harnesses (currently 1 views) |
| Grant Wilson |
| Posted on: August 7th, 2009, 22:47:13 |
LeMans -- 2016
hi,
As I continue to try and finish my cay for the anniversary I again have a question for the forum.
I have harnesses and am unsure where to mount the rear straps. does the 'blue book' allow you to drill through the roll cage, wrap around the cage, or should I just bolt to the rear floor pan?
thanks as always
Grant |
| Tim Neal |
| Posted on: August 8th, 2009, 03:31:33 |
If the rules are anything like our in NZ you can't drill the cage if its been certified/homolagted to the car.
My belts are wrapped around the rear roll cage lateral bar. Not a great angle to try and get a picture! |
Reply: 1 - 3 |
| Allan Brown |
| Posted on: August 9th, 2009, 21:24:17 |
| Mine are wrapped around the roll cage as well. |
Reply: 2 - 3 |
| Guy Humphries |
| Posted on: August 11th, 2009, 10:51:42 |
| Mine too! Just remove the hook clip from the end of the rear straps & wrap round the cage cross bar. |
Reply: 3 - 3 |
