  Mini Marcos Forum  >  General Boards  >  Sport  >  Le Mans 66
0 Members Browsing (0 Guests)
  Author    Le Mans 66  (currently 1 views)
Posted on: June 27th, 2009, 15:53:10 Quote Report to Moderator
Check out this little video of the 66 race, you can spot our fovourite little car at 32 seconds just after the Alpine A210
http://www.youtube.com/watch?v=JX4H8zRYijU&feature=related
Then check it out again at 3:01 and 4:30 in this clip
http://www.youtube.com/watch?v=_750iUmpN1c&feature=related
Tom Wiggers
Posted on: September 15th, 2009, 18:35:41
http://www.britishpathe.com/record.php?id=71659
Logged
Private Message Reply: 1 - 13
Posted on: September 15th, 2009, 18:58:07 Quote Report to Moderator
Nice clip there Tom!
And weren't the cars more interesting to look at then?  Not all aerodymanic aids and wings!
As for the Le Mans MM, does anyone have any specs on the car?  Spec of the engine, final drive, wheel/tyre sizes etc?
Private Message Reply: 2 - 13
Tom Wiggers
Posted on: September 15th, 2009, 20:52:58 Quote Report to Moderator
car ran more than 200kmph on Mulsanne straight (I believe the 67 car ran 220kmph)
1275 engine (maybe 1293cc)
10" dunlops
I am still waiting for the ACO papers on the 66 car.
Logged
Private Message Reply: 3 - 13
Posted on: September 15th, 2009, 23:20:09 Quote Report to Moderator
The 66 car ran an "off the shelf" 1293cc works customer spec rally prepared engine.
There are some great articles about the 66 race and the car in the main section of the MMOC website .
Private Message Reply: 4 - 13
Posted on: September 16th, 2009, 14:19:22 Quote Report to Moderator
Quoted from Neil KilBane, posted September 15th, 2009, 23:20:09 at here
That's good going, but I wonder what it was revving to?  What final drives were available in 66?
220kmh - whats that in real money?  135mph?
Private Message Reply: 5 - 13
Posted on: September 17th, 2009, 07:46:39 Quote Report to Moderator
I think the '67 car was clocked at 141mph on the Mulsanne straight. I doubt if the engines would be revved above 6,500 for an endurance race in 1966, so that would imply a fairly tall final drive, possibly 2.9:1. The '67 engine would have been a full race engine, which broke because the oil pump drive pin sheared off.
  Private Message Reply: 6 - 13
Rodger Howard
Posted on: September 17th, 2009, 08:36:06 Quote Report to Moderator
My understanding was that they put the largest crownwhhell they could fit in the housing. Would that mean that it was less than 2.9:1?
Private Message Reply: 7 - 13
Tom Wiggers
Posted on: September 17th, 2009, 20:00:34 Quote Report to Moderator
2.9:1 that would app be 19 mph per 1000 revs
If 6500 revs x 19 = ~123 mp/h top
Logged
Private Message Reply: 8 - 13
Tertius van Zyl
Posted on: September 18th, 2009, 09:11:53 Quote Report to Moderator
Reputation: -1 (tot: -1)
I asked the current owner of the 67 car and he has confirmed that it had a 2.9 final drive for le Mans..
Private Message Reply: 9 - 13
Posted on: September 18th, 2009, 19:31:11 Quote Report to Moderator
19mph per 1000rpm.  By my maths that would require 7400ish rpm to hit 141mph.  I'm guessing it would be an all steel bottom end very carefully put together to last 24hrs!
(On a better note, the MPi does approx 22mph per 1000rpm, so I'd 'only' have to hit 6500rpm on the autobahn to do 140mph!   )
Were there any mechanical changes for the 67 car?
Private Message Reply: 10 - 13
Lee Matthews
Posted on: March 20th, 2010, 20:26:00 Quote Report to Moderator
Hi nice clip there Tom video on web need help to post on forum ??? Cheers Lee.
http://www.britishpathe.com/record.php?id=71659  sorry try this out.
Last modified March 20th, 2010, 20:27:27 by Lee Matthews
Private Message Reply: 11 - 13
Posted on: August 24th, 2011, 21:51:38 Quote Report to Moderator
Just found this very good series of articles about the 66 and 67 Le Mans Mini Marcos, its from July but I've not seen it linked here before.
http://maximummini.blogspot.com/2011/07/minis-at-le-mans-1967.html
http://maximummini.blogspot.com/2011/06/minis-at-le-mans-1966.html
It also links to this:
http://www.britishpathe.com/record.php?id=71288
The FLIRT girls in a MM at Castle Comb in 1967
Private Message Reply: 12 - 13
Posted on: August 25th, 2011, 08:54:22 Quote Report to Moderator
Quoted from Rodger Howard, posted September 17th, 2009, 08:36:06 at here
I only just noticed this. Of course you meant the largest pinion. You can get a 2.7:1 final drive into a Mini gearbox but with some machining to provide enough clearance for the pinion.
Btw it's well worth subscribing to the Maximum Mini mailing list which you can do via ether of the blogspot links above.
  Private Message Reply: 13 - 13
New Thread Mini Marcos Forum  >  Sport  [ previous | next ] Switch to:
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 10th, 2026, 16:52:49
Files opened: 121 | Files closed: 121
