Show me your rear! (currently 5,726 views) |
Posted on: March 21st, 2010, 18:46:54 |
Liking that Richard! And not an LED to be seen
How about door mirrors next then? I'd like to fit thin stem 'Formula' type mirrors, but haven't seen any of these that quote IVA compliant. (I think Ewan has these fitted) This might be a case of fitting something to get it registered than altering afterward (hopefully using the same mounting point). |
Last modified March 21st, 2010, 18:49:29 by Graham Bichard |
Reply: 15 - 18 |
Posted on: March 21st, 2010, 20:37:50 |
Not a digital photo either! Those came from one of the photo display boards I used to take around to shows in the 1990s.
Note the two shots of TMJ 147K, as I got it with the Mk.1 Cortina lights and after I'd restyled the back end. |
Last modified March 21st, 2010, 20:50:59 by admin |
Reply: 16 - 18 |
Posted on: March 21st, 2010, 20:50:29 |
Quoted from Peter Bremner, posted March 19th, 2010, 23:49:46 at here |
Do you get good reception with that aerial?
Peter, I think you got away with that one  |
Reply: 17 - 18 |
Posted on: March 21st, 2010, 20:55:49 |
Reply: 18 - 18 |
