  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  370 JEA Rebuild
0 Members Browsing (10 Guests)
Pages: « 1, 2, 3, 4 : All Reply Recommend Print
  Author    370 JEA Rebuild  (currently 7,110 views)
Posted on: November 9th, 2020, 17:49:54 Quote Report to Moderator
Some video including 370 JEA with the FLIRT girls on British Pathe:
https://www.britishpathe.com/video/girls-from-f-l-i-r-t
Private Message Reply: 45 - 57
David_Farmer
Posted on: March 24th, 2022, 06:50:12
I found another one
Private Message Reply: 46 - 57
David_Farmer
Posted on: October 8th, 2023, 10:32:37 Quote Report to Moderator
Does anyone have a rusted out van tank that is ready for the scrap yard but could still be used as a template?
Last modified October 8th, 2023, 10:33:49 by David_Farmer
Private Message Reply: 47 - 57
Posted on: November 2nd, 2023, 13:58:51 Quote Report to Moderator
Another one of the FLIRT ladies and 370 JEA.
Private Message Reply: 48 - 57
David_Farmer
Posted on: November 5th, 2023, 13:37:15
And another:
Private Message Reply: 49 - 57
David_Farmer
Posted on: November 5th, 2023, 13:46:53
Here is another with the car on the Mini Marcos stand at the Sports Car Show, Olympia January 1967
Last modified November 5th, 2023, 14:30:45 by David_Farmer
Private Message Reply: 50 - 57
David_Farmer
Posted on: November 5th, 2023, 13:54:18 Quote Report to Moderator
I was just looking at some materials I have gathered over time and I remembered once hearing that when Marcos Cars were carrying out their production run of 50 Mini Marcos for homologation purposes, that some may have worn more than one chassis number so as to make up the numbers. I may have found evidence of this with my car. The 1967 Sports Car Show ran from 4th-14th January and the RAC certificate (for homologation) shows the manufacturing start date of cars serial numbers  7006-7057 beginning on 1st February 1967. Thanks to photos being taken at the time, we know 370JEA was at the car show, which would imply that its chassis number should have been in the range of 7000-7005. But its actual number is 7039. Something not quite right there!
I have always thought that a run of 39 cars was a lot to do, then to eventually decide that maybe a factory demo car would be a good idea
Last modified November 5th, 2023, 13:56:22 by David_Farmer
Private Message Reply: 51 - 57
David_Farmer
Posted on: November 5th, 2023, 14:14:42
Well I have finally had time to bolt some parts back onto the car
Private Message Reply: 52 - 57
David_Farmer
Posted on: November 5th, 2023, 14:15:45
And some more
Private Message Reply: 53 - 57
David_Farmer
Posted on: November 5th, 2023, 14:16:43
And the other side
Private Message Reply: 54 - 57
David_Farmer
Posted on: April 8th, 2024, 19:47:27
The 7.9" vented discs were a little too wide to keep the new wheels under the arches, so had to revert to 7.5"
Private Message Reply: 55 - 57
David_Farmer
Posted on: April 8th, 2024, 19:48:29
Rear corners now completed as well
Private Message Reply: 56 - 57
David_Farmer
Posted on: April 8th, 2024, 19:55:39
Braking system nearly all fitted, unfortunately the man from Mini Sport didn't sell me everything I needed, so the area around where there should be a banjo connector is a little spartan
Last modified April 8th, 2024, 19:56:41 by David_Farmer
Private Message Reply: 57 - 57
Powered by e-blah Platinum 7 Final © 2001-2004   -   July 4th, 2025, 03:04:08
Files opened: 52 | Files closed: 52
