A-series version). Don't know why it's advertised as an Austin Morris Mini. |
Last modified May 18th, 2007, 22:17:26 by admin |
Reply: 2 - 4 |
scrog |
Posted on: May 19th, 2007, 10:28:49 |
should think is was just classed as being resheld that way it can keep thre doners reg number |
Reply: 3 - 4 |
Posted on: May 21st, 2007, 14:24:36 |
More likely noone bothered to tell the DVLA/local authority. You can keep the donor's registration number if you use sufficient parts from it. If you rebuild the car using a completely different shell then that counts as being radically altered, but the situation is different if you keep the origial floor pan and merely change the bodywork sitting on it. |
Reply: 4 - 4 |
